Question about Samsung Digimax S730 Digital Camera
Lens is extended will not close, put new batteries in green light comes on for few seconds but lens will not close and camera will not come on
SOURCE: the lens doesnt close, the camera beeps 3 times and shuts off.
Hi just had the same problem I freaked out and then read that about the lenses problem so I figured screw it if it is broke I have to go out and buy a new one anyway....BUT I yanked a LITTLE on the lens and poof fixed it....
Posted on Oct 17, 2007
SOURCE: my camera will not come on
I had the same problem with the samsung s630 with the lens stuck open, I would turn on the camera and then it would beep 3 times then automatically turn it's self off. I tried using new batteries and chargeable batteries nothing was working and the lens was stuck causing the camera to shut down. I tried to twist the lens to get it unstuck, eventually it did get unstuck and now the camera is working fine.
Posted on Jun 15, 2008
SOURCE: Camera shuts off after a few seconds
i had that problem with another camera i toggled with the lens it went in and works like a charm. Dont be to gentile it will go in
Posted on Oct 29, 2008
SOURCE: Camera will not turn on sucessfully. Says "Turn Off and On Again"
This is not an elegant solution, but it seems to be working. (I might have read some one else mentioning it for another brand of Samsung camera). I hit the end of the camera where the attachment to the computer gets plugged in against the palm of my hand pretty hard about 6 times. Then I tried it and it worked! There is some logic there since it started having the problem right after I put it down on a soft surface from about three feet.(Ididn't really drop it, but tossed it there - gently, I thought - because my hands were full and I was starting to lose everything). In the future I will treat the camera a little more gently knowing that mechanism is somewhat easily knocked out of adjustment.
Posted on Mar 26, 2009
SOURCE: I turn camera on. Lens comes out. beep 3 times. turns off.
Everytime I try to turn it on, the lens comes out for about a second, the camera beeps 3 times, the lens retracts and the camera shuts off. The battery is completely charged and the camera is only 4 months old. HELPP :(
Posted on Jun 17, 2009
It doesn't work any more
Try NEW Hi performance battery, Li is probably best. cheap or old batteries will not give good performance in this camera.
Dec 20, 2011 | Samsung Digimax S500 Digital Camera
Hello, My camera M1093 IS suddenly will open when I hit the power button only to close immediately. The screen comes on for a second and then it closes. I ordered a new battery thinking that may be the...
Could be something stopping the lens to go out all the way. It will automatically retract and turn off if anything prevents it from extending. It could be the motor or whatever but I would definitely contact kodak. Also could be something like a short or software malfunction but it sounds like a problem with the lens not being able to extend fully out.
Jul 30, 2010 | Kodak EasyShare M1093 IS Digital Camera
Camera turns on then off immediately
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 04, 2009 | Kodak Easyshare M893 Digital Camera
Camera not coming green light just blinking
Try 4x normal AA batteries. (new)
Also ensure that the memory card cover is firmly closed.
Mar 07, 2009 | Polaroid i733LP Digital Camera
Cannon G7 need help
Hi
Had the same problem a few months ago.There was a high pitchedwhisltle and I think the screen said "lens fault.turn off camera" or something similar.Bought a G9 to replace as the 7 was out of guarantee but sent the 9 back to the e-bay reseller as it was obviously secondhand with grit around the lens ring and the viewfinder.Ebay never again!.So 3 months ago ago I tried the G7 again with a fresh charged battery before I consigned the camera to the loft.I noticed that each time i switched on the whistle and message was there but the lens extended slightly further each timeso I kept rebooting until the lens was fully extended.Turned the camera off and on again and everything was back to normal.It seems that this may be Canons protocol when a camera goes back.Its been absolutely fine until today.It wont boot up at all.I have tried 2 fresh charged batteries and its dead.Any ideas anyone?
Nov 06, 2008 | Canon PowerShot G7 Digital Camera
Kodak Easyshare CX7530 won't stay powered on
I have the exact same problem. Can anyone help?
Apr 03, 2008 | Kodak EasyShare CX7530 Digital Camera
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Camera Wont Turn on
Please eject camera battery and clean with a pin your battery tip in your camera with care fully.d36f20d.gif
Hope its helpful to you
Oct 17, 2007 | Samsung Digimax L60 Digital Camera
Won't turn on! Possible lens problem?
My daughter just had this problem with her camera. The camera was off with the lens barrel extended. When I looked at it closely, I noticed that the inner part of the lens barrel was at a slight angle to the camera. I pushed firmly on the low side of the inner part of the barrel, and it popped the rest of the way out. Camera works fine now. Good luck!
Jun 16, 2007 | Polaroid i733LP Digital Camera
After switching on - the lens extends and retracts repeatedly
I had the same issue and thought me Ebay camera was trash. I put the batteries back on the charger over night and it worked properly in the morning. Looked to be a low power issue, but my lens did look like it was all cocked, grinding and stalling. perhaps the camera reset itself with no batteries in it for a few hours> I was very relieved.
Jun 13, 2006 | Olympus Camedia C-5050 Zoom Digital Camera
Samsung Digimax S730 Digital Camera Logo
50 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
