Question about Epson Stylus CX6600 All-In-One InkJet Printer
Epson cx6600 will not print entire design on 8x11-1/2 vellum..it prints 2" on right side only....Please help..It used to work fine....on tracing paper , and of course won't print on that entirely either...Thank You Bernice Dupre
  • 241 Answers
Try setting the printer to print the page in "landscape" mode and not "portrait".
Posted on Sep 25, 2009
Epson stylus cx6600. How can I get rid of the message box telling me I am not using Epson carts. I know they are not Epson carts but there must be away of having not to click YES I want to continue using...
Hi Andy,
This helps remove the nag screen:
  1. Go to Printers and Faxes (or the equivalent screen that lists all your printers)
  2. Right click your CX6600 printer and choose "Printing Preferences"
  3. Click on the "Maintenance" tab
  4. Click on the "Speed & Progress" button
  5. Tick the "Disable EPSON Status Monitor" checkbox
  6. Click on OK
  7. Click on OK to close the Preferences window
That should sort you out and allow you to print in relative peace...
Cheers,
Martin
Jan 18, 2010 | Epson Stylus CX6600 All-In-One InkJet...
I can't get my Epson Nx400 all in one to print on vellum. It just spits the paper through...Help!
I had this same issue and I got the printer to print on vellum but I can't say it looked all that great. But here's what I did. I went into the printing preferences and then to the maintenance tab. On the maintenance tab you'll see an option for Printer and option information. Click on that and then you will see a little check box down at the bottom of the pop up and it says Thick paper and envelopes. Put a check in the box. Click ok and then it should print on the vellum for you. Make sure you put the vellum in the printer the right side up (front side) because if you don't it will print all messed up.
Jun 17, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Service required error
Ok.. aside from the fact that you've posted under the R300 Epson model thread you're still in luck.
The CX6600 has been documented (by me admittedly) with a complete guide to fitting an external tank and resetting the waste ink counter in the printer.
http://www.octoink.co.uk/store/pages/Epson-CX6600.html
Just to note: This is a commercial site but the information provided is generic and will help you fix the problem.
Feb 15, 2009 | Epson Stylus Photo R300 InkJet Printer
Epson CX6600 printer does not print
Make sure the tape is removed from the cartridges and that they are the correct ones for your model printer.
Jan 17, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus 580rx won't identify vellum paper
Ran into the same problem. The problem is that the printer's paper sensor sees through the vellum and therefore doesn't think any paper moved into the print position. To use vellum, fold up 1/4" edge on a standard peice of print paper and place the leading edge of the vellum under the flap. Place the paper and vellum into the printer and print. The printer will pull in the paper and the vellum together. Make the paper fold tight and straight to prevent jamming. You will need to feed one sheet at a time. Also the Epson inks take a long time to dry on vellum. I let mine dry overnight.
Jan 05, 2009 | Epson Stylus RX580 InkJet Photo Printer
Open ink cartridge holder
Here are some T/S steps for your problem:
Press the fontx1.gif Color button and open the scanner unit. Follow the messages on the LCD panel to replace the empty cartridge. See :
http://files.support.epson.com/htmldocs/cx66__/cx66__rf/ink_4.htm#replacing%20an%20ink%20cartridge%20a
Running a printer operation check
If you are unable to determine the source of the problem, performing a printer operation check can help you determine whether the problem comes from the CX6600 or the computer.
To perform a printer operation check, follow these steps.
r_1.gif Disconnect the USB cable from your computer. r_2.gif Make sure that Letter-size paper is loaded in the sheet feeder. r_3.gif Press the fontp.gif On button to turn on the CX6600, and make sure the ! Error light is off. r_4.gif Press the Setup Mode button to enter Setup Mode. r_5.gif Press the A or the fontl1.gif/fontr1.gif Select button repeatedly until 3.Nozzle check appears on the LCD panel, then press the fontx1.gif Color button. The CX6600 starts printing. The CX6600 prints an operation check page that includes a nozzle check pattern.
Compare the quality of the printed test page with the sample shown below. If there are no print quality problems, the CX6600 is fine and the problem probably lies with the printer software settings, the application settings, the interface cable (be sure to use a shielded cable), or the computer itself.
If the test page does not print satisfactorily, there is a problem with the CX6600. For example, if bands appear in the check
Please remember to rate Techs who assist you for free :)
Joe
Oct 05, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Epson CX6600 Skips every other 5th line when printing
Run the print head cleaning routine from the printers driver or control panel. you may have to run it 3 or 4 times to regain all the lines.
May 14, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Printing using Parrallels and winxp
How do you have this unit connected via parallel - there is no parallel port
Apr 22, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Epson CX6600 takes up to 2 minutes from when Print pressed to Print
Hey Zitta, Check to see that you have the latest version of the Printer Driver installed on your new drive. Go to www.epson.com and you should find your way through to your local site. Then head for the support area and look for the driver download.
Mar 08, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus CX6600 All-In-One InkJet Printer Logo
101 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
