Question about HP Compaq nc6000 Notebook
Missing the locking devices at the top of the monitor
Somehow the 'parts' from the top of screen that 'lock' with the bottom are gone. At the top of the monitor i see is two holes (seems missing for the part) and that is on the top left and top right.
HP COMPAQ NC 6000 Model PG592ES
Look in the 'receiver' holes on the bottom. If the little flattened "u" connectors are not in there, you are SOL. They are just pressed in and come out when they feel like it. More "high tech" engineering from HP. If they are there, make sure you press them back in in the correct direction, ie: angled toward the hinge. If you put them in backwards, they just hit on the edge of the receiver hole instead of catching on the lock mechanism.
Posted on Sep 26, 2009
Screen gone half black...tried with different CPU...same problem persist... Please advise what to do...
The effect is called fold-over, where the bottom of the screen is folded over the top half.
If you can get into the menu set up you can try and change scan settings and adjust them so that :-
1. The screen is moved down so that the bottom of the fold-over is at the bottom of the screen and the top of the windows screen is at the top (it is missing on the photo).
2. Adjust the vertical scan rate to resolve the fold-over problem.
Otherwise it needs fixing by a TV engineer that can fix monitors as the adjustments are inside.
Mar 19, 2015 | Computers & Internet
The start button is found in the upper part of the screen
Your taskbar may have been unlocked and moved to the top of your desktop. I'll continue under that assumption.
  1. Right-click on your taskbar. If checked, un-check 'Lock the Taskbar'. Otherwise, skip to Step 3.
  2. Left-click on your taskbar and drag it to the bottom of your desktop. This is the original position of the taskbar.
  3. Right-click on your taskbar. Check 'Lock the Taskbar'. (OPTIONAL)
Jun 09, 2011 | ASUS LCD Monitor
At the desk top, I moved the mouse to begin and the screen went black. All it gives is a blinking orange light. Pressing the switch doesn't matter. Upon rebooting , blinking light persists while you can...
Sounds as though you have a backlight issue. How old is the monitor?
The keyhole with the lock sign is for a security lock to lock the monitor to a desk so it cannot be stolen.
Mar 08, 2011 | Acer AL1916W 19" LCD Monitor
My dell S1709W flat panel monitor turned white
http://support.dell.com/support/edocs/monitors/S1709W/en/ug/operate.htm#Using the Front Panel
NOTE: You can also lock or unlock the OSD by pushing and holding themenu-logo2.gifbutton for 15 seconds. (Top of the buttons on right side)
Apr 07, 2010 | Dell Computers & Internet
Blue screen moved right. can't move it back to see my entire desktop
OSD Lock/Unlock
Allows you to secure the current control
settings so that they cannot be
inadvertently changed. You can unlock
the OSD controls at any time by using
the same procedure.
Push and hold the Menu ( )
button for 10 seconds or more to Lock
or to Unlock.
May 03, 2009 | Computers & Internet
How do I fit monitor Samsung SyncMaster932gw
just regix your bottom part of lcd there is lock system press top to bottom thenit locked.
Jan 19, 2009 | Samsung SyncMaster 932GW LCD Monitor
How to clear control lock
Replace the 5volt regulator ic, LM7805, location IC602..
Michael Sathe
HCL Infosestems Ltd.
Nov 10, 2008 | SAMTRON 55V 15" CRT Monitor
Osd locked
I had precisely the same problem... I depressed the Menu Button for about twelve seconds or more and the menu actually finally popped up; and does so now every time I depress Menu! Hope this works for you.
Big Jim
Dec 30, 2007 | HP vs15 15"LCD Flat Panel Monitor
Horrizontal line in bottom of screen shifted the whole screen up
if your monitor has a reset button, press and hold it for 3 to 10 seconds.
Dec 24, 2007 | Philips 150S4FB 15" LCD Monitor
HP Compaq nc6000 Notebook Logo
27 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
