Question about Brother MFC-7820N Printer
I have a brother Fax 2820 with the drum error. I have cleaned the wire and the connectors as suggested on the brother website but to no avail.the fax is just out of warranty and i only use genuine cartridges.Any ideas please?
    President:
  • 2,306 Answers
After running the blue tab back and forth about 20 times, it helps to use a can of air and blow out the area below the tab and also carefully with a Q-tip damp with alcohol, wipe the small wire that is cleaned with the blue tab. Usually works for me...
Posted on Oct 01, 2009
What we can do for brother fax-2820 " DRUM ERROR"
open front cover with the machine on and press the options key.message will appear replace drum unit then select 1 for new.close cover
Oct 25, 2012 | Brother IntelliFax-2820 Laser Fax
Fax message says dust on the drum - clean the corona wire
You should find a BLUE SLIDER on top of the Drum Unit, work it back and forth 10 times.
Feb 02, 2010 | Brother IntelliFax-2820 Laser Fax
GETTING ERROR, DRUM ERROR, SEE MAINTANCE
You need to clean the corona wire.
Open the front door.
Remove the drum unit
Look on the Drum unit for a small blue or purple square slider, sitting in a horizontal slot. This is the Corona cleaner.
Slide this back and forth a couple of times, returning to the original start position
Put it back together and try it out
Good Luck!
Dec 07, 2009 | Brother IntelliFax-2820 Laser Fax
Dust on the drum message - fax 2820 brother
There is a blue colored slider on the drum unit, move it side-to-side 10 times.
Oct 05, 2009 | Brother IntelliFax-2820 Laser Fax
Fax machine has a message that says "open front cover to remove the drum. Clean the corona wire located on the drum."
The fax machine instruction must be done to erase the
message. The corona wire located on the drum needs to be cleaned.
Sep 24, 2009 | Brother IntelliFax-2820 Laser Fax
Print Quality Problem with Brother 2820 Fax
sounds like you are using generic drum and toner. try OEM (brother brand). you say copies are coming out completely gray. try printing an internal report from the control panel. if that is gray or received faxes are gray, then the problem is not in your scanner area, and i would wager you are using "generic" supplies.
hth,
razors
Apr 10, 2009 | Brother IntelliFax-2820 Laser Fax
Dust on the drum carona wire loated on the drum
hey vinny, check out solution #1 on post above labeled "DRUM ERROR". and try that procedure.
good luck,
razors
Mar 30, 2009 | Brother IntelliFax-2820 Laser Fax
"Dust on Drum" problem
try using canned air to clean the coruna chagre wire assy
Apr 16, 2008 | Brother IntelliFax-2820 Laser Fax
Brother fax 2820
Out of the lower paper tray when you go to print? Try this, remove the cassette tray and use a water dampened cloth and clean the gray paper pickup roller off. A lot of times this has paper fiber build up that causes the paper not to feed. The printer has a certain timing pattern for when paper should reach a certain sensor, and if it doesn't, then a jam error will occur.
Jul 18, 2007 | Brother IntelliFax-2820 Laser Fax
Brother MFC-7820N Printer Logo
119 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
