Question about Westinghouse LCM-22w2 Television
Monitor won't turn back on
I cut my monitor off last night and it will not turn back on unless i unplug the power cord and video cable. then when i turn it back on it cuts off when i replug the vga cable.
    Problem Solver:
  • 5 Answers
You should either check the cable you are using and possibly the ports on the monitor, if these both seem to be ok then it is probably your capacitors or a loose connection in the monitor. Also could be that your computer is not powering it up, so when you plug it back in make sure your computer power is off and then reboot otherwise it may not wake it up. More than likely the capacitors are going out, and it is still coming on shortly because they actually can hold a charge and they may not all be bad.
Posted on Sep 23, 2010
What cords are needed to connect my emachines windows 7 desktop computer?
  1. CPU Power Cord
  2. Monitor Power Cord
  3. Monitor video cable
  4. Mouse w/cable (unless wireless)
  5. Keyboard with cable (unless wireless)
  6. Network cable with 8P8C connectors (unless wireless)
  7. Speaker audio cable (unless internal or no speakers)
  8. Speaker power cable (unless CPU powered or no speakers)
Oct 22, 2015 | eMachines Computers & Internet
Tip
How to create a Xbox live ID
<ol> <li><br /> <p>With your xbox turned off unplug the ethernet cable from the back of your Xbox.Next unplug the xbox 360 power cord from the back of the Xbox 360.<br /></li> <li> <p>Unplug ethernet cable<br /> <p> and power cord from the modem. Wait for about 1 minute and then plug ethernet cable back into the modem.Now you need to plug other end of the ethernet cable into the back of the Xbox 360.<br /></li> <li> <p>Plug the modem power cord back into your modem , wait for lights to light up on your modem (this can take up to a minute).The last step is to plug the Xbox power cord into the back of the Xbox, turn it on and you are ready to go<br /></li></ol>
on Dec 06, 2010 | Microsoft Xbox 360 Console
Last night I cut my computer off and it froze on the shutting down screen so I held down the power button and it cut off. Now when I cut it on the light on the monitor is orange. It's Gateway 817GM. Help?
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Jun 27, 2014 | Computers & Internet
HP LP3065 monitor turns off and won't turn back on; is this a Windows problem
It doesnt sound like a windows problem. A simple test for this is to unplug the vga or hdmi cable from the monitor then turn it on if it has power it should say no signal. Also try either another power cable to the monitor or change the fuse. Hope this helps.
Oct 19, 2012 | HP LP3065 Monitor
Monitor SAMSUNG 961BF does not turn on no picture?
  1. Verify that the power cord and Monitor cable are securely connected and not damaged. Unplug and replug these cords back in and test functionality.
  2. If the monitor still ceases to function, you may have a bad board, lcd screen, or inverter.
  3. I recommend replacing the monitor unless you are familiar with testing and replacing electronic boards and LCD screens.
Sep 12, 2011 | Samsung SyncMaster 961BF 19 inch Monitor
After using the television with the VGA cord from my computer monitor to the television it became unresponsive. Both remotes did not work and neither did the controls on the television itself. The tv was...
I had the same issue, the only solution I have found was to unplug both the VGA cable and the audio before turning it on, then plug them both in after you switch the input to VGA. Kind of a pain, but it works. Am still looking for a better solution though.
Feb 12, 2011 | Polaroid FLM-323B Television
My emachine desktop monitor keeps cutting on and off by itself. What should I do?...it's really aggravating.
There are three possible reasons for the issue:
1. Monitor power cable is loose
2. Video Adapter is faulty
3. Monitor capacitor is gone bad
Please try the below steps to diagnose the issue:
1. Check the power cable on the back on Monitor, if connected properly, like connect the power cord on a different Wall outlet
2. Unplug the signal cable from the video adapter and replug it. Also, check a different monitor (if any) on the Tower.
3. If the above steps fails, then the issue is with the monitor, it is going for repair.
Thanks and regards,
Jitha
Nov 23, 2010 | Computers & Internet
Monitor dead
Check your power cables properly and make sure it is attached. Check your power button, maybe you have pressed the wrong one.
Jan 03, 2010 | Acer AL1916W 19" LCD Monitor
E-machine was working fine last night got up and it turns on but the monitor says check cable or power but all is ok.Computer wont display anything, can anyone help?
Do a reset: Turn the computer and monitor off. Unplug the monitor video cable from the computer and unplug the monitor power cord from the wall outlet. Let it sit for 5 or 10 minutes. Plug everything back in, turn on the monitor, then start the computer. Sometimes that will work.
If you still have the same problem, try to borrow a known to be good monitor from somebody. If it works, then you know your monitor is bad.
It's also possible that your video circuitry is bad. If the monitor plugs straight into the motherboard (onboard video), then you'll need to purchase a video card and install it. Disable the onboard video first.
Feb 25, 2009 | E-Machines (T2958) PC Desktop
When I turned off my monitor last night, it was fine. When I turned it back on this afternoon, all of the colors were darkened and discolored. It looks like my contrast was change, but it wasn't, since no...
is this an lcd flat panel monitor or a crt? if it is a flat panel then you may be dealing with blown capacitors on the vga board inside. they can be replaced therby repairing the monitor. if it is a crt then just recycle it and buy a newer lcd monitor to replace this old one.
Jun 19, 2008 | Computers & Internet
Westinghouse LCM-22w2 Television Logo
103 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
