Question about Nuova Simonelli Oscar Coffee Maker, Espresso Machine
Mac cup V commercial Nuova Simonelli will not **** water and will not build pressure
    President:
  • 1,618 Answers
First check the reset thermostat on the right side of the boiler below the level probe, make sure there is water in the boiler before resetting.
Posted on Nov 18, 2009
My nuova Simonelli oscar doesn't heat
This is a good little machine. its basically a commercial machine shrunk down for home and is worth repairing even if you have to take it in. go to nuova simonelli usa website and download the parts manual and check the 009500014 thermal fuse and the 09500004 highlimit thermostat and see if one is gone or tripped. check the pressure stat, check if power to elements and if there is check to make sure the elements havnt failed from being heated with no water. like i said this machine is on par with a rancilio silvia so well worth repairing.
NUOVA SIMONELLI ESPRESSO MACHINES
Apr 08, 2014 | Nuova Simonelli Coffee Makers & Espresso...
Troubleshooting Nuova Simonelli espresso
The water sonoled
You have to despatched it ,clean it you will find small break's there
Mar 23, 2014 | Nuova Simonelli Mac 2000 Espresso Machine
No steam pressure
Leave the valve open until it starts slowly hissing, then shut off valve and wait for the pressure to build up.
Oct 03, 2013 | Nuova Simonelli Coffee Makers & Espresso...
Nuova simonelli vip over pressure problem
Could be lack of water in the boiler, could be a faulty pressure stat or vent valve. Check the level probe first, then the vent valve and then the pressure stat. You can also use the manual fill to make sure water is getting to the boiler.
Jun 27, 2010 | Nuova Simonelli Microbar Espresso Machine
I'm getting no crema from my Nuova Simonelli Mac 2000 V
Pressure pump is not working or can not produce 9 bar pressure.
Or the coffee is less tha 7 gr.
Or the coffee is grinded too thick.
Please remebr to vote for this answer thanks
Oct 15, 2009 | Nuova Simonelli Mac 2000 I Group Espresso...
Old 1996 nuova simonelli mac digit no pressure or heat
There is a reset thermostat on the right side of the machine above the element, check to see if it tripped. If it did make sure there is enough water in the machine and when turning it on, open one of the steam valves and turn off the cup warmer. Leave the steam wand open until it hisses or small amounts of steam or air will vent out.
Feb 11, 2009 | Nuova Simonelli Mac 2000 Espresso Machine
Nuova Simonelli Mac 2000 - Boiler continues to fill up
I had the same problem of the boiler filling up all the way with water and the water was coming out of every hole in the machine. Turn the machine off, drain the boiler completely,
MAKE SURE VALVE #2 is CLOSED, this is the one under the drip pan all the way to the left. Turn on the water supply to the system and turn the system ON. The cup warmer on top will come on and stay on for anywhere between 10 to 20 minutes..... let it be,,, do not turn it OFF,, it will go off automatically. That should do it!
Hratch
Jan 21, 2009 | Nuova Simonelli Mac 2000 Espresso Machine
Nuova simonelli mac cup red light
It sounds like the thermostat on the boiler nest to the element tripped. Fill machine with water until you can see the level about half way, then open the right side of the espresso machine, you might be able to get to thermostat from the top of machine (make sure it is unplugged) then press the red pin on the boiler between the 2 wires, that should reset the thermostat, if it does not then it will need to be replaced. As for the water on the top of the group head, is there any way you can post a pic of the top, because simonelli made a few different head and I want to give you the correct advise.
Nov 13, 2008 | Nuova Simonelli Premier Maxi Espresso...
Nuova Simonelli Oscar Coffee Maker, Espresso Machine Logo
470 people viewed this question
Top Nuova Simonelli Coffee Makers & Espresso Machines Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Nuova Simonelli Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
