Question about Chaintech 7VJL APOGEE (CT-7VJL) Motherboard
Why i won't upgrade cpu up to 2500+ bus 166 MHz with mainboard 7VJL APOGEE ?
  • Dave Lundmark
    Dave Lundmark May 11, 2010
    Get the manual, read it and see what you can do.
What CPU 'chips' can be fitted to the HP Pavilion slimline magnetite motherboards ?
according to HP's compatibility list..
CeleronM 420 (Y) 1.6 GHz
  • 533 MHz front side bus
  • Socket 479
    May 25, 2014 | Washing Machines
    I got "incorrect disk" error message when Win 95 access maxtor 91021u2
    http://www.driverguide.com/driver/detail.php?driverid=673706
    it would appear that there are no drivers for Win 95
    I think it's time you upgrade your computer
    Nov 28, 2013 | Maxtor Computers & Internet
    Can i chage my processor pentium 4 to core2duo my motherbourd is(MSI PM8M-V H (MS-7104 v2) thnkz
    No, you cannot upgrade to a core 2 duo with that motherboard because it is a socket 478.
    Jun 04, 2012 | MSI Computers & Internet
    I have NP-N150-JP01EE and on it DDR2-666 1GB Can i have put there DDR2-800 2GB or must be DDR2-666 2GB
    Yes you can if the mainboard and cpu supports it.
    But i will only run with 666 mhz at the system bus.
    It does no harm to the mainboard to add a 800 mhz ram
    Sep 10, 2011 | Computers & Internet
    I have this motherboard PACKARD BELL BV GA-T671MG. how much ram memory can it have? can i use ddr3? my pcie port supports a 2.2 graphic card?
    System
    System : PACKARD BELL BV ISTART F2310 AIO
    Mainboard : PACKARD BELL BV GA-T671MG
    Bus(es) : ISA AGP PCI PCIe USB
    Multi-Processor (MP) Support : 1 Processor(s)
    Multi-Processor Advanced PIC (APIC) : No
    System BIOS : Phoenix Technologies, 255.255
    Total Memory : 767MB
    Intel Pentium D 3.00GHz
    Packard Bell BV (GA-T671MG)
    SiS chipset (Si671V11)
    DDR2
    1024mb ram
    PACKARD BELL BV
    Model GA-T671MG
    Chipset Vendor Silicon Integrated Systems (SiS)
    CPU Intel Pentium D
    Cpu Socket LGA775 [Socket 775]
    Processor Upgrade ZIF Socket
    Max CPU Speed 3000 MHz
    System Slots 2 PCI, 1 AGP
    Memory Summary
    Location System board or motherboard
    Maximum Capacity 1024 MBytes
    Memory Slots 2
    Error Correction None
    Use System memory
    Maximum Memory Module Size 4096 MBytes
    Manufacturer PACKARD BELL BV
    Model GA-T671MG
    CPU Intel Pentium D
    Memory Summary
    Memory Slots 2
    Use System memory
    it seems this might vary i have listed 4
    hope this helps
    May 17, 2011 | Computers & Internet
    Can I upgrade my CPU to an Intel Core 2 duo 1.7
    You are basically limited to what was optional on the model. So you can only upgrade to one of the following cpus:
    Intel Pentium M 745 (1.8-GHz) with 400-MHz front
    side bus (FSB)
    Intel Pentium M 735 (1.7-GHz) with 400-MHz FSB
    Intel Pentium M 725 (1.6-GHz) with 400-MHz FSB
    Intel Pentium M 710 TJ85 (1.4-GHz) with 400-MHz FSB;
    operates at a lower temperature than other processors
    Intel Celeron M 340 (1.5-GHz) with 400-MHz FSB
    Intel Celeron M 330 (1.4-GHz) with 400-MHz FSB
    And you are limted to 2gb of ram max on this model.
    Apr 12, 2010 | HP Pavilion dv1000 Notebook
    Machine randomly restarts after upgrading RAM
    Ok thats the problem.
    1 module with 2gb is not possible on this board:
    http://www.memoryxxl.net/mainboard::4345_36366/Intel-D102GGC2.html
    Intel D102GGC2 Motherboard Mainboard Speicher Technische Beschreibung Intel D102GGC2:
    Bus Architecture: - Hersteller Standard Ausrüstung: Non-ECC only, Unbuffered only, Chipset: ATI Radeon XPRESS 200 - vom Geräte Hersteller empfohlener maximaler Arbeitsspeicher: 2048MB - Speicher Upgrade: 2 (2 banks of 1) -Speicher Beschreibung: Jeder Slot kann mit DDR2 PC2-4200, DDR2 PC2-5300, DDR2 PC2-6400 und maximal 1GB Speicher aufgerüstet werden. Eine bessere Performance erziehlt man bei paarweiser Modul Installation. (USB Support: 2.x Compliant, Graphics Support: PCI Express x16) - Speicher Bus Architecture:
    You have to use 2 modules with max. 1 gb per module
    Dec 30, 2008 | Intel D102GGC2 Motherboard
    Acer Veriton 5600G Front Side Bus settings/jumpers
    Hi Gerry,
    The understanding of how this works will require some study on your part. This is because you would not have enough basic knowledge to understand any short answers, that someone might give.
    Here are some resources for you to read so you will understand this subject.
    http://computer.howstuffworks.com/motherboard4.htm
    http://www.directron.com/fsbguide.html
    http://en.wikipedia.org/wiki/Front_side_bus
    I hope you will find the answers you are looking for here.
    Good luck.
    Oct 24, 2008 | Acer Veriton 5600G PC Desktop
    Asus A7V8X 1 gb sim
    Have you tried the 1gb in the motherboard on its own but in different slots. i.e try slot 1 then slot 2 then slot 3 and see if you still get beeps.
    Aug 23, 2007 | Abit BL7-RAID Motherboard
    Computers & Internet Logo
    19 people viewed this question
    Top Chaintech Computers & Internet Experts
    Ed Mac
    WTF Chuck.....
    WTF Chuck.....
    Are you a Chaintech Computer and Internet Expert? Answer questions, earn points and help others
