Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
Instructions not clear to me for my Magnavox disc and cassette re
I bought a reconditioned Magnavox digital video disc recorder & video cassette recorder (#ZV457MG9), and the instruction booklet is a photocopy; therefore, the colors on the cables for connecting parts are not distinguishable. I am not good at this stuff anyway. Can you send me an instruction booklet in color?
Also, must I disconnect my converter box in order to connect the recorder. Should I be connecting the cables to the converter box rather than to the TV? Thanks.
Nora Kancelbaum
Magnavox ZV457MG9 A DVD drawer won't open
one of the faults with the home dvd player it seems we have to open them to remove the stuck dvd .and more often than not we end up braekingthe danged thing anyway
Mar 15, 2015 | Magnavox Televison & Video
My Magnavox Digital Disc Recorder & Video Cassette Recorder will not play DVD-RW discs. How can I solve this problem or get a replacement unit.
It claims to play -RWs finalized in DVD-VIDEO format, not VR. If a disc is recorded/finalized on a different recorder, not all players can play it. This is the price we pay for the convenience of the digital system.
Feb 11, 2013 | Magnavox ZV427MG9 DVD Recorder/ VCR
I have a Magnavox Digital Video Disc Recorder & Video Cassette Recorder. Model# ZV427MG9 A. When recording from a VHS home movie tape to DVD there is a high pitch squealing sound. When playing the DVD...
U play another movie like a Hollywood movie DVD disc play on it have no squealing noises wright?Yes,than the blank DVD discs batch u have is bad.Tries buy another batch DVD blank discs,tries recording again should solved this problems.
Mar 16, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
I have a Magnavox Digital Video Disc Recorder & Video Cassette Recorder , Model No. VM426MG9A. I bought the unit in August 2010. When I go to record a program, it seems OK but when it starts...
The recording set-up must have been program to record only in 5 minutes. You could play around with the remote and try to enter the record set-up. The problem with the VCR must be a worn-out belt or a dirty loading mechanism. You could try to replace the belt or clean the surface area where all the mechanism slide together or make contacts and put an small amount of recommended grease or petroleum jelly.
Jan 03, 2011 | Philips Magnavox DVD+R/+RW Recorder/VCR
Magnavox ZV450MW8A DVD/VCR Recorder Dubbing.
I bought a ;magnavox dvd disc and cassette recorder combo.
I am having trouble with setup items? I get nothing on the screen to select from?
Oct 24, 2009 | Televison & Video
I Have been trying to dubb VHS tapes to DVD''s. They record alright, but then when I go to play them on another DVD player they won't do I get them to finalize? I have went through the menu and...
--- for some reason this unit does not finalize automatcally.
--- the instructions for finallizing are on page 52 of the owners manual.
--- they are as follows:
1) Press Setup
2) Scroll down, select "Disc Edit", press "OK"
3) Scroll down, select "Finalize", press "OK"
4) Select "Yes", press "OK"
Finalizing will start.
--- have done this operation several times, works Ok.
Jan 05, 2009 | Philips Magnavox DVD/VCR Dual Player
Zv420mw8 magnavox vhs to dvd recorder
I have lost my remote to my Digital Video Disc Recorder with Videeo Cassette Recorder #ZV420MW8. I would like to know how to go about getting a replacement. Thank You, Diane Wotton
Oct 31, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Viewing a recorded DVD+R on PC
I am assuming you have an actual dvd drive of some sort installed in your computer. The problem you may be having is a missing codec. This problem can be solved by downloading a VLC player which has most needed codecs pre installed. This program is freeware and can be easily found online. I hope this helps. Good Luck!
Jan 28, 2008 | Philips Magnavox DVD/VCR Dual Player
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
56 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
