How can I recover my windows password?
A few years ago when I bought my computer I set up a password, however, it has the fingerprint scanner so I just used that for years. My fiance tried several times to get on the computer while I was at work and it locked out my fingerprint scanner, therefore, me not remembering my password, have NO access to my computer. I dont want to wipe the computer clean, I have TONS of baby pics of my kids plus all the papers I wrote in college that I really need to save. Should I remove the hard drive and transfer the files to a portable, then reinstall windows and start over or is there an easier way to do this? ie can I override the password somehow?
    Guru:
  • 597 Answers
You should probably move the hard drive to another computer to be safe and download the saved files you need. That may be hard to do as sometimes windows will lock you out of the Documents and Settings Directory. You can use Vista though to take ownership of those directories and get your saved information.
I do notice that a lot of people that password their computers are a little sloppy when installing windows though. They kind of skip over the initial user login and password for Admin. Try logging is as Admin and use nothing for the password and see if you can log into the computer. A lot of people just hit enter when they see this screen which makes Admin and user with a blank password.
Posted on Sep 25, 2009
Testimonial: "Thank you.It's useful."
    Guru:
  • 243 Answers
I think the best solution is making a windows password recovery disk. The disk can work perfectly to recover windows password to “Blank”. It is also useful for administrator password recovery, you can wrote it to an blank CD or USB flash drive to recover administrator password. Booting up and clearing a password takes a minute or two works like a charm.
more info: http://www.windowsloginrecovery.com
Posted on Feb 26, 2010
Hp envy of unlock passeord
Which operating system ???
CMOS (Complementary metal oxide semiconductor) refers to the battery-powered, semi-conductor chip located on an HP computer's motherboard.
It is where the BIOS stores important information regarding the PC's system configuration. CMOS is required for an HP laptop and its hardware to run stably.
Sometimes, however, it is necessary to clear CMOS, such as if you lose your BIOS password or your BIOS is corrupted.
Clearing CMOS on HP laptops varies depending upon the model, but for a lot of laptops, the process simply requires removing the battery for a short period of time.
Power down your HP laptop. Remove the AC adapter and any other peripheral devices. Turn over the computer so that the bottom side is facing up.
Ground yourself, either by touching a piece of unpainted metal or by wearing an anti-static wrist-strap.
Locate the battery. This will vary depending on your laptop's model, but it is usually located on the back, near the rear of the laptop.
Review your laptop's documentation to find the battery, if needed.
Many newer models require that you remove the battery by releasing or holding down one or two latches, then gently pulling the battery out.
Some models may instead require that you unscrew the battery from its compartment.
Leave the battery out of the compartment for at least 30 minutes.
Do not attempt to turn on the computer and do not touch the battery within that time.
Some HP laptops may require you leave out the battery longer to clear CMOS, others might take only 10 to 15 minutes to reset.
Ground yourself, then put the battery back into the HP laptop.
Snap the battery latch into place or screw the cover back on, if necessary.
Removing a Bios - CMOS Password
http://www.dewassoc.com/support/bios/bios_password.htm
Disable Fingerprint on an HP Laptop
Many HP laptops include a fingerprint scanner to enhance the security of your computer.
When the fingerprint scanner is enabled, the computer requires a fingerprint scan to log onto Windows.
Disable the fingerprint scanner if you do not need or want this feature.
With the fingerprint scanner disabled, you can log on to Windows using a password.
You can enable the fingerprint scanner anytime you need to.
Access the Device Manager on your computer.
Select "Control Panel" from your computer's Start menu.
Click "Hardware and Sound" and then click "Device Manager."
Find "Personal identification devices" in the "Device Manager" list.
Click the "+" sign next to "Personal identification devices."
This opens a list of all of your devices.
Click on "Validity Sensor."
Select the "Driver" tab at the top of the properties window and click "Disable" to disable your fingerprint scanner.
The button changes to "Enable" and you can enable the fingerprint scanner at any time.
Click "OK" to exit out of the window.
Jun 27, 2013 | Computers & Internet
Tip
Forgot or Lost Windows 7 Password - Useful Solutions You Need to Know
There are many situations in life and work which may lead to or cause password lost in Windows 7. Luckily enough, there are several useful solutions that can be used to reset Windows 7 password, for whatever reason you cannot regain access to your computer. Following are listed 6 effective methods that you can make full use of to bypass a lost Windows 7 password.<br /><br /> <img src="forgot-password.jpg" /> <br />1. <b>Perform <a href="http://www.recoverwindowspassword.com/windows-7-password-recovery.htm">Windows 7 password reset</a> with an administrator account</b>. Users of administrator accounts have full control over the Windows system. They are permitted to install software programs and hardware drivers while entitled to reset password of another user accounts(including other administrator or standard user or guest accounts password). So if you forgot a user account in Windows 7, you can try to reset it through an accessible Windows 7 account with administrator permissions. It's the easiest way.<br /> <br />2. <b>Resort to Commercial Windows password recovery tool</b>. Considering the actual needs of Windows 7 password recovery when one failed to log on computer, some software providers also offer various commercial Windows password recovery tools fully compatible with Windows 7. Here we highly recommend you try Windows Password Breaker if you <a href="http://www.recoverwindowspassword.com/">forgot Windows password</a> and needed a password recovery tool, which can help you create a bootable password recovery CD/DVD or USB flash drive to reset lost password in a few minutes.<br /> <br />3. <b>Seek for free Windows password recovery tool</b>. In addition to commercial software, free Windows password recovery software out there can also help you recover a lost password in Windows 7. If you want to recover Windows 7 password without charge, Ophcrack and NT Offline Password & Register, the most popular recovery software, may be your best choice. <br /> <br />4. <b><a href="http://www.recoverwindowspassword.com/reset-windows-7-password.html">Reset Windows 7 password</a> with Installation Disc</b>. If you have a Windows 7 installation disc, it's not a big problem for you to log on your computer again if you get its password lost. Just insert the installation disc in computer and boot to the recovery options to do Windows 7 password reset. What's more, a system repair disc that also enables you to access the recovery options. But the repair disk need to be created in advance, before your password is lost.<br /> <br />5. <b>Use Windows 7 password reset disk</b>. A forgotten Windows password can be easily reset with a password reset disk, you also need to create a password reset disk for your Windows 7 account in advance(before you lost password). Please note that many users <a href="http://www.recoverwindowspassword.com/reset-windows-7-password.html">forgot Windows 7 password</a> without having created a password reset disk. If you don't have one, please start to create one right now, you will need it some day. <br /> <br />6. <b>Bypass a lost password with Fingerprint logon</b>. Nowadays password is not merely limited to letters, numbers and symbols. It can also be your fingerprint. In Windows 7, fingerprint logon can be easily enabled if you are lucky enough to have a laptop or computer with a biometric sensor, such as a fingerprint reader. If the fingerprint logon enabled, it is easy for you to bypass a forgotten or lost Windows 7 password.<br /> <br />If you have lost your Windows 7 password, select one method of the above which adapts your conditions to reset your password. At last, i recommend you to create a password reset disk when you set a Windows 7 log on password, it's a feature in Windows for one to easily reset a lost password. <br />
on Jan 27, 2011 | Computers & Internet
Recovery toshiba satellite m305 s4819
Recover windows password not a difficult thing.
I also forgot the password of my toshiba a few days ago,but I recover
windows password now by a software called Windows Password Reset ,
it is easy and effictive to use,and all systems support.
I hope it can work out for you too.
May 31, 2012 | Computers & Internet
I forgot my password
I think you need Windows Password Key. It has solved 100000 users of that problem in one year.Hope it can help you.
Related Tutorial about how to reset windows password by using windows password key http://www.lostwindowspassword.com
Feb 10, 2011 | Computers & Internet
Dell Latitude e5400 HDD password LOST. HOW TO RECOVER/ CHANGE OLD PASSWORD
If you have forget the HDD password, there is noway unless you can try it out or the Service center can help you. When I bought my new laptop, the company said that if I set a password and forget it, I only have to change HDD, and for the HDD password, only the manufacturer can get back
Jan 07, 2011 | Computers & Internet
I have HP pavilion laptop. When I reopen the laptop after sleep mode it shows user (administrator) locked. I give the user password, but it's not working. It's showing password incorrect. Is any one there...
This document pertains to the HP TouchSmart tm2-1000 Notebook PC series.
The fingerprint reader login window is not detected when the notebook resumes from a Standby, Hibernate, or powered off state. Additionally, a password cannot be entered because the flashing login window defaults the cursor to the start of the entry field.
Download and Install Fingerprint Reader Driver
To resolve this issue, download and install the latest Validity Fingerprint Sensor Driver for Microsoft Windows 7 .
Any use?
Dec 27, 2010 | HP Pavilion dv9000z Notebook
http://www.passwordseeker.com. Itcan reset almost all Windows passwords in seconds. It also compatible with windows7.
Feb 28, 2010 | AccessData Password Recovery Tool Kit (ftk...
Fingerprint reader
Hi slipknot123,
it simply means that the software for your finger scanner requires the omnipass password modules before windows allows it to work with its identification and authentication modules.
if your computer came with a built-in finger print scanner, all the drivers and the necessary software for it should have been installed already, you may also check the recovery disk that was given you when got when you bought your computer, tcheck out their site at www.softexinc.com
Hope you have a nice day
Aug 07, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Log on password not known
try administrator and admin or password or just leave it blank
Apr 21, 2008 | Computers & Internet
Lexmark x73mfp scanner to windows vista
You can use the Lexmark z42 drivers that come with Vista to make it print but I doubt you could get it to scan. New MFP are a dime a dozen these days so it may be time to upgrade.
Jan 23, 2008 | Office Equipment & Supplies
Computers & Internet Logo
114 people viewed this question
David Payne
David Payne
