How do get rid of echo on sound from speakers?
  • 59 Answers
When you say echo, are you meaning sound coming from your mic echoing thru the speakers or a sound like your in a bathroom on all audio.
If you are referring to the mic issue, then open your volume control and make sure that MIC is muted in playback setttings
If you are refering to bathroom sound on everything , it is called a "environmental setting" and in in your sound cards software setup, like their version of the volume control or some other application they have installed for you to configure your card. Just locate the "environmental" setting and disable it / set it to none.
Posted on Sep 25, 2009
    President:
  • 1,015 Answers
The echo effects setting might be turned on in the sound device properties. You will need to go into the control panel and double click on the sound icon. Check the properties of your sound card and turn off any special effects for the sound stadium,theater,outside,ect.
2 Suggested Answers
Cylon13
  • 55 Answers
SOURCE: how do I get rid
Sometimes the echo is produced by the MIC, if you have a Mic mute it, or make it far from the sound source, or disable the MIC boost function on the recording device on the multimedia panel.
Posted on Mar 12, 2011
My new Vizion tv has a vizion sound bar, the sound comes out with an echo, how do I correct?
Your TV speakers should be turned all the way down or off when you use a separate sound system such as a soundbar. Using them with the soundbar may cause echoes and the TV speakers do nothing to improve the sound.
Look at your TV's audio menu. If you can, turn the TV speakers off completely at the menu. Also see if you can set the analog audio output to "variable." This will allow you to control the soundbar's volume with the TV remote.
Jul 08, 2017 | Echo Computers & Internet
Echo through speakers
Unintended reverberation, or "echoing," from your computer speakers is a common problem that can arise from improper setup of your audio properties.
Resetting all of your audio information to default will correct this problem, allowing you another chance to strike a good balance to satisfy your audio tastes.
This can be accomplished by accessing the Sounds menu in your operating system.
Select the "Start" menu from the bottom-left corner of your screen, and click on "Control Panel." Find the "hardware and Sound" button and click to select.
Click on the sound icon and select the third tab labeled "Sounds" in the window that appears. A list of sounds will appear, beginning with "Asterisk." Click on a sound to highlight and select test.
Listen to hear if the echoing problem occurs.
If it does, you need to configure your speakers or check to see if it is a third-party issue.
Select the first tab labeled "Playback" from the same window. Right-click on the "Speakers" icon. Click on "Configure Speakers" from the top of the list.
Choose a setup from the list that appears and select test to test different sound configurations for the speakers.
Listen to decipher if one configuration has less echo than another. If so, choose the speaker configuration without the echo to fix the problem.
However, if none of the configurations remove the echo, you need to attempt to troubleshoot the issue from "Safe Mode."
Turn on your computer if it is off or restart your computer. Continuously press the "F8" key until the "Advance Boot Options" screen appears.
Use your arrow keys to navigate the screen, pressing down until you have highlighted the "Safe Mode" option. Hit "Enter" to select. Wait for the drivers to load.
Log on from the "Administrator" account. Test the sounds again, and if the echo does not occur, the cause is a third-party driver or service.
hope this helps
Sep 15, 2012 | ASUS Computers & Internet
How do I get rid of echo sounds in my speakers ?
Mar 12, 2011 | Computers & Internet
I have altec lansing pro logic speakers from my
Check that your computer doesn't have a microphone (internal maybe) and that it's not switched on.
Cheers.
Jul 08, 2010 | Audio Players & Recorders
Speakers seem fine except they seem to have an echo to them
the echo is a software effect on your computer check the sound card and driver under control pannel under sound make sure reverb or echo is off it sucks
Dec 27, 2009 | Logitech X-240 Computer Speakers
System echos when dvd is in. When I mute the Bose sytem I can hear the TV sound without the echo.
The echo you hear is the audio delay between your TV speakers and Bose speakers. Muting (or lowering the volume) on the TV will eliminate the echo. Some TVs have a setting to turn of TV speakers entirely, allowing you to listen to your TVs audio strictly through your Bose system.
Dec 20, 2008 | Bose 3·2·1 II System
All sounds on my computer sound like they're in an echo chamber
I had this problem. I right clicked on the speaker icon at the bottom right hand corner of the screen, selected playback devices, left clicked to highlight the 'speakers' (realtek in my case) then clicked properties in the lower right of the open window, clicked on the enhancements tab, and found that my sound effect properties had been changed to auditorium. I clicked the selection arrow and changed the enhancements to 'none'. Oh happy day! No more echo.
Dec 14, 2008 | JBL CREATURE II Computer Speakers
Jensen JMP 50 sounds like I am in a tunnel or well.
Have you powered up the speakers have you checked the sound drivers?? but remember the sound of the Jensen JMP-50s is a bit hollow and lacking in bass, and the speakers do lack bass and treble controls, which can often be found in other speakers in the same price range.
Aug 18, 2008 | Jensen JMP-50 Computer Speakers
Voice echo in computer speakers
Look in your audio properties and make suer to uncheck 3d sound.
Mar 19, 2008 | Computers & Internet
Computers & Internet Logo
1,057 people viewed this question
David Payne
David Payne
