Question about HP DeskJet 3740 InkJet Printer
Cannot print works spreadsheet. Computer says "no default printer"
    Scholar:
  • HP Expert
  • 199 Answers
Reinstall works spreadsheet.
Posted on Sep 25, 2009
When printing spreadheet with multiple pages despite asking to print full spreadsheet the printer prints page by page and the resume button needs to be pressen for each page to print
Make sure that the the spreadsheet print settings match the printer settings. They have to be the same, else the printer settings most likely take priority. So when your print window comes up click on the (printer) 'options' (top right corner) and set those options according to the spreadsheet
Sep 27, 2013 | Canon Pixma iP4500 InkJet Printer
While trying to print from a microsoft works spreadsheet...it always says "out of memory" and prints a distorted page.
Hi
here are some ways to override the problem
When you try to print
it says
Microsoft Works Out of Memory
This problem may occur if there is a problem with the printer driver that is installed on your computer.
  • Method 1: Install a different printer driver
    Contact the manufacturer of your printer to inquire about how to obtain and install the most recent version of the printer driver for your printer.
  • Method 2: Configure the printer as the default printer
    Configure the printer driver that you have installed as the default printer. To do this, follow these steps:
    1. Click Start, and then click Printer and Faxes.
    2. Right-click the printer that you want to set as the default printer, and then click Set as Default Printer.
    3. Click File, and then click Close.
    4. Start Works, and then print the spreadsheet or the database file.
  • Method 3: Install an emulation printer driver
    If the problem persists after you install the most recent version of the printer driver for your printer, install an emulation printer driver. An emulation printer driver is a driver that imitates the functionality of a different printer driver. For example, you may be able to resolve this issue if you install the driver for the Hewlett-Packard DeskJet 550C printer or for the Hewlett-Packard LaserJet II printer. To do this, follow these steps if the printer is connected directly to the computer:
    1. Click Start, and then click Printers and Faxes.
    2. Double-click Add Printer.
    3. Click Next, and then click Local printer attached to this computer.
    4. In the Use the following port box, select the port that you want to use.
    If the printer is connected directly to the computer, the port is typically LPT1 (Recommended Printer Port).
    5. Under Manufacturer, click the manufacturer of the printer driver that you want to use as the emulation driver. For example, if you are installing Hewlett Packard 550c, click HP DeskJet 550c.
    6. Under Printers, click the model of the printer that you want to use as the emulation driver, and then click Next. Select HP. In Drivers, select HP DeskJet 550c.
    7. In the Printer name box, type a name for the printer, click Yes to set the printer as the default printer, and then click Next.
    8. Click the appropriate option for sharing the printer, and then click Next.
    9. Click No, and then click Next.
    10. Click Finish.
    Note If you are using a USB printer, go to step 12.
    11. Start Works, and then try to print the spreadsheet or the database file.
    12. Open Control Panel.
    13. Open Printers and Faxes.
    14. Right-click HP 550c, and then click Properties.
    15. Click Ports.
    16. Click USB001 Virtual Printer port for USB.
    17. Click Apply, and then click OK.
    18. Start Works, and then try to print the spreadsheet or the database file.
Hope this will solve your problem
Jan 02, 2010 | HP Photosmart C5180 All-In-One InkJet...
Printing a spreadsheet
You should tell us your "Operating System, Spreadsheet Program and Printer" for us to give you a difinitive answer. Whithout this info I will attempt to give you a general answer.
In your spreadsheet program, go to "File" and select "Page Setup" and set your paper size and set your margines and Portrait/landscape option. Your spreadsheet display should show you the paper limits for printing each page. Adjust the columns to the paper size. Highlight all the columns and rows you want to print. Find the menu option to set print area and click it. Now the computer will send the paged information to the printer and print as many pages as needed to cover the print area.
May 31, 2009 | Apple Office Equipment & Supplies
Microsoft Word problem
This error message may occur when there is a wrong Printer selected when u try to Print but if it still says the same thing just uninstall and reinstall Works and Check............
Good Luck
Mar 01, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Want to print on legal size paper from Tray 1 (top) as default
print menu - config and verify paper is being sensed correctly. If paper size in tray is not set correctly printer will ask where to print from
Feb 12, 2009 | Lexmark T640 Laser Printer
Printer "out of memory"
The problem isn't your printer. The problem is with your Microsoft Works software. I know of six solutions that may work.
1) Download the latest service pack for .NET Framework 1.1. http://www.microsoft.com/downloads/details.aspx?FamilyId=A8F5654F-088E-40B2-BBDB-A83353618B38&displaylang=en
2) Go to this website and download the update. http://www.microsoft.com/downloads/details.aspx?FamilyID=65f5b806-e6a1-4f92-a656-e56eeda67e3d&displaylang=en
3) Uninstall printer completely (again). Unplug the printer from the computer. Reboot computer. Download the lastest driver from HP website. When installing the driver software, choose (type)a different directory,( ie. C:\MYHP\HP4180\ ). Plug Printer back to computer.
4) Go to this website. http://support.microsoft.com/kb/841220
5) Click START, click RUN, type SPOOL. Double click printer folder, clear (delete) any files in this folder.
6) Download the latest version of Microsoft Works 9.0.
Let me know if this works.
Feb 03, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
So which printer are you wanting help with?
Nov 23, 2008 | Office Equipment & Supplies
Problems with printing
Try uodating your printer drivers ,Try to change default printer
Jul 20, 2008 | HP PSC 1315 All-In-One InkJet Printer
Printer not recognizing web browser print request
Hi scooter,
The solution to your problem is that need to go into control panel then printers and set printer as default. If that dont work then try to re-install your printer drivers that should do the job.
Jan 03, 2008 | HP PSC 2210 All-In-One InkJet Printer
Printing-Supercalc 5-Spreadsheet-, Sideways
just to check if the printer and the printer driver is working properly, try printing a 2 page document.
if it prints out correctly - check the applications documentation / user guide for printing instructions.
Dec 28, 2007 | Office Equipment & Supplies
HP DeskJet 3740 InkJet Printer Logo
Seeker5211
Seeker5211
