Question about Fuji FinePix A700 Digital Camera
I put the wrong ac adapter,now it won't work.
  • 797 Answers
OOPS.... that is not good. Just not what the doc ordered.
Try the right adapter, and see if anything will happens. If not, then try the battery. If that does not work, my friend, your camera is probably zapped, may not be worth fixing.Some of the internal electronics may have been fried or blew out, if the voltage was more than recommended.
If the voltage was lower, then the possibility of damage is less or none.
Posted on Sep 25, 2009
No power
Hello, If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems. 1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose Hope this helps
http://www.chargerbuy.com/laptop-ac-adapter/toshiba-ac-adapters.html
Nov 10, 2012 | Toshiba Computers & Internet
My fuji finepix s5000 has lost power
see this causes and proceed . God bless you
If the camera won't turn on, check the batteries, or connect the camera to an AC adapter. If that doesn't work, remove all batteries, disconnect the AC adapter, wait a minute, reinsert batteries and reconnect the adapter.
If the flash doesn't work, the camera won't take pictures, or the screen keeps turning off, check that the batteries are strong.
Oct 16, 2012 | Fuji FinePix S5000 Digital Camera
My Proform 900 wont work with batteries or ac adapter after I put wrong adapter in
Since you put Wrong adapter, possible dammed blown fuse. or tripped c.breaker inside. replace fuse or reset the c.breaker and Try again.
If this Does NOT solve the problem, you have a problem in the power supply faulty. Call some service tech for fix it.
God bless you. see the block d
Aug 03, 2012 | Exercise & Fitness
Hi, I have a inspiron 6000. 6 years old but works like a charm. Only problem now is the adapter won't charge [not an adapter issue as it works on other dell laptops]. And after the battery has...
Remove the battery and replace it, test. If this does not work, attempt to power on with the AC adapter plugged in and no battery in the system. If this works, you have a bad battery. If this does not work, watch the light on the ac adapter. If the green light goes out when you press the power button, something more is wrong with the system. Further information is desired. When you press the power button, do any lights on the system light up? Do the fans in the computer turn on? Does it make ANY noise? Finally, if available, it is desirable to try a different and known functional AC adapter.
Sep 17, 2011 | Dell Inspiron 6000 Notebook
Netbook charging indicator light won't light and battery won't charge. AC adapter works on other computers
Hope this helps...
Sep 15, 2011 | Gateway LT2021u Netbook
I was using a universal AC/DC adapter with my Boss MicroBR, and when I powered it on there was a small plume of smoke. Now it won't work with any AC adapter. I hate using batteries, because it drains a...
Rechargeable batteries CANNOT be used in this, ONLY alkaline batteries. Rechargeable batteries are ACTUALLY lower volltage (about 1.25 instead of 1.5) that is very near the cutoff point for operation so even fully charged rechargeables last only minutes. Sorry you used "universal" adapter because either you chose wrong polarity or too high a voltage and fried the internal voltage regulator. It is repairable by repair facility.
Jul 11, 2011 | Music
What polarity is the input on the ion IED04 DIGITAL DRUM STAION BY ION. I HAD TO GET A POWER ADAPTER AND DON'T WANT TO DAMAGE UNIT. THERE IS NO PICTURE TO NOTE POLARITY.
There is NO POLARITY to worry about since you MUST use an adapter that supplies 9 volts AC at around 850ma. You CANNOT use a DC adapter with this unit and have it work. Putting a DC adapter of 9 volts on it won't damage it, it just won't work.
AC output adapters are harder to find.
Apr 14, 2011 | ION Audio iED04 Desktop Electronic Drum...
Panasonic SDR-H18 connected wrong AC adapter
I accidentally connected wrong ac adapter and to Panasonic dvd camcorder and it will not turn on.....Hopefully this can be corrected??
Nov 25, 2008 | Video Cameras
Does Anyone know how to test Canon i860 AC Adapter??
Yes I know. put the adapter into the plug and switch on, and put the another side in a glass which contains water, then you can observe water avaporate or not. If water avaporate it is working otherwise it is not working. Just try and send me reply pnbab@hotmail.com
Nov 04, 2006 | Canon i860 InkJet Photo Printer
Fuji FinePix A700 Digital Camera Logo
212 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
