Zenith D52WLCD 52 in. Rear Projection HDTV-Ready Television
Problem for Zenith D52WLCD 52 in. Rear Projection HDTV-Ready...
Hitatchi 52" rear projection TV has blue spot in middle of screen
By ybarra_john on Sep 25, 2009
I recently replaced the projection lamp on my 52" rear projection TV and there is an irritating blue "spot" in the center of the screen. Before the lamp went out the TV worked perfectly. Now it seems that the blue "spot" is becoming blue "spots". I tried adjusting everything, but it's not working. I wore latex gloves when I replaced the bulb and vacuumed out all the dust around the lamp cavity. Thanks.
Solution #1
posted on Sep 25, 2009
Not Rated)
techman007
Rank: Guru  Televisions & Videos  Expert
Rating: 87%, 130 votes
Hello :
I suggest u retrace you the steps u took to replace your lamp make sure no foriegn objects got on the prism where the light shines throung the optics engine, if you remove the lamp compartment througly. If you had a perfect picture prior to replacing the lamp, then retracing your steps you might find something that does not belone. One final note: Did you purchase the right lamp 120watts anything higher than this wattage could damage your optics engine. I suggest never vacuuming the compartment because particals fly around from the suction and could get on the glass of the color wheel asembly.
Was this helpful?
Yes
No
Popular Solutions for Zenith D52WLCD 52 in. Rear
Questions and Unsolved Problems for Zenith D52WLCD 52 in. Rear
Do you recommend Zenith D52WLCD 52 in. Rear Projection HDTV-Ready Television?
Answer
Answer
I have a 65 inch 1080. We moved yesterday and when I turned tv on it shows red on lamp button, tv... (More)
Answer
tried the solution to reset the lamp counter on my d52wlcd zenith tv but but nothing happens. No... (More)
Answer
replaced bulb and still have yellow glow and blue dots in center of screen
Answer
TV was on, weather great, went to another room and heard a loud pop. TV had shut off. I tried to... (More)
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in , IL
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
