Question about HP DeskJet 5650 InkJet Printer
Warping of the Image
Two days ago the images and text I printed from my HP 5650 Ink Jet began to warp, to bow outward on one side of the page. We were just on the verge of printing out all of our holiday cards so this is very frustrating.
It is less noticeable on the lower quality printing settings and much more obvious on the highest quality settings. It gets worse as the page prints.
Could it be mechanical (one page of the paper dragging on the way through)? Could it possibly be software?
  • Eddy Jerome Dec 16, 2007
    HP Deskjest 3845
HP Deskjest 3845
Posted on Dec 16, 2007
How to fix text from printing unevenly as if the roller was not rolling consistently?
Sorry, I don't have one. Mine was a different problem; incompatibility between my old hp desk jet 5650 and my new Mac Book Pro. Just needed a newer printer!
When something like what you describe happens it is because the cartridge is dry; I change the cartridge.
Jun 13, 2014 | HP DeskJet 5650 InkJet Printer
Keep your ink-jet printer printing
Print head or ink cartidge clogged? Prevent this common problem. If you don't use your ink-jet on a regular basis, opting to use a laser for faster printing and sharper text, pick a day of the week (anyday) and make an entry into whichever calendar application you use to send a recurring reminder to print a test page from your ink-jet. Printing at least once a week will reduce the possibility that the cartridge or print head will clog with dry ink.
on Jun 13, 2010 | Office Equipment & Supplies
Hp 4250 laser jet vertical streak ghost image
The problem you are having is caused by the fuser. The fuser is the part in the printer that heats up and basically melts ( fuses) the toner to the page. The fuser has a heat roller that is coated with teflon, your fuser coating has worn off in spots so the toner is sticking to the roller and causing the ghost image. You will need to order a replacement fuser. You can do a search on Google to find a replacement, the parts number is RM1-1082.
I hope this helps, if so please rate our solution.
Corporate Computer
May 04, 2010 | HP LaserJet 4250 Printer
Printer is printing job as a mirror image
go into the properties setting for the printer, go to advanced tab, then to the prinint defaults button on that tab. When you click on that - if you go to the advanced tab within there, you will see "mirror image" and i bet it says "ON" - click on the word mirror and it opens up the ability to set this back to off. Hope that helps!
Mar 26, 2009 | HP Officejet Pro K5400n - - colour -...
Low Toner Warning
Turn the unit off. Remove the cartridge and shake it back and forth. Ten place it and turn the unit back on. Also you can reset the counter on the cartridge, go to UNI KIT and look under Brother TN 110 refill support. These people sell refills. The ink you get with he printer is minimal. Also turning the printer off and back on will help with resetting. I found that there is plenty of toner left when the warning comes on.
Feb 28, 2009 | Brother MFC-9840CDW Laser Printer
HP Officejet 5610 All-In-One print text but no image?
I found what might be the solution to this while searching for a problem for another printer series on HP's site. Go to the Printed Page Is Different Than What Appeared on Screen page and scroll down to "Missing graphics or text, or blank pages"
Sep 11, 2008 | HP Officejet 5610 All-In-One InkJet...
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
well..assuming that the text is the same on all, this might be a settings issue, with the print spooler. That's in the set up of the printer, under properties..look into that, and perhaps you'll want to spool the whole job, instead of printing immediately?
print spooler memory is finite, so the longer jobs will take longer.
Mar 17, 2008 | HP DeskJet 5650 InkJet Printer
Horizontal stripes on images
may be the ink level in ur ink jet printer is low try and use genuine ink for ur printer . i also have the same problem . when i replaced with original ink it gets ok
Dec 03, 2007 | Canon BubbleJet i560 InkJet Printer
HP DeskJet 5650 InkJet Printer Logo
69 people viewed this question
Ben Johnson
