Question about Admiral AW22 Top Load Washer
Doesn't come on in wash, or rinse cycles. will spin...
    President:
  • 1,776 Answers
The question wasn't clear. If the problem is that the machine won't fill with water then check the water inlet valve. Unplug the machine, turn off the water and remove the water supply hoses. Check the small metal screens inside the openings on the valve. Make sure they are clear of rust or debris. The solenoids can be tested using a multimeter or ohmmeter. A lack of continuity means a bad solenoid and the valve assy will need replaced. I will attach a photo for reference. Hope this helped and best wishes.
Posted on Sep 25, 2009
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
Frigidaire FWT647GHSO when it gets to rinse first rinse cycle, it doesn't stop filling with water. It won't agitate or spin. It works well in the wash cycle, agitates and spins and advances
probably you've got something blocking the water pump from doing its job properly so check that the water pump is free running emptying all the water if not then there is a blockage in the pump normally ist a button, paper clip or other debris out of a trouser pocket eric
Dec 25, 2017 | Frigidaire Washing Machines
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
After washing and rinsing it doesn't spin the water out.
Check the drain lines for clogs. If that checks out ok, then you probably have a bad drain pump.
May 11, 2012 | Miele Washing Machines
My washer only runs until it's time for the rinse cycle and then it stops completely. It doesn't rinse or spin. What's going on?
hello, it sounds like a failed lid switch part #3949247 it wont rinse or spin with a bad lid switch. it also wont rinse or spin if there is no cold water to the unit.
Jun 08, 2011 | Roper RAS8445KQ Top Load Washer
Washing machine doesnt rinse and spin
IT SOUNDS AS THOUGH ITS NOT HEATING IF IT DOESNT IT STAYS IN WASH MODE AND WONT COMPLETE CYCLE NEW HEATER REQUIRED
Aug 12, 2009 | Bosch Exxcel WVT 2850 Front Load Washer /...
Spin/drain cycle won't start
If the timer gets to the rinse cycle and stops,
Check the lid switch for continuity. If no continuity replace the lid switch.
If the timer continues through rinse and spin without doing either, replace the timer.
May 21, 2009 | Kenmore Washing Machines
Admiral AW22 Top Load Washer Logo
53 people viewed this question
Top Admiral Washing Machines Experts
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
