Question about Bulova Watch
How do you open chanel watches? It has an unusual clasp at the back and I can't get it open to put it on! Please help
Cannot push pins through women's watch clasp to resize. Help?
you dont take pins out of mesh watch bands all you do is put a dart or small screwdriver in the slot to unclamp it slide the clasp were you wont it then lock it in one of the groovs, click link below for instructions please rate me if helped
http://mondainewatch.co.uk/how-do-i-adjust-a-mesh-strap.html
Jan 25, 2013 | Watches
I just recieved my new watch, I do not understand how this watch closes or clasps, so I cannot adjust to size. it is 109179wtcl. In the manual I think it is a metal insert but the picture does not help me....
I have had a couple of watches that have clasps like that. Essentially it folds into itself, if you look at the metal part that does not fit the rest of the band you will notice some rectangular openings and two little projections.
Now, to close it you have to pull each side of the bands in, the metal bar should also fold a little as well, then each side should clasp.
I hope this helps, also to get back open you should just be able to pull it open, it will should have no ill-effect on the watch. I really hope this helps.
Mar 07, 2011 | Anne Klein Watches
I bought my bulova 96R105 today, the jeweler placed it on my wrist, but now I can't undo it. Please help
It may have buttons on the sides of the clasp that you must press. If you do not see the buttons on the sides of band, it is a friction fitting, and you must pull on one or the other side of the "butterfly" clasp for it to release.
If you see a large outside clasp, there will sometimes be a fold over safety. This is called a tri-fold clasp. You must pull up the hinged clasp one direction, then the main clasp the other direction. A bi-fold clasp has no safety, and can be pulled one direction to open.
Feb 04, 2011 | Bulova Diamond Accented Calendar #96R105...
Hello, I have received a just bling womans watch as a gift and can't figure out how to put the wrist ********. Just bling/ JB 6210 serial #17861854
Your watch has double folding clasp and it is opening by pulling bracelet exactly in the middle of clasp. Some clasps are very stiff, so, use a bit of force to open it. Here is the link where you can see how the opened clasp looks:
http://www.amazon.com/Just-Bling-Ladies-JB-6210-Diamond/dp/B002JPK310
Jul 31, 2010 | Bulova Watch
I have a very similar watch to this, except that the face has diamante style stones all the way around the outside. I cannot remove the watch from my wrist - the sales assistant did not show me how! Please...
All watches have clasps to open/release the watch at the rear of the watch look for slight indention and with your thumb and 2nd finger nail pull towatds you and this will release the clasp and to remove you take the clasp out of its gate andwall your watch is released.
Larry
larry.1@live.co.uk
Apr 12, 2010 | DKNY Steel Bracelets Ii #NY3904 Watch for...
Cannot open clasp prestige replica rolex
1)Unscrew the crown until it pops out, the same way you would unscrew the crown to change the time on the watch.
2)Place the watch case opener in the notches around the outside of the back of the watch case. You have to use a watch case opener made for Rolex watches to open the watch. Once the case opener is in place, twist it and the back will pop open.
3)Use a mini screwdriver to loosen a tiny screw on the inside of the watch located near the stem. You do not need to unscrew fully--only loosen it.
4)Pull the crown straight out. The crown and stem should come out easily.
To open the back of the watch
1)Purchase a Rolex watch back opener set, if you do not already have one. This set is able to open and close any size of Rolex case.
2)Match the size of your Rolex case with the same size of grooved metal die from the tool set.
3)Put the metal die on the grooves on the back of the watch case.
4)Turn the die to remove the case.
5)Remove the rubber gasket.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 31, 2009 | Bulova Watch
How to fasten a Skagen watch?
Hi there. Insert the mesh strap inside the hole and secure with the hook and clip fastening with a foldover security clasp.
Hope this one helps.
May 16, 2009 | Skagen Slimline Mesh 358SGS Wrist Watch
I need help
It probibly is a tri-fold clasp or a "hiding clasp" When you look at you watch can you see a clasp? If not you just need to pull from the middle if the back of the band. One end will open to the left another will open to the right. Don't be afraid to pull on it, that probibly is the main problem your having. Movado makes a solid band that can take some punishment
i
Aug 13, 2008 | Movado 0604586 Wrist Watch
Watch clasp on Tag Heuer
http://www.worldofwatches.com/cust/sizingwatch.asp?d=0
Apr 24, 2008 | Tag Heuer WK1111BA0317 wristwatch
I cant open my brand new watch ...HELPPPPPPPPPPPPPPP!
I just recieved a Moldavo Men's Junior Sport (Model # 0605105 with certificate of authenticity) as an award -- but the instructions didn't bother explaining how to put the watch on!
For any hidden clasp band, see this web page (excerpt below):
Refer to the "Hidden Clasp" diagram and follow the instructions under the diagram:
cad9c3e.jpg To open this clasp, reach under the bracelet band and lift upwards. The band extends to allow for easy removal.
Jan 09, 2008 | Movado Kardelo 0605479 Wrist Watch
Bulova Watch Logo
767 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
