Question about HP EliteBook 6930p Notebook PC
Can't remember bios admin password, how do I reset?
    Sergeant:
  • 236 Answers
I think you have just remove your motherboard battery and try to boot your pc. I hope you will be able to use your pc.
Posted on Sep 25, 2009
4 Suggested Answers
sandrew
  • 2961 Answers
SOURCE: Reset bios on Toshiba A215
the only way to do this is to remove the cmos battery for 5 mins or so or short the jumpers on motherboard, battery way is easier
Posted on Aug 13, 2008
  • 2973 Answers
SOURCE: Need advice on how to reset admin password for
BOIS password can be done away with by removing the button cell on the motherboard for which you should remove the covers on the bottom of the laptop. Insert it after a few minutes and bootup.
Posted on Nov 09, 2009
shibuda
  • 1812 Answers
SOURCE: I forgot Admin password bios
There are several follow the steep.
Download the ISO file from =http://www.fullandfree.info/software/hirens-bootcd-v100/
Write the iso in blank cd
Boot from cd
DONT PANIC follow all the steep It is very simple Use the down arrow key.
1.INSERT CD TO CD TRAY
2.Boot from CD
FOR PASSWORD BREAK
3.Select start boot CD
4.Choice Password and Registry Tools>enter
5.Choice Active password Changer for (NT/2000/XP/2003/VISTA)ADMINISTRATOR PASSWORD RESET.
If you change the HDD PASSWORD, Select ATAPWD 1.2(HDD password Utility)
wait >all will be AUTO
HERE YOU can see the option 1.Logical drive and 2.Search for all HDD and logical.
If you have one HDD choice 1. Logical drive
You you Have More then One Choice search for all hdd.
Just Choice the no and put it on the Your Choice [ ] >enter
Now Choice the partition
Either "0" or "1" which is your active partion for your Operating System. If you have two "OS" in the same HDD,
should choice all.
If you have one "OS" choice "0" to "1" press the number .Generally would be "0"
Only the reason, every laptop has the option ,for one HDD.
So Choice "0" >enter
Follow the steep on screen text > enter
From here, you can see the option for Administrator or Users .
Generally Administrator will be "0"
So pres "0">enter
Press "Y" for save changes If you want to reset the users ac password
Should press "y"
Now pres any key, and choice for Users for "1" if you want. press 1>enter
Same as y and enter .
ctrl+alt+Del
Done , you can access.
Hope it will help you.
Posted on Dec 25, 2010
Bios password removal
Have you tried resetting bios to default? There should be a jumper on the motherboard that says CMOS default or BIOS default. It is usually 3 pins with a jumper across 2 of them. Changing the jumper to the other unused pin and center pin, labled default, should reset bios to default and remove the password.
Jan 16, 2014 | HP Touchpad Tx2-1377nr...
How can i reset the bios power-on password for hp 6720s ?
Do you want to know about bios power-on password reset on HP 6720s?
Turn to Reset HP BIOS/Administrator Password
It shows you how to reset HP BIOS password with SpareKey, and how to reset HP administrator password with effective Windows Password Genius in just 2 minutes.
Get a video learn how to use it:
http://www.youtube.com/watch?v=-vrVcFaUATg&feature=youtu.be
Mar 05, 2011 | HP Compaq 6720s PC Notebook
I forgot my toshiba bios admin password but i remember the user password Howa can I reset the admin password or remove it thxxxxxxxxxxxxxxxx
To reset the BIOS read the information from this link.
In case of your Toshiba laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Dec 10, 2010 | Toshiba Satellite P15-S479 Notebook
Bios password
try removing the cmos battery. power in on without the battery.
Jul 07, 2009 | IBM ThinkPad T21 Notebook
Vaio PCG7ZIL - CAN'T REMEMBER PASSWORD-HELP!!
Log into your computer as administrator to do this. Most likely the password is Administrator, Admin or something like that and the password will be either blank or the same as the user name 'Administrator' or 'Admin'. Once logged in as administrator you can change the computer passwords and users accounts.
Dec 16, 2008 | Sony VAIO PCG-K25 Notebook
My acer 9500 won't perform a recovery because it is having trouble finding the ghosterr.txt. when trying to change the location it cuts off/shuts down. i cannot otherwise log on to my computer at all. I...
Somehow, somebody has manually placed admin password for your bios. Thats the only way it can be done. Try this
Introduction to BIOS Passwords The best method to reset a BIOS password depends on what BIOS the computer has. Common BIOS's include AMI, Award, IBM and Phoenix. Numerous other BIOS's do exist, but these are the most common.
if (!window.netshel_ord) { netshel_ord=Math.random()*10000000000000000; } if (!window.netshel_tile) { netshel_tile=1; } document.write(''); netshel_tile++;
Some BIOS's allow you to require a password be entered before the system will boot. Some BIOS's allow you to require a password to be entered before the BIOS setup may be accessed.
The general categories of solutions to reset a BIOS password are:
  • Using a Backdoor BIOS Password
  • Resetting the BIOS Password using Software
  • Resetting the BIOS Password using Hardware
  • Vendor Specific Solutions for resetting the BIOS Password
Using a Backdoor BIOS Password Some BIOS manufacturers implement a backdoor password. The backdoor password is a BIOS password that works, no matter what the user sets the BIOS password to. These passwords are typically used for testing and maintenance. Manufacturers typically change the backdoor BIOS passwords from time to time.
AMI Backdoor BIOS Passwords Reported AMI backdoor BIOS passwords include A.M.I., AAAMMMIII, AMI?SW , AMI_SW, BIOS, CONDO, HEWITT RAND, LKWPETER, MI, and PASSWORD.
Award Backdoor BIOS Passwords One reported Award backdoor BIOS password is eight spaces. Other reported Award backdoor BIOS passwords include 01322222, 589589, 589721, 595595, 598598 , ALFAROME, ALLY, ALLy, aLLY, aLLy, aPAf, award, AWARD PW, AWARD SW, AWARD?SW, AWARD_PW, AWARD_SW, AWKWARD, awkward, BIOSTAR, CONCAT, CONDO, Condo, condo, d8on, djonet, HLT, J256, J262, j262, j322, j332, J64, KDD, LKWPETER, Lkwpeter, PINT, pint, SER, SKY_FOX, SYXZ, syxz, TTPTHA, ZAAAADA, ZAAADA, ZBAAACA, and ZJAAADC.
Phoenix Backdoor BIOS Passwords Reported Phoenix BIOS backdoor passwords include BIOS, CMOS, phoenix, and PHOENIX.
Backdoor BIOS Passwords from Other Manufacturers Reported BIOS backdoor passwords for other manufacturers include:
Manufacturer BIOS Password VOBIS & IBM merlin Dell Dell Biostar Biostar Compaq Compaq Enox xo11nE Epox central Freetech Posterie IWill iwill Jetway spooml Packard Bell bell9 QDI QDI Siemens SKY_FOX SOYO SY_MB TMC BIGO Toshiba Toshiba Remember that what you see listed may not be the actual backdoor BIOS password, this BIOS password may simply have the same checksum as the real backdoor BIOS password. For Award BIOS, this checksum is stored at F000:EC60.
The BIOS password can be reset on any system. Some systems are easy, others are more difficult. Any BIOS password can be reset with sufficient time, money and effort.
Dec 04, 2008 | Computers & Internet
Admin. password.
Its not ADMIN PASSWORD
It's Bios password!
And i can remove it but it will cost 200$
Nov 20, 2007 | Apple MacBook Pro Laptop Computer with...
Help clear bios
When you remove the battery from the motherboard wait after few seconds (30), reboot your computer without the battery and press the BIOS key (F1 or F10 or DELL key) will not ask you any password. Turn it off and Then put back the battery.
May 21, 2007 | HP (D5680-60001) Motherboard
HP EliteBook 6930p Notebook PC Logo
1,988 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
