Question about Onkyo TX-SR604 Receiver
No sound from receiver TX-SR604
I purchased a refurb unit, connected it up, I am using the audio out to drive a secondary amp for zone 2. Worked fine for a day. Next day, no audio from the surround. I do have an audio signal (pass through) goint to zone 2 however. I tried unplugging the receiver, but to no avail. I still cannot get any audio from the surround SR-604 receiver.... HELP!
  • hammmer Jan 05, 2008
    What does that matter? It's the surround sound that will no longer work!
Make sure that the zone 2 audio source is not digital
Posted on Dec 22, 2007
Can a Onkyo tx sr604 receiver be used as a pre amp?
Yes. You can use the Line Out, or Pre-Amp output into another receiver or amplifier. The receiver or amplifier you use as the amp, will need to have a volume control, as the line output coming from the TX SR604 cannot be varied.
If you have any further questions, please visit my website at and contact me there.
Thank you.
Jun 06, 2014 | Onkyo Audio Players & Recorders
Onkyo tx-sr604 help
You said you tried hooking the HDMI up directly from the TV to each component, and that worked. How is it usually hooked up - through some kind of switch? I'm not completely understanding your setup here.
Aug 10, 2007 | Onkyo TX-SR604 Receiver
Onkyo TX-SR604: Video in from cable box has taken increasingly longer to display a picture.
I would at least disconnect all units from power for a while and then reconnect to allow the units to reboot.
Oct 30, 2012 | Onkyo TX-SR604 Receiver
Hi, this is not really a problem. I have an Onkyo TX-SR604 receiver. I had polkaudio speakers RTi8 speakers that are no longer working properly. I am looking for recommendations for new speakers that can...
A receiver with the specs...
* "90 watts minimum continuous power per channel, 8 ohm loads, 2 channels driven from 20 Hz to 20 kHz, with a maximum total harmonic distortion of 0.08%"
(*) The only acceptable statement of its power bandwidth in the manual.
... when fed an undistorted audio signal, used properly and not driven abto clipping is not particularly dangerous to any reputable speaker.
Driving any amplifier, even a modest one, into high distortion is more dangerous to any speaker than a high-powered amp pumping pure undistorted power.
Choose any speakers but low efficiency models if you want loud and clean sound.
Jun 10, 2010 | Onkyo TX-SR604 Receiver
I have a Onkyo TX-SR604 Receiver. I get no sound
Hello Fixya customer,
Thank you for your question.
A point to keep in mind here is that Zone II will only feed through an analog source. Since the Video 1 input is using the digital (coax, optical) input that that is your most likely issue.
Thank you for using Fixya, and please let me know if I can firther assist.
May 01, 2010 | Onkyo Audio Players & Recorders
One channel not working onkyo tx-sr04
You might have to take a look into the unit, there could be some damage or a bad solder connection on the front left speaker connector at the circuit board, possibly also on any other component (power amp chip / transistors, internal connectors, etc.), also loose or broken wires or oxydized connector contacts inside the unit.
It could be something else as well, but i guess it's worth checking the above mentioned.
Hope you can fix it
3rq8 (Triarcuate)
Aug 08, 2009 | Onkyo TX-SR604 Receiver
Onkyo TX-SR604 provides audio thru receiver but no video on Bravia LCD when satellite receiver signal is sent thru any of the Onkyo HDMI connections to tv, however if I connect up my Samsung DVD recorder...
easiest fix is to take all hdmi straight to tv. then come out of tv with optical cable to your receiver. that way what ever your watching will automatically be sent to the receiver thru optical. you even will get dolby dig. also you can have audio from your tv when you dont want to use your surround. keeps receiver on one input also.
Jul 02, 2009 | Onkyo TX-SR605 Receiver
Onkyo TX-SR806 7.1 Channels Receiver I bought a reciver just 4 days back. It worked fine for 2 days and yesterday when i tried to increase the volume, it shut off. I tried troubleshooting to see if there...
If you have disconnected all connections from the receiver including your sources and the unit shuts down and goes in protect then there is an internal shortcircuit on the receiver and you would need to send that to an authorized service center. Now, since you just bought it 4 days ago, if you purchased it from an authorized dealer of Onkyo you could have it replaced since its way within the 30 day return policy. But, if you have purchased it from circuit city, unfortunately your option would only be the service center for repairs. If you send it to an authorized service center, you would need to put in a copy of your sales receipt together with a brief description of the issue you are encountering. Where did you purchase your 806?
Mar 03, 2009 | Onkyo TX-SR604 Receiver
Onkyo TX-SR604 Receiver Logo
195 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
