Question about IBM Computers & Internet
IBM thinkpad cec1 stop post task
IBM thinkpad crc1 stop post task
  • 797 Answers
Let's see what we can do with this one.
It seems you are saying the laptop hangs while trying to boot, and seems not to get that far, that is to the boot stage.
Shut the computer off, and remove the power wire and battery...OK... remove any cards, and remove all memory sticks. Now plug the computer in and turn on the power.. see what it says, if anything. The correct message should be something about no memory installed.
If that message appears, then you can suspect some problem may be with the memory. If you have more than one memory stick, put one in at a time and check to see what the computer does.
There are programs you can download and put on a cd or floppy disk to test your memory sticks. These are free for the downloading.
There are diagnostic free programs to test the rest of the computer, with self-booting programs to put on a cd. These can test your computer.
If all fails, then you may have a bios problem.
Reset the bios by shorting the jumper (on a laptop, this may be harder to get to) on the bios. This will reset the bios to default.
See what it does... if still same problem, then repair is in order or sell as parts...part out, what ever.
Posted on Sep 25, 2009
ERROR 0175: bad crc1, stop post task
0175: bad crc1, stop post task ,ibm t20
Jan 16, 2011 | IBM ThinkPad T20 2647 Notebook
MY laptop beep twice and flag error code Bad CRC1, stop POST task
sounds as if one of your memory modules is defect.
CRC stands for Cyclic Redundancy Check and is a form of checking the memory.
If you have two modules inside, take on out and see what happens.
Best regards
Manfred
Dec 07, 2009 | IBM ThinkPad T20 2647 Notebook
Post problem
If it beeps (which it should) means that some device did not pass post. Find your motherboard online and look up the beep codes. This should help you to discover the problem. I hope this helps!
Jul 15, 2009 | IBM ThinkPad A21m 2628 Notebook
Error 0175 bad crc1
Numeric error codes - ThinkPad General From IBM Web Site
Notes:
· The most likely cause is listed first.
· A numeric error is displayed for each error detected in POST or system operation.
· In the displays, n can be any number
Error code
Symptom or error
Field replaceable unit or action, in sequence
0175
Bad CRC1, stop POST task. The EEPROM checksum is not correct
This problem you may not be able to fix. There are a couple of things you can try.
1st Keep on rebooting your laptop until this error goes away.
2nd Replace the BIOS battery, it maybe nearly worn out. After replacement you need to go into the BIOS setting to set the Date & Time.
System board
May 16, 2009 | IBM ThinkPad T20 2647 Notebook
Error 0175 on boot IBM Thinkpad T20
Error code Symptom or error Field replaceable unit or action, in sequence 0175 Bad CRC1, stop POST task. The EEPROM checksum is not correct. System board
Mar 27, 2009 | IBM ThinkPad T20 2647 Notebook
0175: bad crc1, stop post task, system bios shadowed
Go on tis forum and post your problem. There is also the Lenovo forum. I have a T23 and haven't seen this error before. These Forums are very good for information on your laptop.
http://forum.thinkpads.com/viewforum.php?f=28
http://forums.lenovo.com/lnv/board?board.id=T_Series_Thinkpads
Oct 02, 2008 | IBM ThinkPad T20 2647 Notebook
While booting error " bios shadowed " & 0175: bad crc1, stop post task
sounds like cmos battery flat small battery inside pc to retain cmos setting when pc switched off
Stop POST task, bad CRC1 error 0175
There are a couple of possibilities, go to this link for the solutions, but it could be a bad power supply http://www.hardwareanalysis.com/content/topic/31761/
Aug 07, 2007 | IBM ThinkPad A21e 2628 Notebook
Computers & Internet Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
