Question about MSI Wireless-G RG54G3 Router
Problem with closed ports on router rg54g3 i tried forwarding the ports and turned off my firewall and still no good any ideas?
  • 4,338 Answers
How do I turn off wireless security?
  • Disable the fire wall by logging in to the administration interface of your router and looking for a firewall section. The administration interfaces differ depending on the manufacturer and model, so your wireless router might not have a firewall section. If it does, click on that section and turn off the firewall.
  • 2
    Forward a port. If the firewall is preventing an external computer from connecting to your internal client, you will need to forward a port to your client.
  • 3
    Find your internal IP address.
  • 4
    Click on "Start -> Run..." and enter "cmd" into the box. When the command-line pops up, enter "ipconfig" and hit "Enter." Find your IP address in the statistics that are printed out.
  • 5
    Refer to your software's documentation to find which port number must be forwarded.
  • 6
    Log in to your router's administration interface.
  • 7
    Click on "Port Forwarding" or an equivalently named section. The name of the section will differ depending on your router's manufacturer and model.
  • 8
    Add, on the correct port, a forward to your IP address. You will have to update this port forward in the future if your IP address changes. If your IP address changes often, ask your network administrator for a static IP address
  • Read more: How to Disable a Wireless Router Firewall ' eHow.com http://www.ehow.com/how_2091716_disable-wireless-router-firewall.html#ixzz14HV1mYNW
    Nov 04, 2010 | Arris SURFboard SBG900 Wireless Router...
    Can't download forward or reply on my email ?
    it could be a virus or some setting.. it's unlikely it's your router unless you disable or closed ports like 110 which is pop3 server port.
    I would suggest to make sure you're virus free first (which is a most) and then try to do a restore with a previous restore point. also check your firewall and make sure your email client is configured as an exception.
    if you did change something in your router, check the firewall configuration and if you dont remember what you changed, just reset your router to defaults. You may need to reconfigure wireless security after that
    good luck!
    Dec 26, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
    Dose this router work as a firewall switch?
    It is not possible to close all the ports on the router.
    you can open other ports.
    by default port 80 is open on the router.
    On the router there is no such setting to close the port.
    Oct 06, 2009 | Linksys Wireless-G WRT54G Router
    No matter what i do, ports will not forward
    you have to TURN ON both FIREWALL AND NAT, and then configure the nat forwarding + firewall rule and then it will work
    it's a known bug @ zy boxes
    Aug 15, 2009 | Zyxel Prestige 660R Router (91004397002)
    Can not hock up my Xbox 360 to router
    you will have to get the port numbers from them and setup port forwarding in the router
    Jan 11, 2009 | MSI Wireless-G RG54G3 Router
    Standard username and password
    hello!
    By default the router username is admin, and the password is also admin
    Jul 03, 2008 | MSI Wireless-G RG54G3 Router
    Lost instruction
    Most of the Router user name and password will be admin and admin try this
    Jun 22, 2008 | MSI Wireless-G RG54G3 Router
    Help with my router
    You did not have this problem before because port forwarding was set on the previous router settings, or you were using a modem ( no firewall) .
    Here are instruction for port forwarding
    Here are more instuctions
    One last thing, if your computer is powerful enough (1gb memory would be good), use Azureus, is much better.
    Jun 08, 2008 | Linksys Wireless-G Broadband Router
    TEW-452BRP - can't open a port (forward)
    I had the same problem.. the router did forward another port for me (port 12345) so i just set the port for uTorrent to 12344 and it magically worked... i'm not sure why but i would try setting the port to a lower range
    Feb 23, 2008 | Trendware TEW-452BRP Wireless Router...
    MSI Wireless-G RG54G3 Router Logo
    73 people viewed this question
    Top MSI Computers & Internet Experts
    vsri9
    David
    David
    Matthew Spark
    Matthew Spark
    Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
