Question about Nintendo DS Lite Console
Inverted colors on botton Nintendo DS screen
The lower screen of my Nintendo DS works fine, but it displays all in negative colors (like old 35mm. cameras films). Any ideas?
5 Suggested Answers
SOURCE: nintendo DS bottom display screen
Hi I have a problem with my bottom screen as well. I was replacing the case as the hinge was broken. When i was putting it back together i noticed a slight tear in the ribbon cable which is attached to the board and the bottom screen.
When I turned it on I found I had poor colour and contrast in the bottom screen however the top screen was fine.
Where this ribbon cable is attached to the board there is two small cables attached to the board beneath it, maybe one of these has come away and needs repositioning or your bottom screen needs replacing.Try this site for diy tipshttp://site.powergamingparts.com
Cheers Chris
Posted on Oct 28, 2007
  • 19 Answers
SOURCE: my nintendo ds lite top screen isn't working properly
Top LCD's flex cable that passes through right-hand hinge into bottom part of case will be damaged or not properly seated in its connector socket.
Posted on Jan 01, 2008
SOURCE: Nintendo DS lite - dropped
Might be worth taking it into a phone repair shop to see if they can replace the LCD screen. (yes, a phone repair shop - a lot of them do portable console screens too!) If they can't do it, it's probably unfixable realistically.
Posted on Mar 27, 2008
support146
  • 90 Answers
SOURCE: my nintendo ds top screen's color is off. It is
Unfortunately this is coming to be known as the "Green Screen of Death"... It is likely one or more of the components that create the image on the screen are damaged. This usually occurs if there has been an impact -- such as being dropped or hit -- to the Nintendo DS's screens. Your Nintendo DS system will need to be repaired.
You can give Nintendo a call at 1-800-255-3700 or contact them via their website:
http://www.nintendo.com/consumer/webform.jsp
Hope this helps!
Posted on Nov 28, 2009
What type of film does a n60 slr camera use
The N60 uses standard 35mm film (also known as 135). 35mm film usually comes in 12, 24, or 36 exposure rolls, any of which will work. 35mm film is available in black-and-white, color transparency (color slides), and color negative (color prints). It's also available in infrared, both color and black-and-white, but the N60 will not work with infrared film.
35mm film is available online and at any camera shop. Many department stores, drugstores, and even supermarkets also carry film, though not as wide a selection as a decent camera shop.
Oct 11, 2014 | Nikon N60 35mm SLR Camera
Is it possible to get 35 mm film for camera?
Any camera store will carry 35mm film, color or black&white, transparency or negative. A narrower selection will also be available at many department or drug store, as well as some supermarkets.
Dec 07, 2013 | Minolta Maxxum 7000 35mm SLR Camera
Which film in nikon f3?
The Nikon F3 uses standard 35mm film, also known as 135. The type of film you use is up to you. You can use black&white film, color transparency (color slides), or color negative (color prints). Prints are generally cheaper than slides but slide films generally produce better results, and prints can be made from slides. You can also make black&white pictures from color films, though obviously you can't go the other way.
These films are available in a variety of speeds. Faster films let you shoot in lower light and/or with a faster shutter speed for stopping action, but slower films have finer grain. Different films also have different color properties. No film (or digital sensor, for that matter) reproduces every color exactly. You may need to experiment in order to see which film gives you the colors you like for the types of pictures you like to take.
Dec 17, 2011 | Nikon F3 35mm Film Camera
What size film is used in this model
It uses standard 35mm film, also known as size 135. You should be able to buy black-and-white, color negative (print), and color transparency (slide) film at any camera store. Many drugstores and supermarkets also carry film, though usually a smaller selection.
Jul 12, 2011 | Jazz 506 Point and Shoot Camera
What film do you use for a canon af-7s
The Sure Shot AF-7 is a 35mm camera. That means it uses 35mm film (sometimes known as size 135). You can use black&white film or color film, either slides or negatives (for prints).
You may download a copy of the manual here.
Jan 28, 2011 | Canon Sure Shot AF-7S 35mm Film Camera
Is there a manual available for the Fuji Discovery 1000 Zoom camera? Also, where can one purchase film for this camera.
You can download the manual at
http://www.cameramanuals.org/fuji_pdf/fuji_discovery_1000_zoom-1.pdf
The camera uses standard 35mm film. 35mm film is available in black-and-white, color negative (print) and color reversal (slide) forms (and others). 35mm film should be available at any camera store, as well as many drugstores and even supermarkets.
Jan 09, 2011 | Fuji Discovery 1000 35mm Point and Shoot...
What types of film can i use with my nikon f80?
You can use almost any 35mm (size 135) film available. Black&white, color negative (print), color transparency (slide). The only restriction is that you can't use infrared film since the camera uses infrared light internally. Any brand will work, as the film size and cartridge are standardized.
Sep 28, 2010 | Nikon F80 35mm SLR Camera
I don't know how to buy film for this camera. is it just 35mm 400 film
Yes, you can get 35mm in color negative or black and white. Although the black and white film may be in 2 varieties: traditional process black and white(not all labs can process this) and C-41 process black and white (and one hour lab can process this). If you are looking for color film choose the C-41 color negative film like Kodak gold 400 or Fujicolor 400.
Mar 28, 2010 | Nikon N65 35mm SLR Camera
Maxxum camera no color
I think your camera had a microchip in it that changes modes. I could be wrong, I can't remember exactly what model it was. Take the chip out or reset it in the menu. How old is the film you are using? There is some film that is color film but a black and white emulsion. That can be developed in color processing.
Jan 04, 2009 | Minolta Maxxum 300si 35mm SLR Camera
Negatives were in "widescreen"
The camera has a panoramic switch on it somwhere that caused a pair of baffles to close down over the film exposing only the center 1/2 of the film. The idea is that the print from this negative would be printed as a 4x11.5 inch photo. It's basically a 8x11.5 with the top and bottom of the print chopped off.
The only other alternative is that for some cameras had a panoramic adapter to place inside the film chamber, but that would be a very difficult thing to do inadvertantly.
Cheers.
Feb 07, 2008 | Samsung SR4000 35mm SLR Camera
Nintendo DS Lite Console Logo
220 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
