Question about Kenmore Refrigerators
When I open and close the freezer door there is a gurgling sound
  • Kenmore Master
  • 1,606 Answers
The gurgling sound , is the vacuum being pulled thru the defrost drain line . Like when you close a freezer door , and you see the gasket being pulled in tighter . This gurgling , is the drain p trap with a vacuum being pulled thru it . Normal .
Posted on Sep 25, 2009
Freezer gurgles
    • Give it mouth wash lol
      Check the water valve on the back of the refrigerator if it has an ice maker. Make sure the valve is turned completely on and not constricting the flow of water to the refrigerator via the water supply line. You might also hear a simultaneous buzzing sound when the gurgling noise occurs. In some refrigerator models, this filling process is on a timer, and you might hear the buzzing and/or gurgling every 15 minutes or so.
    • Check the water supply line for leaks or damage. You might see a puddle of liquid on the floor. If air is pulled into the water line as the refrigerator is pulling in water, that can create a gurgling noise. Replace the damaged hose yourself, or contact an appliance repair technician for assistance
      • f he refrigerator to feel a slight vibration. This is probably the compressor processing the refrigerant, which is a liquid. This flow of refrigerant can produce a gurgling sound, and it is normal. However, a simple way to reduce this noise is to make fewer trips to the fridge. When you open the door, you let hot air in, which means the compressor has to work harder (and gurgle the refrigerant more) to cool things back down.
    • Wait while the refrigerator completes its defrosting cycle if you hear water dripping and gurgling in the freezer area. When the heating coil turns on, the melted water from the frost flows down to a drain pan for evaporation to take place. The defrost process usually takes about 30 minutes. This is automatic and cannot be prevented in most refrigerators. Keep the closed to try to prevent unnecessary frost buildup.
    • Wait while the water equalizes in the refrigerator if you hear a gurgling sound when shutting the door. This is normal and is a result of air being forced through the drain tube. The gurgling can last several seconds but should eventually dissipate this usually happens with old fridges upgrade its a good investment
Dec 10, 2013 | Freezers
Our Thermador Freezer door seals so hard after being opened that you can't open it again. Why? Also Sometimes after opening it makes this weird gurling/bubbly noise.
thermodynamics: pressure differential when warm air cools causing a difference in pressure. after closing a freezer wait until the pressure equalizes usually within 10-15 seconds then reopen the freezer. as far as the gurgling this is normal. it is the drain tube usually a J type tube that prevents warm air from returning into the freezer.
Jan 15, 2013 | Thermador Freezer FREEDOM® T24ID80PLS
My brand new Beko frost free fridge freezer makes a loud gurgling noise and sounds like water trickling inside every time the fridge door is opened then closed again, regardless of how long its open for....
mINE IS DOING EXACTLY THE SAME - I'VE HAD IT ABOUT 2 WEEKS BUT ONLY STARTED MAKING THIS SOUND TODAY AND AS YOU SAY ONLY WHEN THE FRIDGE DOOR IS OPENED AND THEN SHUT!
Oct 08, 2010 | GE Profile 20.7 Cu. Ft. Side-by-Side...
Door was left very slightly open. reclosed but so...
This is normal when compressor starts u can hear some gurgling from evap. from feron flowing. If you hear gurgling only when you close the door it's water in drain pan when you close the door air is forced down drain tube blowing air into water.
May 17, 2010 | Freezers
Unit runs continually with gurgling sounds
defrost fully once a year or more if you notice it frosting up.it should run at minus 18c to 20 c for best results. 0f is fine.gurgling noise is normal (liquid turning to gas before compressor turns it back to liquid).make sure door seals all round and the kids close the door asap after use......also if you portion up food prior to freezing and vacpack it it will last longer.and be easier to store/rotate.
Feb 17, 2010 | Frigidaire 15 cu. ft. / 425 liter Chest...
Rattle and Gurgling noises
It's the fan bouncing off the fan-motor housing. The best way to stop this is to shim the motor mount so the fan will ride with the motor shaft "out" preventing it from bouncing. When you raise the fridge on one corner you are doing the same thing the shim will accomplish.
The draining gurgling sound is probaby freezer defrost water being pushed down the drain tube into the drip pan at the bottom. The door action pushes/pulls air in the tube and pushes out water.
May 27, 2009 | Refrigerators
My refrigerator gurgles when the bottom freezer door is closed?
Air is stabilizing between the fridge and freezer.
Do not worry.
Mar 11, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Sub-zero 650 makes loud gurgling sound
gurgling is not unusual and is caused exactly by fluid bubbling thro a pipe.
Nov 04, 2008 | Sub-Zero 650 / O Bottom Freezer...
Gurgling noise
gurgling noises are not unusual - after all there is a gas/liquid mixture being circulated
Sep 04, 2008 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
993 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
