Question about Vivitar ViviCam 3750 Digital Camera
I can't get it to flash - Vivitar ViviCam 3750 Digital Camera
  • redaalasy310 May 11, 2010
    u see this sign on front of camera lens looks like pyramids turn camera lens on it and flash will work
    Problem Solver:
  • 17 Answers
First turn ur camera lens wheel on the pyramid sign on the front 2-use the right side of the back button (push)that have zigzag sign to change ut flash mode for ur pics
Posted on Feb 26, 2010
Nokia x300 flashing
Did the phone flashing it's display and boot to normal mode itself ? If not follow this Click here1 or you can contact mobile repairing shop, you need to flash/update the firmware because the operating system of your phone is corrupted.Here is the link of your flash file ALL Nokia Flash Files,flash files download site,Free Nokia Flash Files,latest nokia flash file free,phone Flash Files,mobile flash files,nokia firmware,free all nokia flash files,Blackberry Flash Files,iTablet Flash Files,JAFMain SoftwareThanks for visiting fixya.Good luck
Mar 09, 2012 | Cell Phones
How do you turn o and off flash
Your camera has 4 modes flash function : 1; Flash Off ( flash will Off in any shoot) 2. Flash Fill in ( flash always On) 3. Auto Flash (Camera decided flash) 4. Red Eye reduction flash ( Camera decide flash).
You can set your flash base on your need.
Nov 29, 2010 | Polaroid i531 Digital Camera
I have this Electro GSN one. When I mounted a normal flash, the flash doesn't function. What is the solution? Does it need a special flash which differently? Thanks for your helps. Reap
You can use any flash that has one contact at the shoe.
Try using the PC flash cord to the flash socket on the camera body and see if the flash fires. If you see flash with pc flash cord and not with the accessory shoe, try cleaning the flash contacts at the hot shoe.
If no flash either using the hot shoe or the flash cord, try testing the flash. If the flash is good, you have to open up the camera to trouble shoot. The flash wire is connected to the shutter's flash contacts.
Jun 01, 2010 | Photography
Engine code
12 and 55. The 55 means end of code session, the 12 means no distributor reference. Both of these codes are normal with the engine not running, so do not go out and purchase a dstributor. Is there another problem with the vehicle, or did you just want to know the codes? Comment back to continue,thanks.
May 26, 2010 | 1995 Jeep Grand Cherokee
Check engin light
it is flashing the codes if you got the sequence right it is codes 12,21,55 what engine? 12 battery disconnect,21 isO2S shorted to voltage, and 55 is MIL may not come on
Mar 05, 2010 | 1995 Jeep Grand Cherokee
My Hotpoint Aquarius WF430 1300 doesn't complete its cycle, it stops after the wash & doesn't go on to the rinse & final spin. It seems to "freeze" after the wash is finished as the lights remain...
If your lights are flashing, use these codes to pinpoint the error.
These codes are reading from the top neon down.
F01....OFF, OFF, OFF, Flash, OFF.
F02....OFF, OFF, Flash, OFF, OFF.
F03....OFF, OFF, Flash, Flash, OFF.
F04....OFF, Flash, OFF, OFF, OFF.
F05....OFF, Flash, OFF, Flash, OFF.
F06....OFF, Flash, Flash, OFF, OFF.
F07....OFF, Flash, Flash, Flash, OFF.
F08....Flash, OFF, OFF, OFF, OFF.
F09....Flash, OFF, OFF, Flash, OFF.
F10....Flash, OFF, Flash, OFF, OFF.
F11....Flash, OFF, Flash, Flash, OFF.
F12....Flash, Flash, OFF, OFF, OFF.
F13....Flash, Flash, OFF, Flash, OFF.
F14....Flash, Flash, Flash, OFF, OFF.
F15....Flash, Flash, Flash, Flash, OFF.
f16....OFF, OFF, OFF, OFF, Flash.
F17....OFF, OFF, OFF, Flash, Flash.
F18....OFF, OFF, ON, OFF, OFF. Fault on control board, check Eeprom.
these are the codes and this is what they mean
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
also try checking this manual
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/WFseries_19504110305_Jan05_book.pdf
Mar 05, 2010 | Washing Machines
Check engine on jeep grand cherokke 1995
Try again and verify, for example.
3 flashes,pause,then 3 more, is 33. etc.
5 flashes, pause 5 more, is code 55.(end of message)
always 2 digit number, then slightly longer pause in between those 2 digits.
Feb 23, 2010 | 1995 Jeep Grand Cherokee
Led with number 9 displayed is flashing
LED 9 flashing can mean many things. Here is the list of "flashing codes" for the vostro 1510.
Keep in mind a flashing led is going to blink 3 times. for example,
number one would look like this:
On (solid lit). Blink, blink,blink (paused off) blink, blink, blink... (paused off), (then repeat)
1. ON-FLASH-FLASH = No Ram or ram not seen
2. ON-FLASH-ON = Ram has a problem
3. FLASH-FLASH-FLASH = Motherboard failure (replace board)
4. FLASH-ON-ON = CPU Fault/failure
5. FLASH-ON-FLASH = LCD detect failure/fault
6. ON-ON-FLASH = MINI pci card (controller) failure/fault
7. FLASH-FLASH-OFF = Keyboard fault/failure
8. FLASH-OFF-FLASH = USB FAILURE
9. FLASH-FLASH-ON = Video BIOS or BIOS issue
10. ON-FLASH-FLASH = Modem issue
Depending on the blinking code, you might just need to re-seat or replace your RAM or your CPU. But then again, you could have a more severe motherboard issue.
Nov 01, 2009 | Dell Vostro 1510 Motherboard System Board...
Built-in flash and an external flash simultaneously
Yes, please see the following table: Optional Flash Flash Control Mode Capacity FL-50 TTL Auto (Super FP flash)/ TTL Auto/ Auto/ Manual/ Manual (Super FP flash) The FL-50 flash can be connected with the E-300 camera through flash power grip: FP-1 and flash cable: FL-CB05. FL-40 Auto/ Manual The external flash cannot be used with the built-in flash. * Only Auto and Manual mode can be set in the concurrent use of FL-40 and the built-in flash. (For their specification design, E-300 and FL-40 can not communicate in TTL Auto and R-TTL Auto modes.) FL-36 TTL Auto (Super FP flash)/ TTL Auto/ Auto/ Manual/ Manual (Super FP flash) The external flash can be used with the built-in flash.
Sep 04, 2005 | Olympus EVOLT E-300 Digital Camera
Flash Problem
Using the flash When shooting with the built-in flash, open the flash manually. The flash does not pop-up automatically. The flash will not fire if it is closed. The flash will work when it is opened up. When the flash is open, the (flash on) icon or (automatic) icon will appear on the LCD monitor (or in the viewfinder). Flash on: The flash fires in every shot. Automatic: The flash fires automatically. Press the (flash) button to switch between the and flash modes while the flash is open. In some shooting modes, the flash mode does not switch even if the flash button is pressed. Please refer to Functions Available in Each Shooting Mode in the Camera User Guide provided with your camera for more information. When you are not using the flash, close it manually. When the flash is closed, the flash will not fire and the icon appears on the LCD monitor (or in the viewfinder).
Aug 31, 2005 | Canon PowerShot S2 IS Digital Camera
Vivitar ViviCam 3750 Digital Camera Logo
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
