Question about Dell 0Y3740 Keyboard
I connect key board but it seems dead iam using
I connect key board but it seems dead as if not even connected. so i am using onscreen keyboard. how can i test the port? i have a dell desk top and iam running xp operating sys
  • Dell Master
  • 8,404 Answers
I suggest you look in your device manager for a problem with the driver for your computer. The keyboard may be defective, id suspect the driver. Remove the driver/device and let XP fix it for you (reboot)
If you dont know how to do these things, please let me know
Let me know if this works for you
a
Posted on Sep 25, 2009
    President:
  • 1,015 Answers
You can test the port with another keyboard if you have one. If the keyboard port is bad you can get an adapter that will turn the keyboard connector into a usb connector or buy a USB keyboard.
I have to enter my password several times to get my kindle to log on. I always have to log on..the signal seems to be weak adjacent to the router. authentication failed is a normal response on my kindle....
your kindle device should be able to connect the network automatically , if this is not happening try adding the network manually.
1.First, make sure you are within range of the network you want to add, and that you know the network name and password (if required).
2.From the Home screen, tap Menu and select Settings.
3.Select Wi-Fi Networks to display a list of detected Wi-Fi networks.
4.Tap Join to enter network details.
5.Use the onscreen keyboard to enter the name of the Wi-Fi network that you want to add.
6.Once the Network Name has been entered, tap the Password box and enter Wi-Fi password / Network Key using the onscreen keyboard (if required).
Tip: Tap the 123 key to enter numbers or symbols. Tap the ABC key to return to the regular keyboard. Tap the Shift key (up arrow) to enter uppercase characters. Your password may include non-English letters (accents, umlauts etc.). To view accent options, press and hold a letter down, and accent options appear.
7.Tap Connect
Does all your wireless devices have weak signal issues?If so , Then problem may be with the wireless router.Try changing the wireless channel on the router by logging into the router interface page.
Authentication failed is the message u ll normally get when u enter the password incorrectly.
Aug 07, 2013 | Belkin (F5D7230-4) Router (587009)
Certain keys do not make a sound..
The wire from pin 1 or 7 of CN1 on the GHL88L (left end) circuit board is open where it goes to the middle circuit board. This could be a bad cable, improperly seated cable connector, or a crack in the circuit board(s) connecting to these wires. These are the common matrix wires associated with only the C# and G keys for the left 1/3 of the keys. If more than 1/3 is dead, then the problem is likely on the middle board GHL88M that connects to the mating cable to the CN1 connector.
There are two wires dedicated to the keys for the two contacts that are used to measure velocity of the key strokes. There is a mechanical position between closing the contacts and the time is measured by the processor as velocity.
If you are the least bit worried about working on electronics you best have a service person do the repair. The keyboard has to be lifted out after removing the top and disconnecting other cables.
May 03, 2010 | Yamaha Full-Size Keyboard
None of the keys respond
Hi
It seems that the connection of the keyboard is disturbed.
Check the TOP Lights which are on the key board. If the num lock is working then it shows key board is fine with the connection or check the connector
Tx.
Feb 19, 2010 | Acer NSK8458AN Keyboard
Shift key error
dear sir
good day
you can use the caps lock key instade or you can use the ms onscreen key board from accessories then ease of use then chose the ms on screen key board or by the end of the day you can buy a new key board for that :)
thank you
Dec 24, 2009 | Computers & Internet
I have a Dell Inspiron laptop, and certain letter
This could be a possible hardware issue. You can try to use an external USB keyboard and check if the keys are working or not. If you do not have an external keyboard, you can try to use the onscreen keyboard. To do this, go to start>programs>accessories> accessiblity and then choose on-screen keyboard. Open a notepad and try to use the keys which are not working using the onscreen keyboard. If onscreen keyboard works fine , then you need to get the keyboard replaced.
Nov 11, 2009 | Computers & Internet
Keyboard problem. Key 3, @, #, y, n can't use
you may have shorted your keyboard (spillage??)
if your laptop is outside warranty you can check the connection to the keyboard, by removing the top bezel, undoing the keyboard retaining screws and then check that the ribbon cable for your keyboard is seated properly, If reseating this cable does not work the you can always order a replacement for your keyboard, you can find the part number for the keyboard you have, it should be printed on a tag on the reverse of the keyboard.
May 24, 2009 | Acer Aspire 3680 Laptop
Keyboard and mouse pad dead. all else seems ok. got dropped
If it works with an external keyboard and mouse then you need to replace the palmrest.
May 13, 2009 | Computers & Internet
Wireless keyboard stopped working; mouse still does though
on this key boards problem is that they key pad circuit board has no mechanical connection or wire connection it merely lays across the circuit board loosing contact that's why if you squeeze the bach it starts working again
May 03, 2009 | Gear Head WIRELESS keyboard/Mouse
I have one intel 845gvsr board for repair. The board is dead. When RAM is removed it gives memory error beeb i.e. 3 long beeps, but RAM is ok & cpu is also ok. When is installed the board does nothing. No...
Hi there
Three Long Beeps = Keyboard/Keyboard card error
An error with the keyboard can be caused by any of the below possibilities.
  1. Keyboard is not connected properly.
  2. Stuck key
  3. Bad keyboard
  4. Bad PS/2 or AT port
Solution:Keyboard is not connected properly
Verify that the keyboard is connected properly to the computer by turning off your computer and then disconnecting and reconnecting the keyboard to the computer.
Stuck key
Ensure that there are no stuck keys on the keyboard. If all keys appear to be ok and you have a standard desktop computer with keyboard, attempt to turn keyboard over and gently hit the back of the keyboard to loosen any dirt or hair that may be stuck in the keyboard.
Bad keyboard
Try another keyboard on the computer to verify that the keyboard has not gone bad.
Bad PS/2 or AT port
If all of the above solutions are not able to resolve your issue it is likely that the port on the back of the computer may be bad and the motherboard or I/O board may need to be replaced.
Good luck and kind regards
Jan 05, 2009 | AOpen XC Cube MZ915M (95MZ1592Z1) Barebone
Dell 0Y3740 Keyboard Logo
83 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
