Question about Nintendo DS Lite Console
Ds Lite Hi the back of my sons Ds lite is very loose, it moves around 6 mm so you can see inside the ds a bit I was wondering if there were any screws that could be tightened to make it better - the only screws i can see are at the bottom of the console, are there screws under the little rubber feet? what can i do?? lol please help
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • Nintendo Expert
  • 127 Answers
You may buy the screws here:
nintendo-ds-and-ds-lite-screws-and-springs
But my opinion is to go to a hardware store with a sample (cant be too long, the original ones are aprox 3mm long X 1mm diameter), try to find screws that fit and use normal philips screws instead these tri winding screws as you would need a tri winding screwdriver to put the original screws in place. All the screws in the NDSL screw in the plastic case except for the battery one that screw in a squared nut.
Good Luck...
Posted on Dec 22, 2007
The top screen on my DS Lite lights up but there is no picture, the touch screen works fine and so dose every thing ellse.
Chances are the screens ribbon connectior has become loose or the screen has develouped a fault.
If its under warranty then send it in, otherwise you can take it to a local repair shop or do a bit of DIY.
Take the DS lite apart (a tri wing screwdriver is needed and can be found cheap on ebay), disconnect the top screen by lifiting the motherboards connector flap (located near the hindge) and then re-insert it, try switching it on again and see if thats sorted it. If not then you will need to replace the screen.
A new screen can be brought on ebay for a reasonable price, there will be a little soldering required as the speakers will need to be de-soldered from the old screen and re-soldered onto the new one (please take note of which wire goes where).
Remove the screws from the lid of the DS lite (4x screws hidden under little coloured squares above and below both speaker outlets) slide the top/outer part away from the hindges, it will move about 5mm and then you can lift it off... Gently pull the ribbon through the hindge so that it is free from the bottom part of the DS lite, pry the screen away from the shell (a small amount of force may be required to remove it) remove the front plastic part of the screen (with the respective DS lite coloured frame, de-solder the speakers, re-attatch them to the new screen, place the new screen into the housing along with the speakers and put back the wifi and mic to their original position if they got moved, you will notice a slot in the hindge where the ribbon goes in, this is for the ribbon to easily slide back into the bottom part of the DS lite... pop the ribbon through and then re-attatch it to the motherboard with the connector, pressing down the connectors flap.
Screw the DS lite back together and hope fully this has resolved the issue.
If you find that your DS lite now doesn't want to stay powered on please refer to my other tips and tricks I have issued on here.
I hope this helps and have to say that I accept no responsability for any damage that may occur to your DS lite when following these tips.
Regards,
SOD69
Feb 07, 2010 | Nintendo DS Lite Console
Hello...i have a problem with my son's ds lite, the hinge is broken, can it be fixed?
yes check ebay for hinge axle ds lite, from what i understand their are 2 types so make sure its for ds lite, should be around £4.99 with a screw driver lol
Jan 23, 2010 | Nintendo DS Lite Console
My sons ds lite has a jammed l button please help
with a special tri screw driver open up the DS from underneath theres about 6-7 screws, hidden one's are under battery in the corner, one in game card slot and two under the rubber padsRemove slot 2 cover. Carefully ease the back off the L and R buttons are spring loaded so hold them down so you don't loose track of how they are fitted. If the micro button has to be replaced then you will need to solder it in. The part is about £5. If you are in the UK and can't find anyone to fix it get back to me.
Dec 28, 2009 | Nintendo DS Lite
Ds lite saying no ds card and no game pak inserted
Defecttive Slot 1
Look inside with a litte light. You will almost certainly see bend pins. You son has almost certain play with someting sharp inside the connector.
Slot1 must be replaced
Apr 21, 2009 | Nintendo DS Lite
DS Lite game card won't "click" into slot
Slightly push once. If too fast come out.
If still, back to nintendo
Apr 16, 2009 | Nintendo DS Lite Console
Nintendo DS Lite
If you want get some tools and take the ds apart.make sure all the pieces are straight and are put together right.if there not straight,make them straight.if there not put together,put them back together.Hope it works.
May 23, 2008 | Nintendo DS Lite Console
DS Lite Circuit Board Problem
no i tried it just melted the inside of the ds i dont recamend it call tech support or take it back i did
chris
Mar 31, 2008 | Nintendo DS Lite Console
Ds lite
Components may have come loose on the board, or damaged solder joints. Water damage can sometimes only appear after water has had time to seep, unless knock helped throw some residual water around inside, onto things it shouldn't touch.
Dec 02, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
55 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
