Question about Kitchen Ranges
My front right bruner on the viking range wont
My front right burner on the viking range wont turn off - it twists all the way around, but doenst turn off
  • Anonymous Mar 19, 2014
    viking range is wobbly
    New Friend:
  • 47 Answers
Hm, check your knob if that's the case call your local Viking distribution center for further assistance
Posted on Nov 26, 2014
  • 546 Answers
Pull knob straight.off use a pliers to turn shaft to off position.shop an appliance parts store for a new knob.
Posted on Sep 25, 2009
Nearly brand new wolf range ignitor not working
The cleaner most likely got soap or debri in the gas orifice, this is where the gas goes into the the burner cap. If you can see a spark/light then the ignitors are working properly, just not getting fuel to the area. Pull the burner cap off, check area for particles on/in bruner. Take a twist tie and strip the outer covering off, Use it to clean out the orifice for the gas. Burner ring has an area where the gas comes in. Ensure it too is free of any debri.
Apr 22, 2013 | Wolf Range Kitchen Ranges
Viking range burners won't light
from I review I found it might be this...Simple replacement of Glow Bar igniter requires removal of entire front panel with many screws
so sounds like your igniter might be shot - it heats up to ignite the burners - easy fix - get a long torch lighter and just light the gas after turning it on -
Nov 05, 2017 | Viking VGIC485-6G Gas Kitchen Range
Viking gas oven model # VGIC3656BSS, serial #022404-2919 takes FOREVER to preheat up. Sometimes in excess of 40 minutes. Been a problem for a while. Looks like flames at bottom do not increase when oven...
When increasing the temp. on a gas range the oven's burners do not increase flame size as the cooktop burners do. It just keeps the burner lighted for a longer amount of time.
First if you can see the burners do they light within about a min. or less. If no you probably have bad igniters which are not lighting the burners as quickly as they should or they are "opening up" (stops working) when they get too hot. In this case replacement of the igniters should solve the problem.
Second if it lights quickly but still takes a while to heat; you want to look at the burners to ensure that the flames are down both sides of the burner tube and not dancing around too much. If only part of the two sides of the burner tubes are lighted then a pluged orifice or burner tube is the most likely cause. Once cleaned it should work fine.
As with anything mechanical there are numurous possiblities for something not working correctly and above are the two most popular reasons that come to my mind.
May 17, 2011 | Viking VGRC485-6 Gas Kitchen Range
Left front burner not igniting...no spark but has gas,
automatic re ignition control (spark module), that's a common issue on all viking stove.
appliancesrepairla.com
May 12, 2010 | Viking VGIC485-6G Gas Kitchen Range
Three small burners work three large dont
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Mar 24, 2010 | Viking Professional VICU165 Stainless...
Burners continue to click after ignite
I would say it was the switch , do the others do the same thing?
Apr 14, 2009 | Viking VGIC365-6B Gas Kitchen Range
My right front burner will not turn off on my electric stove top?
Hello, the switch controls the element ,if the element is staying on replace the switch.Please note any electrical repairs should be performed by an authorized service technician. good luck
Dec 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Burner ignitor will not turn off after the burner lights Viking
replace the electrode that's the wire or pilot tip, it has a sensor built in, when it gets hot it stops automatically. if the electrode is between the front and rear burners, there are small holes on the burners going down on the side of the burner facing the ignition. they need to be clean. try a paper clip and insert the clip in side the holes.
Dec 14, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Kitchen Ranges Logo
258 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
