What may also help is to reset the internal charging circuit: remove the battery and hold down the Roomba's [Power] button for at least 10 seconds, then re-install the battery and charge for 16 hours.
There's a chance that the battery you bought is bad. There's a greater chance that the problem is with the charger. If you're using the dock to charge, try plugging the charger directly into the roomba just to rule that out. If that doesn't fix the problem, I would try borrowing or buying a new charger, and see if that works. If a new charger and new battery don't solve the problem, the problem must be with your roomba itself.
Was this helpful?
Yes
No
Popular Solutions for Roomba Robotic Floor Bagless
When I press the start button it makes a noise, turns red and doesn't start. Has been charging for...
(More)
When I press the start button it makes a noise, turns red and doesn't start. Has been charging for months.
roomba is on, but it won't clean when 1) I press the clean button, or 2) when I schedule it. I did...
(More)
roomba is on, but it won't clean when 1) I press the clean button, or 2) when I schedule it. I did try pulling it away from the docking station and it did go back to the station...without cleaning. Help, MIL is on her way!
The last 2-3 cleaning rounds, the dirt cup was empty at the end of a cleaning session, and this is...
(More)
The last 2-3 cleaning rounds, the dirt cup was empty at the end of a cleaning session, and this is NOT normal. The filter DID have the usual dust on it. So tonight, I unscrewed several layers, cleaned out debris, and replaced the parts and the brushes. But this time, after turning it on, Roomba made a clicking sound every few seconds. I removed the dirt bin to look at the brush, and it would make 1/8 turn, click, and stop -- then turn again and click and stop turning -- and repeat, repeat. What can I do?
