Question about Sony SPP AQ600 Cordless Phone
/trying to record outgoing message on an sppaq600
On an older sppaq600 I've tried removing the battery from the handset and then waiting a few minutes but got no result. The record of outgoing message is just press seven, correct?
Also, aside from the one in the handset, what other batteries?
R.R.
  • 403 Answers
These phones have to totally discharge. Unplug the phone from the jack, take out your battery. Wait up to 24hours. This should set it back to factory default. Look for a reset button on your station and on your phone. It is usually the size of a pin hole. Sell what this does. If you need more help be sure to contact me. Thanks.
JimmyC
Posted on Sep 25, 2009
How can I record outgoing message?
Recording your greeting
message
1 {MENU} i {#}{3}{0}{2}
2 {V}/{^}: "Yes" i {SELECT}
3 After a beep sounds, hold the
handset about 20 cm (8 inches)
away and speak clearly into the
microphone (2 minutes max.).
4 Press {STOP} to stop recording.
5 [off]
Feb 14, 2016 | Panasonic KX-TG6531B Digital DECT 6.0 1X...
I have the uniden dect 6.0 3 handset. I lost my manuel and do not know how to record my answer message
Which specific Uniden DECT 6.0 phone do you have? There are a number of them. Uniden has the manuals available here: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . Phones are listed in alphabetical and numerical order.
If the answering system is off, turn it on before proceeding to the following steps.
If you are at home, there are usually two methods to access the answering system. Some Uniden phones let you set the outgoing message from the base or the handset. Others will only let you set the message from the handset. (Calling in remotely is more complicated.)
To access the answering system menu from a handset, on some models, push the Mute/Messages button. Then let your current message play or press 5 to stop the recorded announcement. Then either use the up/down arrows to select Record New Greeting (or the number that matches the sub-menu item). It's number 8 on the DECT1480. Then wait for the prompt (tone or "Record Greeting") and then speak into the handset clearly. Press 8 to stop recording and press End to save the message. Press 6 to select the outgoing greeting if a default greeting is available.
On other Uniden DECT phones, press Menu and go to Ans Setup. Then choose the line for the greeting (if it's a multi-line phone) and then select Record Greeting. Press Start, wait for the prompt and then press Stop when done. Press Stop again to save the message. If there is an optional pre-recorded greeting, use the Greeting Option submenu to select the greeting to play. (This applies to the DECT4086.)
From the base, you'll do something similar. However, you should stay about 9" from the microphone while recording. Messages can be between 30 seconds and 3 minutes 30 seconds for most systems.
I hope this helps.
(recording a new greeting during a remote call can be done but consult the manual for details.)
Dec 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
My handsets both show the icon that says I have a voice message waiting, yet I'm unable to get the message...and the base says there are no messages. Also, when I tried calling my own phone, the...
Try resetting the all the handsets by removing all the batteries for one minute. Then, put them back in and try it. This may reset the units. Also, check the batteries to make sure they are still good. You don't mention what kind of handset you have, but I think many of the different brands have built in voicemail. Are you sure you are not using the service voicemail instead of the handset voicemail?
Jun 19, 2017 | Uniden Cordless Phone
I have recorded an outgoing message. However, at the end of the new outgoing message an old obsolete outgoing message starts to play. How do I get rid of the old outgoing message?
You will need to remove the old message. There SHOULD be prompts. IF NOT try going to a very quiet room and hit record but do not say or make noise and this will record silence over the old and new message. Then attempt to retry.
ALSO - look for a 'reset' button and remove all batteries if you have power outage back up batteries.
Unplug the phone - and try again.
Here are the instructions from the manual:
To Change Your Personal Greeting:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
Best of it
Gary @ Fix Ya
Jul 20, 2011 | NorStar M7324 Telephone
I do not have a manual for directions on recording a personal message
For most of the Uniden DECT phones, you set up the outgoing message from the handset. Make sure the answering system is on. For the DECT1480, press Messages/Mute on the handset when the handset is in standby to enter the answering system menu. Then press 5 (or wait until the current message ends). Then press 8 (record new message). Wait for the prompt and then speak your message. When finished, press 8 again. Then listen to the play-back of your message. Press End to save and exit the menu. Alternatively you can scroll through the list of commands and press Menu/Select to enter the sub menu or command.
There are several models of Uniden DECT 6.0 phones. If you have a different phone, you should check your manual. The entire list of Uniden phone manuals is available here: http://www.uniden.com/scat/cordlessphones_mnl . Scroll down to your product and click on the version in your language.
I hope this helps.
(most of the Uniden phones that I know have the same set of directions for the answering system outgoing message.)
Jul 07, 2011 | Uniden DECT 6.0 Cordless Phone ID
While switching on mobile blinking start and shows contact service problm so plz tell solution within second ......pplzzzzzzzz
Try resetting you handset by removing the battery, wait a few minutes then re-assemble the phone.
If it does not work, via menu option, try doing a reset to factory settings (you will probably loose any information, such as contact numbers and sms messages, stored on the handset).
Dec 12, 2010 | Nokia 3110 Cellular Phone
I have purchased the Uniden 6.0 and would like to install my voice mail but I am directed to the DETAILED OWNER'S MANUAL which is not in the box. Is it possible for you to download the information for me?...
There are a number of Uniden DECT 6.0 phones. The user's manuals are available from the list here: http://www.uniden.com/index/manuals_results.cfm?cat=59 . Select your model and language for the appropriate PDF.
For the Uniden phone I know, you can set up the answering machine from a handset or the base unit. First turn on the answering system. On the base, press Ans On/Off. From the handset, press either the Phonebook or Redial buttons and use the menu to choose AM Operation. Then select Menu/OK. (Then find Answer On/Off choose On or Off and press Menu/OK to save.)
To set the Outgoing Message, use the handset as above but select Record OGM. (Alternatively, you can delete or hear your outgoing message.) To record the message press Menu/OK and wait for the beep before starting your message.
Next you can set the length of the message recording for incoming calls (1-4 minutes or Announce Only (no messages recorded). Choose Msg. Length from the menus.
I hope this helps.
Nov 15, 2010 | Office Equipment & Supplies
Telstra V580a cordless phone not working.
Try disconnecting all power to the base stations and the batteries in the handsets for a few minutes.After reconnecting power it may take a few minutes for the units to reconnect.
Good Luck
Doc
Aug 14, 2009 | Lands Phones
I can't remember how to record my outgoing message ?
here you go...
message
You can record your own greeting
message (max. 2 minutes and 30
seconds). If you do not record a
greeting message, a prerecorded
greeting message is used.
1 {MENU}
2 {V}/{^}: “Answering devicei
{OK}
3 {V}/{^}: “Record greetingi
{OK}
4 After the handset beeps, speak
clearly about 20 cm (8 inches) away
from the microphone.
5 To stop recording, press {OK}.
6 {OFF}
If this helps you solve it, plz rate this fixya. Thank you kindly.
Feb 01, 2009 | Panasonic (KX-TG1032S) Phone
How to change Flash timing
The only reference to flash timing I can find in the manual is shown below for you, also here is link to manual :
I hope it helps !
http://www.uniden.com/products/productdetail.cfm?product=TRU8885-2
If you have Call Waiting service and a call waiting
tone sounds while you are on a call, press talk/flash
on the handset or flash/find hs on the base to accept
the waiting call. There is a short pause, and then you
will hear the new caller. To return to the original
caller, press talk/flash on the handset or flash/find
hs
on the base again.
Setting the Ring Time
Ring Time allows you to set the number of rings the caller hears before your
answering system plays the outgoing message. You can set the ring time to answer
after two, four, or six rings. If you enable the Toll Saver (TS), the answering system
picks up after two rings if you have new messages and after four rings if there are
none.
1) Enter the Answ. Setup menu, and then the Ring Time
submenu (see "Entering the Menu" on page 16).
2) Press volume up/down to select a Ring Time (Toll
Saver, 2 Times, 4 Times, or 6 Times).
3) Press the OK soft key. You will hear a confirmation tone.
Setting the Record Time
Record Time sets the duration for recording the incoming messages. You have three
record time options. The options "1 minute" or "4 minutes" set the duration for
recording the incoming messages. "Announce only" answers the call but prevents
the caller from leaving a message.
1) Enter the Answ. Setup menu, and then the Record
Time submenu (see "Entering the Menu" on page 16).
2) Press volume up/down to select Record Time
(1 Minute, 4 Minutes, or Announce Only).
May 03, 2007 | Uniden TRU8885-2 Cordless Phone
Sony SPP AQ600 Cordless Phone Logo
85 people viewed this question
Top Sony Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Lands Phone Expert? Answer questions, earn points and help others
