Question about Dell Latitude D600 Notebook
SYSTEM WON'T BOOT UP COMES TO A REGISTRY ERROR AND DUMPS MEMORY TO DISK. DIAGNOSTIC TEST GETS FAIL ON DST SHORT TEST ERROR CODE1000-0146
  • 59 Answers
That error code is in relation to the hard drive beginning to go bad, If it is still in warrenty call dell, if not and you have any data you need to try and retrieve taking it to a qualified shop that can put the drive into another machine or boot with a utility cd to try and get your files is recommended, either way you are going to have to get a new drive.
Posted on Sep 25, 2009
Dell Inspiron 9100 running XP boots up but then won't work. Diagnostics results in the fololowing: --DST Short Stats Test-- Test Results: Faill Error Code: 1000-0142 Msg: Unit 4: Drive Self Test...
Hard drive has bad sectors. Before your replace your hard drive when getting this error, try this- Boot from a Windows XP CD and choose Repair at the first prompt to get the recovery console. Type "chkdsk c: /p/r" at the prompt. Repeat until there are no errors found. Exit and reboot. It worked for me.
Jun 14, 2011 | Dell Inspiron 9300 Notebook
Sudden Blue screen display on my Dell Inspiron 1545 with MS XP OS-Then I ran diagnostics and got this result- "DST short Test-Failed-Error code-2000-0151 Error message: Hard Drive 1-incorrect staus...
Hard Drive 1-incorrect staus 3E. Please help fix this problem. Thanks
Nov 03, 2010 | Computers & Internet
My Dell Inspiron 6000 won't boot up. It keeps
Hi:
The DST error code 1000-1046 is definitely a failing hard drive. ..I am not sure why your laptop is not recognizing a CD in the drive, but you should go into your BIOS settings, and in boot sequence, make sure that the CD drive is the first boot device. If you can't boot from a CD, you are not going to get very far with installing a new hard drive...
May 02, 2010 | Dell Inspiron 6000 Notebook
Error Code: 1000-0146; MSG: Unit 0:DST Log contains previous erro
Code 0146 is hard drive read/write failure.
Replace the hard disk drive
Jan 27, 2010 | Dell Inspiron 6000 Notebook
DST log contains previous errors.DST short test failed
Error Code: 0146
MSG Code: 2000-0146
MSG: 1:DST Log contains previous errors
Dec 22, 2009 | Dell Latitude D600 Notebook
D610 DST Short Status Test Fail
It appears your hard disk has died and it may not be possible for you to retrieve your data.
Remove your hard drive from the laptop and insert it into an USB harddrive adapter, (they are not expensive and you can use it later as a external hard drive). Then plug it into the USB port of a working computer. The computer should/may see it as an external drive, if you are lucky you will be able to copy your data, if not, you are out of luck.
There are companies that can recover data from faulty hard drives, but it will cost you an arm and a leg for their service.
Feb 17, 2009 | Dell Latitude D610 Notebook
DST result fails
I would say this is the memory. You said that you checked the memory, and it passed, but did you download a cd called 'memtest x86' ? This will definately make sure your RAM isn't cooked. You boot off of this disc and let it go for a couple hours, it will tell you if it finds errors. Also, if it's the harddrive, you can just replace the harddrive, and then hook it up via USB and retrieve your information.
Feb 05, 2009 | Dell Latitude D610 Notebook PC
UNABLE TO BOOT DELL D600 - FAILURE TO DETECT HARD DISK
If you press F12 during bootup, you should get the boot menu. Run the hard disk diagnostic. If the hard disk is bad, you will get a DST Short Test Error code.
Replacing the hard disk in a D600 is a piece of cake though so if you need a new HD, it's easy to do. The tedious work will come afterward.
Dec 31, 2008 | Dell Latitude D600 Notebook
Dell latitude d600
Greetings AROD718,
This error message is telling you that your hard-drive is nearing OR has already failed.
I would contact a buddy or go somewhere local to get Data recovery ASAP or if that is not important to you start shopping for a new hard-drive.
Hard drives are not very expensive and are simple to install, if you need further assistance please reply back!
Good luck,
Shawn
Oct 31, 2008 | Dell Latitude D600 Notebook
Error code 0146 , can you help me ?
ALWAYS CHECK THE WARRANTY BEFORE DOING IT YOURSELF
If this is a Dell computer , it indicates a hard drive failure. if so here is the solution:
Look at the bios and see if the hard drive is detected.
To get to the BIOS, when you turn on the system, you will be confronted with a black screen with the dell symbol in the middle, if you look at the top left of the screen, you should see something like
Press F2 for boot options
Press F12 for setup
Keep tapping the F2 or F12 key for boot options. this will take you into the BIOS.
Check also that it says enabled
Next see if you can boot the dell diagnostics partition. {F12}, then select diagnostics, once you have the diagnostics available run the memory tests and the hard drive test.
you should get a report when it finishes looking something like this:
DST Short Test: Failed
Msg: Unit 2 : DST LOC Contains previous error(s)
READ TEST:
0F00: 0244
MSG Block: 57301297
VERIFY TEST:
0F00:1A44
MSG Block: 57301297
if there are more than two errors ide suggest a new hard drive. BUT TO SAVE YOUR DATA BEFORE ------>Do you have anything important? if you do, you will need to do a repair install of XP and get your files before the hard drive fails completely. Use the service tag to obtain full specs of the computer at dells website. This hard drive has previous errors, and has generated new ones. It looks like it is getting ready to fail. You may be able to use a xp disk to perform an operating system repair, the dell operating system CD will do this also. Here is a link: http://www.michaelstevenstech.com/XPrepairinstall.htm If you follow the directions exactly, you will not lose any files. Please continue to post about this issue, and operate this computer as little as possible.
Oct 21, 2008 | Computers & Internet
Dell Latitude D600 Notebook Logo
107 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
