Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Grease ring left in washer after washing clothes used in working on cars
  • 403 Answers
My son did the same thing, and also with dye. What you have to do is get some heavy duty cleaner like for cleaning driveways. Use rubber gloves and sponge the inside. After is soaks in you have to use more with a green cleaning pad and clean as far down as you can reach. Wash. After first wash, wash again with just the cleaning solution as if you were washing laundry soap, maybe a dab more. You should see a noticeable difference.
JimmyC
Posted on Sep 25, 2009
A407 maytag washer getting grease on clothes occassionaly what would the replacement part
Maytag washing machine gets grease on clothes ... - Fixya
www.fixya.com/.../t14582529-maytag_washing_machine_gets_grease
Oct 8, 2012 - Maytag washing machine gets grease on clothes occasionally. ... some of their clothes ruined by grease stains from their front loader Kenmore. .... remove the agitator from a Maytag washing machine Model A407 series 02?
Aug 24, 2015 | Maytag Washing Machines
What should I do to stop washer from putting grease on clothes?
Good Afternoon Bernard,
I understand the washer of your Frigidaire laundry center, model# GLEH1642F, is leaving grease in your clothes. I also see that you noticed the grease in the detergent cup. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine where the grease is coming from to be able to repair your appliance. Hope this is helpful.
-Best Regards-
WP
Jul 01, 2014 | Frigidaire GLEH1642F Front Load Stacked...
Pressure washer lost pressure in the middle of a job
The pressure valve has stuck in the high pressure position. This prevents anymore inflow and hence no further water will be pumped.
Rebuild the valve... There are O Rings to replace and clean the bore with croocus cloth. Lube the O rings with plumber's grease... good as new! 15 minute job. Get EXACT sized O rings for the unit.
May 16, 2010 | Honda Pressure Washer PSI 3000
Grease gets on clothes from inside washer - not always but often enough to ruin several items. Also, once in a while it makes a "not normal" louder sound when spinning. We inherited this washer/dryer combo...
hello. generally this mystery grease comes from an article of clothing placed in the machine, not the machine itself. Problem is once that grease gets in the machine it can stick to the tub and contaminate other clothes in later wash loads. Look for the grease and wipe it away with a product like 409 degreaser. Regards, Joe
Jan 28, 2010 | Washing Machines
Washer leaves spots on clothes
wipe the inside of the washer with a clean white cloth and see if anything shows up, it may be an ink pin that was left in the wash or a leaking seal that is letting grease enter the washer tube from the washer tub bearings.
Oct 01, 2009 | Frigidaire ATF6000ES Front Load Washer
ON the second wash I did today, after the second wash my clothes came out with streaks of black. What would cause this?
Grease is leaking into the drum under the agitator cone.
Remove the agitator cone. There will likely be a removable plastic piece with an O-ring. Oil could be leaking out of the O-ring into the washer, and water could be leaking into the bearings. If there is damage to the O-ring replace it, or if there is a bunch of schmag that is compromising the seal, clean it out, and re-install everything. This solved the problem in my washer; hopefully it works for you.
Sep 29, 2009 | Kenmore Washing Machines
Grease oil ring around tub and it smells like oil?
The only place there is oil in a washer is inside the transmission. If you have oil in the tub (and it didn't come from the clothes you put in) you have a bad transmission seal. It is generally cost prohivitive to replace the transmission. It's time to get a new washer. Look into the front load machines which use much less water and spin out twice as fast as top loaders. Some even have direct drive, which means no belt, transmission, or clutch.
Jul 19, 2009 | Washing Machines
Oil ring left in tub and on agitator
If its oil your transmission is leaking oil. Time for a new washer.
Mar 21, 2009 | GE WJSR2070B Top Load Washer
Grease stains on clothes from LG washer (tromm 2688)
We run a small hotel and have been having this same problem with our LG Direct Drive WM2301HW... but the stains aren't grease at all... they're from sledge buildup in the washer. I found this out when I cleaned the lint trap behind the small door at the bottom left, on front of the machine. I ran my finger around the interior and found it lined with black, stinky muck. Due to the low position of the filter, this area never fully drains, so the muck collects and the bacteria grows. Of course, this means the pipes or hoses to the filter are probably also lined with this muck.... Poor design!!! Try running the washer empty (no clothes) with a couple cups of honest to goodness chlorine bleach. Then run it again to make sure all the stuff that came loose gets pumped out.
Jul 16, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
71 people viewed this question
Dan Webster
Dan Webster
Sal De
