Question about ViewSonic NextVision N3260W 32 in. HD-Ready LCD Television
I cant convert my 24" ViewSonic remote to my Comcast remote
I want to be able to have vol, power, everything run off of one remote. The codes are not working, unless I am doing something incorrectly.
  • 403 Answers
Try and re-do your codes for your remote. If you don't have the codes try this.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Posted on Sep 25, 2009
Need codes for toshiba sound bar and Comcast remote
  1. Turn on the Sound Bar you are programming.
  2. Press and release the "AUX" button on your universal remote.
  3. Press and hold the "Setup" button on your remote until the button blinks twice.
  4. Type in the 4-digit code listed below using the number buttons. Additional codes may be found in the remote manual. Most likely code
    0045
    Others to try
    0209, 0043 most likely (then try 0503, 0695, 1045, 0154, 0156, 0060, 0045, 0043, 0845)
  5. If the code is entered correctly, you will see two blinks. If the code is incorrect, you will see one long blink.
  6. Use the universal remote to operate your Sound Bar (use Power, VOL, etc.)
  7. If these steps don't work, try another 4-digit code and repeat the above.
Sep 07, 2017 | Toshiba Televison & Video
I have a radio shack 15-302 rc and I need codes for a Toshiba DVD player and a sansui platinum plus t.v. if possible thanks
its not likely you'll find these codes as few ever publish them as manuals have become a thing of the past on most devices.
but you have a search function on any remote it might only give you the power on / off an if your lucky the vol control advanced functions rarely ever work on remotes unless you scan them using the original remote into the new master remote
some day i spect there to be a master site with all scanned codes for every tv etc made .. slobber
Sep 12, 2015 | Toshiba Televison & Video
I have a Sony VCR remote control that is compatible with a Sony TV. The VCR functions work fine but I can't get the TV functions to work. I have set the proper code and installed new batteries, but to no...
All Sony remote controls will be compatible to any other sony products except the other buttons than Ch Up/Ch Dn and Vol Up/Vol Dn. No other buttons won't be.
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Feb 07, 2015 | Sony Televison & Video
Need tv code for model un32eh40031
This should help!
Turn on the TV you are programming.
  1. Press and release the "TV" button on your Universal remote.
  2. Press and hold the "Setup" button on your remote until the button blinks twice.
  3. Type in the 5-digit code using the number buttons. Most likely code for a Samsung TV is 10812
  4. If the code is correct, you will get 2 blinks. If the code is incorrect, you will get one long blink.
  5. Use the Universal remote to operate your TV (use Power, VOL, etc..)
Dec 14, 2014 | Samsung UN32EH4000 32-inch LED TV
How do I program a comcast xfinity remote for a Dynex tv
Hello there
From this page, http://customer.comcast.com/remotes/
I used the first type of remote and I got
  1. Turn on the TV you are programming.
  2. Press and release the "TV" button on your Universal remote.
  4. Type in the 5-digit code using the number buttons. Most likely code
    11463 Others to try
  5. If the code is correct, you will get 2 blinks. If the code is incorrect, you will get one long blink.
  6. Use the Universal remote to operate your TV (use Power, VOL, etc..)
  7. If these steps don't work, look for another code and repeat the above.
Sep 20, 2014 | Samsung TV Remote Control
What Is the tv code for an lg42pq30c
  1. 1 Turn on the TV you are programming.
  2. 2 Press and release the "TV" button on your Universal remote.
  3. 3 Press and hold the "Setup" button on your remote until the button blinks twice.
  4. 4 Type in the 5-digit code using the number buttons. Most likely code
    10178 Others to try
    11178, 11265, 11993, 10017, 10700, 10856, 11314, 10842, 11032
  5. 5 If the code is correct, you will get 2 blinks. If the code is incorrect, you will get one long blink.
  6. 6 Use the Universal remote to operate your TV (use Power, VOL, etc..)
Aug 30, 2014 | LG Televison & Video
Where Can I Get a Cheap Remote for a Sony AVD_K800P. I Paid $10 Dollars for the Sony AVD_K800P . and I would like to get a Remote that works with it That Can Turn up The Rear Speakers , and Work Vol
I know of a Sony brand learning remote that will do it but, it sells at Target for $29.99. I have 2 of them and works great for all equipment however, the problem with that is that you actually need the original remote to assign keys or buttons on this one. It does have factory settings for various Sony equipment programmed from the factory. I'm looking in the manual now to see if that player is listed. I can't find the actual model but, there are several Sony model surround amps that it will operate with the code listed. This remote is only a couple of years old and runs all my oddball stuff I couldn't get remotes or codes for. Sony models usually have settings for their own stuff built in. The remote is called a RM-VL610 Integrated Remote Commander if you're interested in trying it. It works my old Sony stereo 60 cd changer unit with no problems. This could help unless you order the original remote in which I can help find if you need but, would probably cost more.
Dec 02, 2013 | Televison & Video
All buttons on tv stopped working only turns ON no ...
There is a button lock in the menu of the television. Using your remote access the menu screen and unlock the buttons.
Feb 19, 2009 | ViewSonic N3735W 37 in. LCD TV
Unicersal Remote code for Motorola cable box
I found this on another site: It works BUT you don't have all the functionality you would have with the cable remote (of course). If you want power on/off, vol up/down and channel change.. this is your fix.
Was this comment useful?
new Starbox("rating1496612", 0.0, {identity: 1496612, stars: 5, buttons: 5, max: 5, total: 0, onRate: saveVote});
  • Motorolla Comcast code Posted by whowlett5 on Dec 26th, 2008 at 12:40pm
    I got mine to work using the Code search method. The manual is incorrect though about using the code search: Instead of pressing Power repeatedly, you just press it once. It sequences through the codes. You then need to press Enter immediately when the comcast unit turns off.
  • May 23, 2008 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
    Child Locked TV and Remote
    Press MENU to show the on-screen
    menu.
    Press VOL+ or VOL- to highlight SET.
    Press CH+ or CH- to highlight
    PARENTAL CONTROL.
    Press VOL+ or VOL- to display the
    SECRET CODE
    screen.
    Press VOL+ (on the remote) and the
    CH+ button on the front of the TV
    at the same time.
    Press the Number buttons to
    enter a four-digit code. The code will
    appear on the screen as you enter it.
    The code "0000" is the default of the
    TV. If you have not set up a code previously,
    then "0000" is the code.You cannot
    use "0000" after you set your own
    code (unless you reset the code to
    "0000").
    Press MENU to save the code.
    Hope this helps. :}
    HERE IS A LINK TO THE USER MANUAL:
    http://www.p4c.philips.com/files/2/27ms343s/27ms343s_dfu_aen.pdf
    Mar 31, 2008 | Philips Magnavox 27MS343S 27" TV
    ViewSonic NextVision N3260W 32 in. HD-Ready LCD Television Logo
    263 people viewed this question
    Top ViewSonic Televison & Video Experts
    Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
