Question about Emerson LC320EM8 32 in. LCD TV
I have a emerson and it doesnt turn on its always on stand by power what is do you is wrong on it
  • 403 Answers
It sounds like your picture tube has went out. If you have one tube that is bad it will cause your TV not to come on. This is a safety feature. How old is your unit. Try disconnecting everything from your TV. Unplug your TV and let it sit for at least 8 hours. This will discharge your picture tube. As long as it is plugged in you have constant current. After waiting this period plug it back in and tell me what you hear if the picture does not come on. Now keep in mind that when your TV comes on you might only see your picture for seconds before it shuts off again or goes into your stand by again. Try this also, go to your internet browser and type in your brand, model, help with stand by. If you can't find what you need try this link http://emersontv.com/. Hope this helps.
JimmyC
Posted on Sep 25, 2009
Replaced Main power supply,inverter board,Digital main on Emerson LC320EM1F but it doesn't turn on,except stand by red light
The power supply board is at fault. You have a shorted diode. Location of this diode is D639. Replace it with an NTE 5087A. The board you will fix, has the power AC cord attached to it! Thanks for asking, Matt of Martins TV.
Nov 23, 2013 | Emerson LC320EM9 32 in. LCD HDTV
Emerson tv....won't turn on...stand by light won't go off
Not making it on or out of standby---first place to look is the power supply for signs of damage or puffed up filter caps there.
Dec 10, 2012 | Emerson SLC195EM8 LCD TV
32'' emerson tv says digital telivision then nothing
press power screen reads digital television then the power light and stand by light turn on then screen goes black
Nov 26, 2012 | Emerson Lc320em1f TV
Emerson Microwave MW9325SL
Failed magnetron or power supply.
Aug 12, 2017 | Microwave Ovens
My emerson tv try to turn on but goes to stand by
Hello
Unplug the power cord for one minute, then plug the cord back in . This allows the unit to reset itself.
Check the breaker box to make sure that the switch that controls the TV is not switched to "Off." If it is, flip the switch back to the "On" position.
Check the batteries in the remote control if attempting to turn on the TV from the remote. Make sure that the batteries are properly aligned. Try replacing the batteries.
Grab your Emerson TV's remote and hit the "Input" button at the top multiple times. This will cycle through the available video inputs for the Emerson TV.
You may have had the wrong input selected accidentally, such as the one for the DVD player. This will reselect the correct video input for you to enjoy television programming via your cable or satellite receiver.
If, however, your Emerson TV still lacks audio or video, peruse your A/V cable prong-to-port connections and ensure they are correctly made. The A/V cable has one red, one yellow and one white prong on each of its ends, for a total of two of each color.
Appropriately, there are red, white and yellow prongs on the back of your Emerson TV and the back of your cable or satellite box. Make sure the ports and prongs are matched up by color and have not been switched up.
Jun 09, 2011 | Televison & Video
Buzzing from inside when off.
hi!if your t.v is always on stand by power mode and there is a buzzing sound the problem is in power supply section,you need to check for weak capacitors.
Sep 08, 2009 | Emerson EWF2004 20" TV
Emerson 32 inch flat goes immed to stand by when you turn it on.
this is almost always caused by a bad inverter board, looking at the back of the tv, it is the board all the way on the left, i dont think you can get that board by itself--it comes on the panel, but you can get the transformer chips, those are next to each plug that plugs into that board on the left, usually 5 or 6 of them, you have to unsolder the old ones, and solder the new ones on, tyey are usually the problem, and alot cheeper than the board, they cost about 35 dollars for them all
Jan 11, 2009 | Emerson EWL3706 37 in. LCD Television
Won't turn on
one of the inverter transformers has gone bad replace the bad one and the set will work fine ,there are 6 transformers in the 32".
Oct 02, 2008 | Emerson EWL3706 37 in. LCD Television
Emerson LC320EM8 32 in. LCD TV Logo
209 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
