Question about Leader 2" 30 IPS AES 16 Minutes 355 nWb/m MRL51L414
Plantronics Audio 355 mic does not work in TF2.
Plantronics repair
Have you got that particular headset enabled in audio settings.
If you are talking about Skype: click Tools - Option -Audio Settings- Microphone then the down arrow at the extreme right of the mic name box, select your mic if it's name is in the drop down menu.-- scroll down and click Save. then test it.
Good luck
Mar 11, 2014 | Plantronics audio 655 Dsp Usb Headset For...
Compatilble with macbook?
If you just plug the headset into your computer's USB port you should be good to go. With these headsets, there's no software to install, no configuration, etc. So it should be compatible with macbook
Jul 19, 2012 | Plantronics .Audio 355 Multimedia Headset
My right side of the headphone is not working.....not any physial damage.....at first there were just some loose connections for the sound....now its totally null......the left side is working perfect...
If you have preformed a sound test on your computer and everything seems to be working fine, I would assume the connector or cable itself is the problem. Contact the store you purchased it from or If the unit is under warranty (1 year) Plantronics will replace if for you if you still have your receipt of sale.
Good luck from Headsets Direct - 800-914-7996.
Aug 13, 2011 | Plantronics .Audio 355 Multimedia Headset
When I plug in my Audio 625 Plantronics to my usb port it shows an error - Device not recognized, please help..
If you are using a Mac computer your Plantronics .Audio headset will not work The microphone plug on the .Audio analog headsets is not compatible with a Mac. It will physically fit into the Mic input jack on a Mac; however, it will not function. Basically, the digital sound card does not recognize the analog signal coming in from the headset.
Good luck from Headsets Direct!
Apr 16, 2011 | Plantronics Audio 625 Headset
I have been using Plantronics 995 for several weeks. I quit working without any system cnanges. Have tried re-paring, and reset all audio settings to plantronics. Bought replacement unit ( plantronics...
this is a normal reaction ..specially on a wireless device ..the idea is to lower the volume into the computer ..(to max 80%)..and also get into the volume control by double clicking on the speaker icon in the task bar ..and in here look at the mic volume
if there isnt any volume section for the mic..than click options ..than properties..and from the list tick the case for mic in ..and will list the volume for mic..
if the advanced function is on ..check into the advanced under the microphone it is started the mic boost function ..if it is ..and you want to keep it for a better mic reception ..than you have to put the mic on mute to eliminate the static noise..
THis should not mute it for good..but you can make a trial to be sure..
If the advance boost function is on ..and the muting puts it out for good..the choice is to get rid of the boost but usually works if you mute it ..cause only mutes the noise ..
let me know if you didn't understood anything ..
Sep 03, 2010 | Plantronics Radio Communications
The microphone on my headset does not work
there must be a problem in the jack ,, try another one, if it work, then your headsfree need a replacement
Jan 08, 2010 | Plantronics .Audio 355 Multimedia Headset
Mic not working (plantonics headset)
Your exterior mic MAY have been the one ACTUALLY working rather than the one on the headset. Some mics require a battery for the mic part to work, Not sure about your particular Plantronics. If it has a battery, then check the battery as the receiver part does not use it but the mic MAY use it.
Oct 06, 2009 | Plantronics Radio Communications
Electronics - Others Logo
240 people viewed this question
Top Leader Electronics - Others Experts
Are you a Leader Electronics - Other Expert? Answer questions, earn points and help others
