Question about Pioneer Car Audio & Video
How do i make my pioneer super tuner 3d 2 unmute? if i try 2 turn the volume up it just keeps sayin mute and i havent been able 2 find a mute button on it any where?
  • Anonymous Mar 14, 2014
    Good day. Mine Blaupunkt's model not sure but it's built in for Proton Satria Neo. Problem is sometimes volume will turn down or up itself or just mute. FYI horn is also not working and i already removed horn's fuse not sure it affected or not or battery or head unit problem. Thanks dude..
  • 3 Answers
My Pioneer Super Tuner 3 D was working just fine. The face plate was removed by accident while it was operating. Once it was reinstalled the displays all still work but there is no audio any longer.
Posted on Sep 18, 2011
  • 655 Answers
Hello justin_m_san,
Most likely the "mute" lead from the receiver is grounding or shorting against other wiring behind the dash. Without the exact model number, it's not possible to point you to the specific wire. But on the DEH-P5100UB, the mute lead is "yellow/black". I'd check all the wiring and insure that ANY unused leads are securely insulated and kept from touching other wiring or any metal.
Hope this helps.
Posted on Sep 25, 2009
My pioneer avh-p5000 wont unmute. I have already pulled the faceplate off and reset it by pressing the reset button and when I turned it back on it was still muted. It doesent matter what source it is on....
  • Hello and thank you for the opportunity to assist you.
  • Are you getting any errors numbers? Any special icons on the screen? Cables hooked up properly?
  • Have you tried just turning the volume up to see if the mute removes itself? I know you press the knob to mute it but turn the volume up to increase the volume.
  • When you reset the radio did you follow these steps exactlly?
  1. Ignition off first.
  2. Then remove the front panel.
  3. Now engine on.
  4. Now press and hold the reset button for 5 seconds.
  • If your steps were different try this first. If they were the same then you need to reset the entire unit not just the processor.
  • To do a master reset the unit must loose power for a couple minutes. In other words unhook the power or remove both battery cables for two minutes and try it again. Make sure to have any codes you need handy before doing this procedure.
  • Let me know how you do with these steps. If it takes care of you please do rate and comment.
Regards,Tony
Nov 27, 2011 | Pioneer Auto Video Bypass Avh-p5000dvd...
Audio Issues
have you tryed to reset the device, also performing a software update useing your desktop software might fix the problem.
Jun 16, 2008 | GPS
I can hear but people can't hear me
Try to unmute the headset. This may be your problem. The mute function is enabled through the volume buttons. Simply tap both volume buttons at the same time until you hear a mute tone. The mute tone when unmuting the call will be a descending tone. When you tap both volume buttons, if you hear a descending tone you have just disabled the mute function and your problem is solved. If the mute tone is ascending tones you have just enable the mute function and this was not the issue. If this is the case consult your user manual or contact Motorola for trouble shooting.
Aug 27, 2010 | Motorola Mobility H710 Bluetooth Headset
I can hear the other person but they can't hear me
Your headset may be muted. Try to unmute the call. The mute function is enabled through the volume buttons. Simply tap both volume buttons at the same time until you hear a mute tone. The mute tone when unmuting the call will be a descending tone. When you tap both volume buttons, if you hear a descending tone you have just disabled the mute function and your problem is solved. If the mute tone is ascending tones you have just enable the mute function and this was not the issue. If this is the case consult your user manual or contact Motorola for trouble shooting.
Aug 18, 2010 | Motorola Mobility H710 Bluetooth Headset
Trying to find the volume on a lenovo n500 laptop computer
The touch sensors and "volume" button is on the top right corner of the keyboard panel .... above the keyboard keys. press "1" - left most - to mute and unmute press "2" - next - going right - to turn volume down press "3" - next - going right - to turn volume up
or ..
you can press (at the same time) the Fn key and Esc (to mute), Fn key and F1 to decrease the volume, or Fn key and F2 to increase the volume.
Aug 11, 2010 | Lenovo 3000 N500 Notebook
Mute button
Try to unmute from the taskbar control, see if it work. Also try reinstalling sound driver of the system
Nov 25, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Setting clock radio
Press and hold down the "clock" button. You should see your time start flashing. Normally you set the time with the volume or channel control. Check which control lets the selector jump from "hou" to "minute and set the minutes. To exit setting menu, depress "clock" button again
Apr 28, 2009 | Car Audio & Video
How do you turn the sound on if mute is on MMI sound system?
Depress the volume bottom or rotate the volume knob. When on a Bluetooth phone call, the speaker symbol will mute, but unmute when the call ends. Either rolling the right steering wheel scroll or the volume button on the shifter area will should unmute the radio volume.
Apr 20, 2009 | 2006 Audi A6
How to set the clock on Pioneer car stereo Super Tuner 3D
ok what u do is turn radio off hit clock so that it displays the time then hold audio button in until clock starts flashing then use your arrow ****. not your vol. ****.
Mar 04, 2009 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
Proview TFT has got volume option mute , need to unmute it & dont know :(
navigate with the monitor buttons to the OSD (on screen display). menu button brings up the OSD. then use volume buttons to move around. there should be a mute option or indications by symbols how to unmute the sound option. if there is not, i would guess pressing two buttons at the same time might do it.
Sep 30, 2008 | Computers & Internet
Car Audio & Video Logo
676 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
