Question about Sentry Fireproof Safe
I have a security safe at my house and my husbaqnd left for the military and need to get in it! i have the key but dont the trick to opening it once the key is in???
    President:
  • 1,187 Answers
Turn key clockwise 1/4 turn (90 degrees)
then lift the top, it will swing like a suitcase.
Posted on Sep 25, 2009
  • Just Gort
    Just Gort Sep 25, 2009
    Thank you, and thank your husband for serving our country.
How to reset number code on my secursafe. I bought never set it up I have key but dont know how to set up safe with pass code
Open the safe with your key (key slot behind the blanking plate btween the safe knob and the keypad).
on the back of the door is a plastic housing put your hand on the side of the housing near to the hinges, you will feel a small push button.
Press it once the unit will beep and the far right led will illuminate.
key in your new code (8 digits) then press either A or B.
Job Done!
Feb 14, 2017 | Home Security
What is the best lock system for home safes?
There are three kinds of locking mechanisms used for home safes,
1. Lock and key system
2. Pass code system
3. Fingerprint system
The safes with above mechanism and also fireproof is an added advantage. You may check online for price comparison also.
Visit Fire Cabinets Direct to find the best safes for your home.
Sep 15, 2016 | Home Security
Can u assist me with opening my safe
Our tech team at Quality gun safes wall safes and floor safes store in Burlingame Ca produced this video
Nov 04, 2014 | Sentry Fireproof Safe
Sandleford es20 safe won't open
Find something long & thin, I used a screwdriver. Has to be at least as long as depth of safe. There are 2 holes in the back of my sandleford ES 20 safe. Insert screwdriver into hole on left & push in until it hits the door on the other side. You have to do the next bit blind, but feel around for reset button. Once you find button use screwdriver to press. Lock will beep & you then just have to put your new code in. Problem solved. Of course this method only works if there is nothing inside the safe getting in the way of access.
Once inside remove anything valuable & find somewhere secure to keep it. This method took about 30 seconds to gain access. I'd hate to think how quick a professional thief could open it.
Mar 17, 2013 | Home Security
Dont remember password
password to your network?
well you can try accessing your router through your computer by plugging it in directly to your router with an ethernet cord. Once connected to your router. open a web browser and type in
192.168.1.1 or 192.168.0.1
one of the ip addresses should bring a dialog box up with a username and password field.
the user name can be
admin or user
password can be
admin or user or password.
try admin and admin first then admin and password then repeat with user.
once into your router you can go to wireless security settings and change your password in there.
Oct 18, 2012 | Computers & Internet
How do i unlock my safe with: Model number MSW 3110 Serial Number BK 706346 Dial Combination 23-93-59 Thank you. Dan.
3 Digit Combination Lock
31-10-31
  1. NOTE: If your safe DOES NOT have a key, skip Step 3.
  2. Turn the dial to zero.
  3. Insert your key and turn it until the plunger pops out.
  4. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
  5. Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
  6. Turn the dial to the left to the last number (stop the first time on your last number).
  7. Pull the handle down; the door should open.
3 Digit Combination Locks for Security Safes
31-10-31
  1. Turn the dial to zero.
  2. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
  3. Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
  4. Turn the dial to the left to the last number (stop the first time on your last number).
  5. Insert the key; turn right.
  6. Pull on the key while it's in the lock to open the door.
3 Digit Combination Locks for Gun Safes
31-10-31
  5. Pull the handle down; the door should open.
Electronic Locks
31-10-31
  1. Insert the tubular key into the lock to the left of the key pad.
  2. Turn the key all the way to the right until the plunger pops out.
  3. Press the five-digit factory code. The green Proceed light will come on.
  4. Pull the handle down; the door should open.
4 Digit Combination Lock
31-10-31-10
  2. Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the fourth time).
  3. Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
  4. Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
  5. Turn the dial to the right to the last number (stop the first time on your last number).
  6. Pull the handle down; the door should open.
You can find more information about your Sentry Safe at www.SentrySafeShop.com
Dec 01, 2010 | Safe International SentrySafe Home/Office...
My husband has passed and all of our insurance, house deeds and other important papers r in the safe. the x105. He handled things like that. but i must get to the life ins papers. I dont know where the key...
There is no override code. But maybe a override key the normal key is to open the bolt after the correct code is entered.
Cracked or drilled.
Call a locksmith to help.
Don't fall for the biggest add in the phone book a good locksmith could never afford a full page add and offer a good price.
Jul 18, 2010 | Sentry Large Security Safe - Safe - X105
Digital Electronic Security Safe S2120.
You will probably have to call a locksmith who specializes in digital safes, or you can contact hardline and give them the serial no. of the save and proof of purchase to get the code or key. You will probably need proof of purchase for the locksmith to.
Sep 18, 2009 | Kitchen Appliances - Others
Help me security code
Hi dude,
if u want mastercode for ur IMEI no., here it is 4323137111.
I have another trick to bypass the security code of NOKIA phones. But this trick works on some phone but dont work on some.
So try it, if works, it will be helpful for u .
Process:
1) When u r in desktop in normal mode. At that time, u can see "unlock" in left hand side of ur phone's screen.
2) Press & hold (left soft key + *) at once. Dont make difference of 1 sec also during pressing it. U hv to press them accurately.
3) If u have done it properly, u wil get a message "press * to unlock".
4) At that time, press * quickly and u will bypass the security code.
Note :- Try this several times since it is very tricky and u maynot be succeed in just a try.
Send me a feedback and rate my solution.
Be sure to post a clarification request for ur problem after it is solved.
SAJAN(sajwhat_2003@yahoo.com/sajwhat@hotmail.com)
May 13, 2008 | Nokia 6030 Cellular Phone
Security code for nokia 3110c
moz-screenshot-1.jpgmoz-screenshot-2.jpgHI dude,
to bypass the security, i hv got a trick.
When phone is locked by security code, there is unlock option at the left side of the screen above left soft key.
Press and hold left soft key and * button at once.
If u do it properly, a message "press * to unlock" appears. Press * quickly at that time n u will bypass the security code.
U should try it several times to success coz it is tricky.
Looking for ur kind feedback. Dont forget to Rate my solution too.
Be sure to post a clarification request after ur problem is solved.
SAJAN(sajwhat@hotmail.com/sajwhat_2003@yahoo.com)
May 05, 2008 | Nokia 3110 Cellular Phone
Sentry Fireproof Safe Logo
83 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
 Brian Main
Brian Main
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
