Question about Ovens
Faulty Daniela oven
Hi, I have similar problem to Tanya. the fan assisted oven on my Daniela doesn't work. Convential oven and grill work OK so guessing it is the lower heating element. Also rang the number on oven and it is wrong, feel sorry for that person. How do I find someone who can service it as it is not common, or do you know if it is a common brand under a different label? Thanks
Hi Fiona, here is the service department number 1800886010 or the manufacturers number is 0296041226
Hope this helps
Pam
Posted on Oct 23, 2009
Hello the main oven is not working but grill and hobs is ok??
If it is a fan assisted oven, and the fan is working o/k, then it is probably the oven element that is faulty.
This is usually located at the rear of the oven compartment behind a removeable cover.
Dec 02, 2010 | Ovens
My zanussi FM9232 fan assisted oven is not heating up, the fan is working
Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Nov 04, 2010 | Zanussi Ovens
Hi my zbf260w built in fan assisted oven is not getting heat in the oven department.The fan and grill are both fine but not the oven,
If the fan is working o/k, then y ou need to replace the oven element, located at the rear of the oven compartment behind removeable cover.
Sep 26, 2010 | Zanussi Ovens
Fan operates but no heat. Oven heats ok on convential oven setting Has operated perfectly during 5 years since purchase
It is probably the oven element that is faulty.
This is to be found at the rear of the oven compartment behind a removeable cover.
Please rate my solution.
Thankyou.
Jan 23, 2010 | Neff Ovens
Good evening i have a BT2431SS baumatic cooker,i have no heat in main oven yet i have the hob and the grill that work ok.
If it is a fan assisted electric oven, and the fan is wrking o/k, then it will probably be a faulty oven element.
This is located at the rear of the oven compartment behind a removeable cover.
Thanks.
Nov 24, 2009 | Baumatic Ovens
Smeg Oven
Their will be two elements in the oven a bottom element and a fan element, sounds like the latter has blown!
Oct 09, 2009 | Smeg SE250XUK Stainless Steel Electric...
Whirlpool oven not heating up, though grill, fan and light still
Hi.
If fan in oven is working o/k, then the prob is most likely the oven element is faulty, and needs to be replaced.
Thanks.
Aug 20, 2009 | Ovens
Baumatic BT187ss Oven All working EXCEPT fan assisted cooking
I have a similar problem with my Zanussi and discovered there is a seperate element arounfd the fan wihich I think may be burnt out. Could be a similar fault have you investigated behind the panels in side the oven?
Mar 08, 2009 | Baumatic B180 Electric Single Oven
Neff faulty Fan
Hi.
I would not think that both fan and element are faulty, although it is possible.
if it has a timer make sure that it is on manual and not on auto, as this would stop the oven working.
Other possible fault is faulty main oven selector switch.
Hope this helps. Please do not for get feedback .
Thanks.
Nov 23, 2008 | Neff U1661 Double circotherm super...
Ovens Logo
610 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
