Question about Linksys Wireless-G WRT54G Router
I have a linksys wrt310N router with wap2 (personal) security setup..i have a work provided laptop with vpn ..setting up work laptop to recognize new wireless router..intel setup programwants 6 digit numeric device ownership password...my password for router is alphabetic and my wap2 code must be 10 digits by default..help!
  • 59 Answers
U can add the network manually ...
In Intel pro set u can go to profile and do the things there ...
Posted on Sep 25, 2009
How do i recover a wep key for a cisco router model wrt310n and thanks
WEP keys are created by the user in the setup or in the security setting inside the router.
You will want to enter into the router via the ip 192.168.1.1 for this model
and check the "key renewal" instruction for the WPA pass-phrase.
this is where you do changes for router security. This pass-phrase is usually 63 characters.
Here are some additional instructions:
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP a dresses.
5. Set the laptop up in the router by WPA KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Jun 18, 2010 | Linksys Computers & Internet
We have windows 7 ultimate on a hp pavilion du 7 laptop, coupled to a linksys wr310n router.It was working fine until our c drive crashed & had to replace , now we can't get the router to work , driver...
For the WRT310n, back to the User Guide (download from Linksys), perform a reset and start over following setup instructions (make sure the router is hardwired to the laptop). Set up a new home network on the laptop using Control Panel. Make sure the adapter settings are correct and good to go. Then see if you can connect to the router with your browser to set it up. After setup, you should be able to connect to the router wirelessly from the laptop, but you have to make sure the wireless transmitter inside the laptop is turned on first (see the laptop user manual).
Jul 05, 2017 | Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT...
3 failed attempts to connect HP DV6t laptop
First as a test, turn off the wireless security, and see if the laptop can connect.
If it can connect with security turned off, then it is likely that you are making some type of mistake with the password. (Such as caps lock being on, or having a keyboard error.)
Good Luck!
Jan 03, 2010 | Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT...
Used to be able to connect using WRT310N
You should call Linksys tech support now. The router needs to be configured manually. The tech that you hired maybe not familiar on how to configure the Linksys router.
Jun 25, 2009 | Computers & Internet
Reset admin pw on Linksys RV042 VPN Router?
unplug router on the back is a reset hole use a pen or paperclip and press for 30 seconds this will set the unit back to factory settings
Default IP: 192.168.1.1
Username: Admin
Password: Admin
http://www.smallnetbuilder.com/content/view/30186/51/
Apr 16, 2009 | Linksys RV042 VPN Router
Lg r 405 will not recognize wireless signal from lynksys wrt350n
hi i would suggest to access your routers setuppage and set the channel to channel 11.
make sure also if your wireless network is secured, type the correct key those things are case sensitive.
to access the routers setuppage go to a computers that is connected to your linksys router (wired) then launch IE on the address bar type 192.168.1.1(this is the routers ip) then it will ask you for username and password for the username dont type any thing for the password type admin.
when your on the setuppage click on wireless tab. while on the wireless page set the channel to 11.
after that click apply or save settings on the page.
then after that try to connect to your wireless network on your laptop.
for further help you can call linksys hot line 1800-3267114
they will surely help you with this.
hope this helps.
Oct 19, 2008 | LG X-Note LM50 Notebook
Cannot get Internet connection with my new Linksys WRT310N wireless router
Power cycle modem and router. Check if getting wan ip address on router. I yes. Enter static DNS on router or on computer
Aug 19, 2008 | Linksys Computers & Internet
I can only connect thru my router when hardline connected. Cannot connect thru wireless. wrt310n router
On the computer wired to the router.
1. Open an internet explorer browser
2. Go to 192.168.1.1
3. Leave the user blank then "admin" for password unless you changed it.
4. Go to the wireless tab Check the wireless settings If the Wireless network name is Linksys change it.
Cilck save settings.
Go to the subtab wireless security.
Change the security to WPA Personal
then for passphrase put in a password 8 chars or more.
Click save settings.
5. On your computer use the wireless connection to connect to your network name then enter your password
If that does not work or if you have difficulty with the directions just call linksys support 8003267114
Aug 18, 2008 | Computers & Internet
VPN passthrough
What are the settings that you have for your netgear router? Its going to tunnel, right? Try this solutions and see it will work.
1. Access the set-up page of the router, from a browser, type 192.168.1.1
2. Go to VPN tab and select IP SEC VPN
3. Local Security Group, set it to subnet and input the Network Address of the router (LAN IP - 192.168.1.0)
4. Remote Security Group, set it to subnet and input the Network Address of the netgear router (LAN IP, for example - 192.168.2.0)
5. Remote Secure Group, set it to IP only, WAN IP address of the netgear router
6. For Key Managemnt, just make sure that all settings are identical with the netgear router
7. Last go to Advanced Settings and make sure that group settings are identical to the netgear router
Hope it works for you
Jun 24, 2008 | Linksys RVS4000 Router
I cant get my new wireless N linksys WRT310N router to work
First reset the router by pressing the reset button for 15 seconds and after resetting it run the setup CD fo it to reconfigure the router, if you don't have the setup CD better contact Linksys tech support number and let a tech walk you through in manually configuring the router, this is the number for Linksys 800-3267114...........
Jun 18, 2008 | Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT...
Linksys Wireless-G WRT54G Router Logo
671 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
