Question about Daewoo Televison & Video
Why my prejector send an image whith alot of static????? some people says the ground in my house is not good
  • 403 Answers
I need more info but try this. If you have audio, check your cables. Most of these items work fine without a ground so this might not be the problem. Check all your connections. How old is your unit? What software if any are you using. Are your drivers and software up to date. You can get help from the projector web site. In your search just type in Brand, model, help with sending images. Hope this helps.
JimmyC
Posted on Sep 25, 2009
I have a problems with my gage on my 1997 ford Thunderbird the gas go to full all the time what could that be
Here are some suggestions:
TROUBLESHOOTING
PROBLEM: The fuel gauge does not work at all...no needle movement. With the ignition switch on, remove the wire from the fuel tank sending unit and ground it to the unit housing. This removes the resistance supplied by the sending unit, and should cause the gauge to swing over to the 'Full' position. Does this happen?
Yes
No
The gauge and wiring are good. The problem is most likely with the sending unit. The sending unit must be removed for further testing. (1) Ground the sending unit wiring to a good chassis ground (instead of the sending unit housing) and watch the gauge. Does it now peg out to the 'Full' side? Yes
No
The problem is with the sending unit ground. Either the unit itself is bad or the float/arm is binding/missing. The sending unit must be removed for further testing. The power supply to the gauge has been interrupted, (check fuses), the gauge is defective, or the wire from the gauge to the sending unit is open or has a break in it. Testing the Sending Unit After the sending unit has been removed from the tank, check to make sure the float is present, intact and still floats and that there is no binding with the float arm. Reconnect the gauge wiring to the unit and ground the unit. Move the float arm up and down. If the gauge reads full in the full up position and empty in the full down position, then the sending unit is good. Verify by hooking up an ohmmeter to it and making sure it reads 8-12 ohms full and 70-73 ohms empty. If not, the sending unit needs repaired or replaced. You can easily disassemble the head of the sending unit to clean and/or repair.
Apr 28, 2016 | Ford Cars & Trucks
Just moved houses, and the amp puts out loud static when cable is plugged in. The house may not have grounded plugs, and I do not see a separate ground screw for attaching a stand-alone ground wire. What...
get a 3 way adapter,, plug your amp into the adapter, and secure the ground wire to the center screw in the receptical cover , or if it comes with a tab instead of a wire, secure that
May 30, 2011 | Fender Frontman 15r Combo Guitar Amplifier
1999 durango shifts hard runs up high rpm then shifts. only between first and second. if you increase speed moderayely it will jump out of second and into first with very high rpm
I have seen alot of governor pressure issues whith those and sometimes the oxygen sensor can short out they share the same ground so if whoever works on this changes governor solenoid and pressure switch bring this to there attention and change the 02 sensor at same time.
Nov 02, 2010 | 1999 Dodge Durango
Need to find out where the starter is on my 1999 Olds Silhouette, I think the ground wire is loose
it's typically near the largest part of the transmission bell housing. where the flywheel is.
typically black, 4-6'' in diameter...
http://static.am-autoparts.com/part-images/full/AM-20288955_C.jpg
Jul 28, 2009 | 1999 Oldsmobile Silhouette
1994 silverado 4 wh dr.V6 I have alot of static on my radio
Sounds like a ground issue try removing radio and put a ground wire from radio to a good metal ground or check ant. connections
May 16, 2009 | 1994 Chevrolet Silverado 2500
Laptop into my YAMAHA HTR-6130 Receiver has Static
One possible reason would be a damaged ground in the cable (check with a DVD/CD player or any other device if possible to see if static persists.) if it is not the cable, then try plugging the laptop into the same power outlet as the Yamaha receiver and see if static persists. if static no longer persists, the problem is a discrepancy in the grounding on either end causing static in the signal and you can either buy a filter at most electronic stores. or you can just continue to use that power outlet if it is not an inconvenience. if it IS the cable, well, replacing it should be fine.
Jan 18, 2009 | Onkyo TX-SV444 Receiver
How to hook up my Mackie 1202 VLZ PRO to my computer .....
i think your computer audio is not in shape to boost a great sound. specially when it is built-in sound in the motherboard of your computer. see your computer / motherboard manual's if the driver's you have AC '97 then you cannot really boost sound.coz it's a generic driver's for sound card. if try also to update your driver's (sound). by seeing the brand and the model of your motherboard or computer and go to manufacturer websites for update. after update if can't help, but you really need to boast a great sound then you can really buy a PCI sound card 6 channels or 24bit 5.1 or 24bit 7.1 f your sound system have are compatible with this. or has an interface like this - audio 5.1 and 7.1.
Nov 15, 2008 | Dell Dimension 2400 PC Desktop
Static on line
Does the static stay on the line after the called party answers?Is the static on incoming and outgoing calls on any phone?if the answer is yes to the above questions,check your house jacks for corrosion.There are a number of things that can cause static inside your house and outside.From the interface box on your house where the wires come from a pole or from under ground is phone company problem.From the box into the house is your problem,so the easy solution is to make the phone company come out and determine from what side the static is coming from.There is usually no charge for this unless you have them come into your house if the problem is there.
tk46
Jul 20, 2008 | Panasonic KX-TG1033S Cordless Phone
Speakers are making wierd sounds
yes........maybe the ground is poor,pin jacks broken ,open ground in the preamp stereo ouput...all for the ground..try this........ take a pice of wire and put one end in ground of car chasis in area with no paint, and the other side in the amplifier input pinjaks and check if the static goes off. good luck.!!!!
Mar 13, 2007 | Lanzar HRWDC15 Car Subwoofer
Televison & Video Logo
23 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
