Question about Hitachi 42HDS69 42 in. Plasma Television
Hitachi 42hds69 turns on for about 20 minutes then shuts off. I unplug and then plug in and it turns on.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 92 Answers
There is a componet that is heating up on the board then shutting the tv off when it fails, it is cooling off and working again. The problem is this can only be fixed with a diagram of the board to locate the faulty part. You will have to take it in to a service center for work. Sorry for the bad news, I hope this helps a little.
Posted on Sep 25, 2009
Hitachi 2006 42HDS69 will not detect signal from dvd or xbox, how do I fix this?
Check the error codes on the digital board, which is visible through the grill in the back where the AC power entry is located. A trouble shooting guide, including the error codes, can be found in the service manual here: http://elektrotanya.com/hitachi_42hdx99_42hdt79_42hds69_chassis_dw2-u.pdf/download.html
In the case of my TV, I had to replace the main digital board. I was able to find one online for about $80 and replace it myself. Once you get the rear cover off the TV the digital board is easily accessible and took maybe 20 minutes to replace. Good luck!
Jun 27, 2014 | Hitachi 42HDS69 42 in. Plasma Television
TV does not power on. For the last several months I would have to unplug it then plug it back in to get it to turn on. It makes a clicking sound when plugged back in similar to the same sound it normally...
I have similar problem with my 42hds69. What I did is unplug the tv and remove the cover and vacuum everything especially the fan and remove the power supply board and brush/vacuum the back side... careful about static so hold the metal frame while you're vacuuming. Reassemble everything... mine worked... and still working... Good luck.
Aug 04, 2010 | Hitachi 42HDS69 42 in. Plasma Television
Have red light tv won't turn on
I have a post about this, go find it. It's about cleaning the back of the tv. Good luck.
Jul 29, 2010 | Hitachi 42HDS69 42 in. Plasma Television
HItachi Model 42HDS69 Stuck in Standby
Tv problems?. any warrenty on the set? how old is the set?
Mar 18, 2010 | HP Televison & Video
My 42HDS69 Hitachi has a recurring problem of not turning on. I unplug from outlet for awhile and sometimes it will turn after I plug in outlet, Other times it takes a few hours for TV to turn back on. ...
MY TV KEPT GETTING WORSE EACH DAY ALSO. BUY A CAN OF SPRAY AIR WITH THE EXTENSION SPRAY TUBE. WHEN YOU GET THE TV RUNNING SPRAY THROUGH THE HOLES IN THE BACK RIGHT ONTO THE FAN BLADES OF BOTH FANS. THE DUST WILL FLY OFF THE BLADES. A VACUMM HOSE WILL HELP PULL OUT THE DUST. ALSO SRAY THE POWER SUPPLY BOARD FOR DUST. I APPEARS THE FANS SLOW DOWN WITH DIRT ON THEM AND THE EXTRA HEAT BUILD UP JUST AFTER THE TV IS SHUT DOWN IS CAUSING THE POWER SUPPLY TO BE IN A SHUT DOWN MODE WHEN POWERED UP THE NEXT TIME. BEEN TWO WEEKS NOW AND WORKS PERFECTLY NOW AGAIN.
Dec 17, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Picture went out when I changed the cable channel
Check this forum thread:
http://www.avsforum.com/avs-vb/showthread.php?t=778593
Jan 27, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Loud noises
Try resetting the TV. Unplug the AC, wait 1 minute then replug it. If not fixed, its requires service.
Aug 28, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Hitachi 42HDS69 42 in. Plasma... Problem
Describe the past - How did it fail? One day or acting up for a while? Could be a weak power supply - a bad capacitor on a power supply too. Look for popped up capacitor top inside.
Apr 29, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Hitachi 42HDS69 42 in. Plasma Television Logo
310 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
