Question about Intel Desktop Board D815EEA2 Motherboard
Video Ok.. When I turn on my computer it boots up just as if the video was working problem is it is not I've tried switching out video cards still nothing tried the onboard to but still nothing so please help me. (It could be the battery but I just replaced it)
    Genius:
  • 1,226 Answers
Disconnect all power cord and also video card. reconnect it again using on-board video card. reset your motherboard. find jumper near the battery read info on it by resetting( you can do that by switching on for a seconds). and then switch on then press F2 or Del to enter the bios configuration. Load system optimized default(something like that.) and then save and exit. when computer boot up in this setting your in your way. but if not then, fixed any memory attached may be lessen. when it is successful your glad using your on-board video adapter/card.
You can either use your add on Video card.( be sure that you add on card is functional.) shutdown the computer then attach the add on Video Card. Do not transfer yet the monitor connection from the on-board. switch on the computer press again F2 or Del to enter bios setup(note: your using onboard on this) If your in the bios, find an option "AGP bridge configuraion" (find in advance and then chipset option) on primary graphics adapter (select AGP or PCI) and then press F10 to save and exit. may solve your problem.
Posted on Dec 17, 2007
    Problem Solver:
  • 18 Answers
Sorry to say, but I just can't understand youre grammar. Maybe you need to put some marks on your sentences such as comma to specify thought.
Anyway, based from my understanding to your problem, your computer tries to boots but you cannot see anything on the screen(I hope this is what you really mean)..
And you have already tried switching video cards, so maybe you have plenty of video cards there. Hmmm.. so if you have already make the swithching technique, that should have solved the video problem, unless all your video cards is not working.
Why dont you try to connect your video plug to the onboard graphics(this is the motherboard plug for your video device). If its still not working there, then there must have been a problem on your motherboard, since you have told that it boots up and has a beeping sound. Maybe the onboard graphics is already not workiing.
Disable onboard video card on dx4870 ub318
enter your Bios then Advanced settings there should be an option to turn of onboard graphics or switch to pci..
Dec 27, 2012 | Gateway Computers & Internet
Asus crosshair socket am2 motherboard not booting
Sounds like your monitor is bad. Try another monitor because if the video card was bad and the monitor is working you would get a No Signal message on the screen. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok, then your original monitor is bad. If the Borrowed monitor does the same as your original monitor and does not display anything, then there is an issue with your video card.
May 13, 2012 | Computers & Internet
Acer ax3400g does not boot and light blinks twice
Either your memory, lcd monitor or the video card is bad.
Check the Memory by steps below:
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
I'm thinking that it might be your monitor because if the monitor was working and the video card was bad, you would get a No Signal message appearing on your screen.
Try another monitor on the computer. Borrow a monitor from a friend, family member, neighbor or co-worker and see if it works. If it does then your monitor needs to be replaced. If it does not work, then you've got a video card issue.
Check Video Card below:
If nothing ever posts to the screen then more than likely your video card is bad. Go purchase a Video Card that will fit into one of your open PCI Slots.
May 12, 2012 | Acer Aspire AM1640-U1401A Desktop PC
How do i get my asus model ul80j to switch from integrated graphics to nvidia
From my years of working with computers most of them only work with one video card at a time. If you have two video cards on the computer and if you have them both connected, a lot of computers get confused and can't handle that.
I've seen computers where there is a VGA Port (that normally comes with most computers) and the user goes out an purchases some heavy duty graphics video card and installs it. When they try use the VGA port, the computer refuses to switch to it as long as that other video card that they purchased is in the computer.
I've down countless of house calls to repair a computer where the purchased video card has gone bad and the customer thinks they are up the creek without a paddle until they get a new video card. Not so, I just remove the bad video card and plug into the vga video port that came with the computer.
Mar 30, 2012 | ASUS UL80JT-A2 Notebook
Dell Dimension 5100 will not power up. Was working fine, turned power off, will not turn back on. Power supply tested OK, tried different power switch and ribbon cable connector, replaced mother board...
Have you checked your monitor? Try your monitor on another PC and check it is OK. Once you change the MB battery you effectively "Kill" the PC, as all the settings in the BIOS are removed and must be reprogrammed. You must enter the BIOS, and select "Default" setup and then reboot, you must do this regardless of what else is done first.(A bit hard when you can't see anything" You say... "tried different power switch and ribbon cable connector" (sic) exactly what "Ribbon cable/Power switch"? Anyway as said check monitor, if it is OK, we will proceed from there, then, you must check your video card, test it in another machine, if possible, to see if thats OK, if it is OK, then it is now likely that you may have a Mother board problem. If you can, try another Video card to see if you get Video on screen. see we need to establish "Known Good" items, once we know whats what, we can then go on. Now if any of these things tested are faulty, Monitor, Video card, obviously replace them, however IF they are NOT faulty, as related it may be the Motherboard, Remove the RAM, and see if anything is on screen? If yes, replace RAM, If still NO, then take any cards out, and check, if then OK, replace cards one by one until you get to the one that stops it, there is your problem, replace it. All we are trying to do is get anything on the screen, if we do, then you must redo the BIOS, as related before. Now if you get it going it still may not boot through to windows desktop, if this is the case, after you boot press F8 and select safe mode, when you get asked if you want safe mode or system restore, choose system restore and choose a date before you had a problem that should get you back. You just have to logically work through, until you find the faulty "bit" and replace it.
Feb 22, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
My video card stopped working. i changed the video
maybe it is your motherboard, reset bios ... because you can see anything do as it follows , unlupg power coard-open case - pull out little silver battery- wait 10 sec-put it back in- switch power cord and start your computer.. that will reset your bios. cmos more exactlly... if you see the boot menu it is ok.. but if you can go to os.. then you must set you bios video output to pci... try and write back
Feb 20, 2010 | Gateway GM5260 PC Desktop
Monitor won't start when I boot up - without a lot of fiddling!
First try to do monitor self test.Disconnected the blue cable VGA or white colour connector from monitor to the computer. Turn on the monitor and check if you are able to see colours or line on the monitor.Indicating self test monitor is working fine. If you are using Video card on computer connect monitor directly to onboard video and check. Good Luck.
Aug 19, 2009 | Computers & Internet
Monitor says "Check signal Cable"
lilsidetrack -
An obvious cause is that your video card may have taken a dive on you, and it needs to be replaced. If you don't "see" anything on boot up, but what you hear sounds like it's booting, your video card has probably gone bad.
Another possibility is that your video card's settings got changed accidentally, and it's not sending the proper signal to the monitors you've tried. Try booting into Safe Mode (if you have a Windows OS). This loads only the most basic drivers, and if it successfully enters this mode, indicates that your video card is probably OK, and setting might be the issue. Press "F8" during boot-up to get the boot menu, and choose Safe Mode.
You don't say what kind of card or monitors these are. Does your video card have a "TV-OUT" or "S-Video OUT"? If so, the video card is probably set to output to one of these other sources, and not to the monitor. Once in Safe Mode, you can go to you video settings and be sure they are set correctly.
Thanks,
videoman7
Aug 14, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Blank screen on AL 2223W
When you switch on the computer and monitor does the monitor power light illuminated?
If not check the power cable, if the power light is on try connecting it to another computer, if it works on another computer then the fault is in your computer or a faulty video cable (try another video cable).
If the monitor does not work then it is faulty, if it is OK then your computy is faulty.
If the fault is in your computer, you didn't exactly pinpoint the nature of your fault.
Does the power light on your computer illuminated when you power up?
Does your computer actually boot up, does it give and beep code (count the number of beeps - 7 beeps usually means video problems, depends upon the type of BIOS)?
When your computer first boots up and you see POST information on the screen then nothing, it is most likely :-
1. The refresh rate of the video card has been set too high beyond the monitor's specification.
2. Video card configured with incompatible monitor.
If you computer fires up and the monitor is OK the you have a faulty graphics card, you need to replace it.
Nov 12, 2008 | Acer Monitor
No any video signal from the video card
When you power on your computer do you hear any system beeps from the PC speaker? When the computer is turned on it will run through a system check and one of the things it checks for is the presence of a working video card. One beep typically means everything checked out ok and your graphics card is working and it will continue to boot. If you are getting past that initial test I would next look at the monitor and see if it can handle the signal that is being sent to it. Are you not getting any of the boot up text display?
May 31, 2007 | Gigabyte ATI RADEON X550 , (256 MB) PCI...
Intel Desktop Board D815EEA2 Motherboard Logo
57 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
