Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
F30 error code
I also was cleaning the oven when I started to smell a burning odor. The oven displayed ''F30'', and now I can't use it. It is a 3 month old Kenmore wall oven. Amazing how many problems I have had with an alleged ''top brand name'' appliance company. I am sure they will do their usually, 'our soonest appointment is one week from today' then it will take another week to order to part that needs to be fixed. When the part arrives, I will schedule another appointment and will here 'our soonest appointment is one week from today' and will end up being without the oven for a month.
By the way, this same thing happened to my washer. After the month, I complained about their service protocol. I was advised by the supervisor that if they have to order a part, I could have rented a washer and they would have reimbursed me. Nice to know after the fact. I WILL NEVER BUY FROM SEARS AGAIN!
  • 15,935 Answers
The F30 error code indicates that the electronic oven control board detects an "open" oven temperature sensor probe circuit.
This is usually caused by a failed oven temperature sensor probe.
Replacing this component will likely fix your problem.
You can order this part from www.searspartsdirect.com website.
If you replace this part yourself, be sure that you unplug the range to disconnect electrical power before accessing this component.
On some models, you can replace the probe by removing the screws that mount this component to the inside back wall of the oven.
Carefully pull the probe inside the oven cavity until you encounter the wire harness disconnect plug.
Unplug the sensor and replace it with the new one. Mount the new probe on the back wall of the oven.
On some models, you have to remove the lower back oven panel to access the sensor probe.
If you replace the probe and still have this problem, you will need to unplug the range and measure the resistance through the violet wires that plug into the control board (this is where the sensor probe circuit is connected to the control board).
If the resistance through the oven temperature sensor probe circuit is normal (about 1100 ohms at room temperature) then the electronic oven control board will need to be replaced.
http://media.fotki.com/1_p,wbwdqtgkkqdrrfgxgtqsskgwtqkq,vi/ktrrwffdrxkddstsrtq/1/1303472/5961857/image45310img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 23, 2010
I HAVE A F30 ERR DISPLAY ON BOARD AND THE DOOR IS LOCKED. HOW DO I RESET AND GET DOOR OPEN?
Hello Friend, this is Z. I am happy to assist you!
If you are getting an error code F30 on your Frigidaire range, it usually indicates an issue with a faulty sensor probe or a wiring harness between the sensor probe and EOC (Electronic Oven Control). You may try and reset your range by disconnecting the power or by flipping the circuit breaker off and back on after 10 minutes. This often clears most false error code. If the error code does not clear, most likely the EOC of your range will need replacing. I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website.
Aug 05, 2014 | Frigidaire Ovens
Microwave is smoking when I use it as a convection oven
It seems to be self cleaning... burning all the oils that coats the inside from microwaving food that wasn't covered. Clean the oven well and to remove bad smells put lemon juice in a bowl and microwave.
http://www.wikihow.com/Remove-Odors-from-a-Microwave
Nov 13, 2013 | KitchenAid Architect Series KEMC308KSS...
PLES389ECH F30 ERR code. Oven and stove top is locked out after trying to run self clean. The fan is still running. I have turned breaker off and back on after waiting a day and range is still locked out....
This should help, good info includes links! http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/76555-error-code-f30.html
Oct 27, 2013 | Ovens
EW30EW65SS Stainless Steel smells like burning electrical
Hello purrpplee - If the smell is coming out of the oven vent, more than likely it is something inside the oven that is creating the odor. Also, keep in mind that new cooking products can create a burning electrical odor when the bake and broil cycles are used as any residual coating or film on the oven liner and elements burns off. However, if odor increases consult a professional for an accurate diagnosis.
Jan 31, 2013 | Electrolux EW30EW65SS Stainless Steel...
Flashing PF 32 error code
Hello - This manufacturer does not show to have such an error code for a wall oven. However the error codes F30/F31 indicates that the unit either has an issue with the oven sensor, wiring with the EOC or the probe connections is open or shorted. Contact a professional to move forward accurately.
Nov 10, 2012 | Frigidaire 30 in. Electric Gallery Series...
Had self clean on for a little over 1hour, was set for 2 hours and code F30 was flashing, self clean turned off
Hello & Welcome to FixYa
F30 error means open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you want to do it yourself and wan to be sure before replacing the sensor then you can test it with a voltmeter between 1080-1120ohms....if it reads more then or less then this then it needs replacement however, if the reading is around between 1080-1120ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 10, 2011 | Ovens
Kenmore ultra self cleaning oven or top heat
I found that the 220 plug had burned out, that was where the smoke came from. The display worked because the ground "prong" was the only one burned. Had to replace the electrical 220 socked and the electrical plug on the oven.
Jan 13, 2009 | Ovens
Microwave emits a burning smell when on
there is a transformer dont use it and get it serviced
Dec 28, 2007 | KitchenAid KEHC379JSS Electric Double Oven
Kenmore Elite slide in range F30 error
I had the same F30 error problem but fixed it. On my professional series Frigidaire, there are 2 resettable red button locations. I discovered that only one is in the rear of the oven. After going to the breaker box and shutting off the power, pull out the stove enough to work, unscrew the rear screws (I didn't unscrew all of them, just enough to work back there). The small red button is on a small black round piece with two purple wires feeding to it. That was not my problem. Mine was the other red button behind the control panel. Pull off all 4 knobs, unscrew by hand the large black rings that are underneath the knobs, pull out the whole panel. Look back and right (below where the right knobs were located) to find the 2nd red small button. Push to reset. Check this one first since it is easier to do.
Dec 27, 2007 | Ovens
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
302 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
