Question about Dell Inspiron 9100 Notebook
Dell inspiron 9100 laptop computer boots up but
Dell inspiron 9100 laptop computer boots up but screen graphics showing large and blurred pixels ,have plugged into another monitor but still same result ,. is this problem the graphics card ?,
Is the graphics card part of the motherboard on this model ? will i have to replace the motherboard and where will i be able to get a replacement ? thanks carl in australia
  • carl_don Sep 25, 2009
    thanks jimmy, but the screen is unreadable in its present state, cant even make out images
  • 403 Answers
Your motherboard is not the problem. Try this. When you are on your main desktop right click your mouse. Click properties, click on settings. This will show you your monitor settings. Make sure that you have 32 bit clicked on quality. Change your screen resolution so your numbers are higher. Just change it to the resolution that you want. If this does not correct this go to this link to update your video driver http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INS_PNT_P4_9100&os=WW1&osl=en&catid=&impid=
Just copy and paste. This will take you to the page for your laptop. Just select your operation system. Hope this helps.
JimmyC
Posted on Sep 25, 2009
  • James Chavez Sep 28, 2009
    Try this, go to your local goodwill or check out craigslist and get yourself a cheap monitor. Plug it into your port on the back of your computer at least this way you can see what is going on with your system. Let me know if you do this and will see where to go from there.
    JimmyC
Find a windows 7 driver or a windows 7 replacement modem
Robert,
Unfortunately, Dell does not have Windows 7 drivers available for download for the Inspiron 9100. You can click the link below to download the online service manual for steps removing and replacing the modem in your computer.
Inspiron 9100 Manuals
http://dell.to/1KXJsjK
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 17, 2015 | Dell Bcm94154m Dell/inspiron 56k Mdc Modem...
I have a dell 1520 inspiron.. and just now i found on the mid top of the screen a white horizontal line running from right to left side, facing the laptop.. i just want to ask what's the probable cause of...
Hopefully, pixels on the screen light-up ONLY when Windows tells them to light-up. However, you have some electrical problem inside the LCD screen, causing a "row" of LEDs to ALWAYS light-up.
So, your LCD is just "slightly" broken.
It's probably about $200 for a replacement LCD screen,
plus $60 to $75 for "labour" to replace it,
if the white-line annoys you too much.
Oct 10, 2010 | Dell Inspiron 9100 Notebook
Cant remember password to access laptop dell inspiron 9100 , how can i change it or go around it ? thanks
Its better if you can reinstall the OS...
Dell has a default partition on the computer and you can install with the same..
If you have windows vista on the computer then tap F8 when the computer turns on and then you will be able to see the advanced boot options.. Select repair my computer.. In the repair my computer screen select the dell factory image restore...
Your computer will go through the installation and it will be up and running...
If you have windows Xp then you have to turn on the computer and when the dell logo appears you have to simultaneously press control and the F11key.. You will be able to reinstall the OS in this way..
If you dont find this default partition then go ahead and reinstall the OS and then install all the drivers for the system....
Sep 19, 2010 | Dell Inspiron 9100 Notebook
I have reinstalled the software on my Inspiron 9100. Everything installs fine until I install either the Intel chipset drivers or XP SP2 or SP3 updates and then after a reboot the screen displays...
Sounds like a problem with the Video Driver...You can always opt out of installing the chipset driver as really the computer can run without it. Does the Dell website have alternative chipset drivers for this model besides the Intel one? If so try it.
Jun 15, 2010 | Dell Inspiron 9100 Notebook
The images on my computer are blurred
if you use the default dell settings you may experience the problem with blurry images in Internet Explorer. This effect is due to the automatic scaling in IE6 and above. IE tries to resize the images so that everything looks the same as when everything is at smaller dpi, but does a terrible job at it, resulting in blurry and unreadable images. Change the following registry setting from 1 to 0 in order to disable this "feature":
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main\UseHR
[1] Adjusting Scale to Higher DPI Screens (MSDN)
good luck with this. please do this, and get back if u run into a problem. also, if this fixes the problem please rate my answer. thanks so much, Joe
Feb 02, 2009 | Dell Inspiron 1501 Notebook
Dark Screen Inspiron 9100
If you replaced the inverter board and its still dark you need and new backlight itself http://cgi.ebay.com/LCD-Backlight-Lamp-for-Dell-Inspiron-9100-15-4-WXGA_W0QQitemZ150217509448QQcmdZViewItem
Dec 10, 2008 | Dell Inspiron 9100 Notebook
Processor not recognized
Updating bios is outside windows.
Use another computer and download the bios, save it on a floppy, cd or usb
Put the floppy, cd or usb in your pc, change the boot on your pc, let the pc start from whatever u sored your update on
The pc will now update your bios since thats an automatic procedur.
Dont forget to change your boot back to your HDD
Good luck
Dec 06, 2008 | Dell Inspiron 9100 Notebook
Grey screen at boot up
hi!!!
maybe your video card
or
there is a problem
with your os
then try to reformat back-up
your important files
Nov 05, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 9100
That unit has an Inverter board, just below the screen in the LCD panel.
It is the unit that actually brughtens the LCD.
If it is out I purchase them from here:
http://www.smartmicrousa.com/
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 18, 2008 | Dell Inspiron 9100 Notebook
Dell Inspiron 9100 Notebook Logo
122 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
