Question about Sony Computers & Internet
My Sony PCG-FR130 laptop has a screen problem. The screen flickers and is very dim. When I hook up an external monitor it does not display.
  • Anonymous Mar 26, 2014
    2320 dell all in one screen flickers on and off . I have a external monitor hooked up and that works fine any recommendations ?
  • 797 Answers
Most laptops have a setting to change to external or some will display both at the same time. See what the settings are capable of in your user manual. If you do not have it, look it up on the web.
Posted on Sep 25, 2009
Dark screen and flickering on the laptop computer model pcg 61611L
I would check the GPU by connecting an external monitor before booting it, that will allow the external drive to automatically work.
Jan 02, 2014 | Sony VAIO Computers & Internet
I have a Sony VAIO PCG-K25 Notebook Problem. When I Push the Power on Button, A flickering white screen comes up. The system goes throught boot up just fine but the LCD screen remains white. When hooked...
Hello
These symptoms are not the inverter problem, What can you do if the laptop LCD screen turned completely white? From my experience I can tell that this problem may be related to the following: 1. Loose connection between the video cable and the LCD screen. 2. Defective LCD screen. 3. Defective motherboard (I assume the graphics card is integrated into the motherboard).
Check these by yourself or get assistance from sony support.
Good Luck
Dec 22, 2010 | Sony VAIO PCG-K25 Notebook
My laptop comes on, and the screen stays blank, (black ) nothing, I tried hooking up an external monitor but it does nothing also, could the invertor be the cause? Unit is a Sony VAIO PCG-TR3A
If the invertor was faulty you would get a picture on the external monitor, assuming that the external monitor and the laptop was configured to work. Check the Fn key and F5 at the same time. That should switch between internal/ external or both displays.
Hope that helps.
Dec 09, 2010 | Sony VAIO PCG-TR3AP1 Notebook
Sony vaio vgn nr160e laptop - no display (intermittent). Attached monitor shows display fine and laptop works fine. Screen used to flicker intermittently (last few days).
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Oct 20, 2009 | Sony VAIO VGN-NR160ET Notebook
My sony vaio vgn-n365e screen is Dim
The fault could be a faulty CCFL lamp or inverter.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 24, 2009 | Sony VAIO PCG-K23 Notebook
Sony vaio PCG-GRT30P Screen Problem
You could have a defective screen, either a faulty inverter or a CCFL lamp - follow this to determine the fault.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 15, 2009 | Sony VAIO VGN-NR220E/S Notebook PC
Laptop screen flickers and goes off .
You could have a faulty inverter but
You most likely have a defective CCFL backlight, it may have the following symptom:
Apr 13, 2009 | Sony VAIO VGN-C140G/B Notebook
My Gateway mx7118 lcd flickers whenever screen is opened,closed,
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the laptop's LCD screen it means you have a backlight problem.
Mar 13, 2009 | Gateway MX7118 Notebook
Pcg-xg28 no display
Either the video card is bad, or the memory is bad. Replace the memory first to see if that fixes the problem. Also, if capable, reseat the CPU, which is located beneath the Keyboard.
http://www.Computer-Repair-Today.com
Nov 28, 2007 | Sony PCG-FR130 Notebook
Sony Viao Display Problem
Sounds like you have some internal issues going on with this Laptop! If you are getting the same response when you connect an external monitor, then you more than likely have a few things going on here: A bad VGA port for starters, Issues with the Data card, and your graphic card is cetainly not helping. In addition you may want to check appropriate drivers as they are sometimes updated! But my best guess is that you are having issues internally! That could be costly! Sorry!
Nov 26, 2007 | Sony PCG-FR130 Notebook
Computers & Internet Logo
70 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
