Question about Samsung DLP HL-P5663W 56" TV
Popping sound Picture is fine, popping sound increases or decreases with sound volume.
In our area this is commonly the cable boxes. Does it occur on DVD or other sources? If not:
Reboot your scientific atlanta cable box by unplugging it from the wall for a few seconds, then plug it in and wait about 5 minuites for the time to come on again before use.
Posted on Dec 20, 2007
I have a kenwood ka-94 and it still plays music but if I turn the volume up the speakers start making a popping noise and the speakers are not the problem so I need to know what the problem could be...
It does sound like your speakers. But it could be the output transistor are going bad. As you increase the volume causing more current to go thru them it make a clipping sound. If you have a different set of speaker try and see if the popping is replicated. If not have some check your receiver out.
Oct 20, 2013 | Kenwood Audio Players & Recorders
My 2007 vista grey volume icon is popping up on screen
reinstall your sound card driver and check it and post me
Jun 07, 2012 | Microsoft Windows XP Home Edition
My 8350 was working fine now i cannot hear the phone ring and cannot hear text alerts
make sure the phone isn't on silent by checking the volume level.
Jul 24, 2011 | Blackberry Curve 8350i
Amp pops randomly and gets worse with my remote bass knob hooked up any ideas ?
When you say that the amp "pops" are you referring to the sound that is coming out of the speakers?
This is most likely the speakers "bottoming out", i.e. moving as much as they can, and then slapping against the back of the speaker frame. Adding the remote bass knob (presumably increasing the signal to the amplifier) would make the problem a bit worse, which explains why the popping increases after you add the bass knob.
You can try decreasing the gain on your amplifier and running the system at a moderate volume. If there's no popping occurring, you can be reasonably sure that the subs/speakers are just being over-driven.
Mar 03, 2011 | Rockford Fosgate Power 1501BD Car Audio...
Car making popping sound on left front when putting on brakes and turning to the right
Could be a bent control arm - or - if the popping is a rotational noise (not just one pop, but many - when you drive faster, the popping increases, slower, the popping decreases) Then it is a worn CV joint. CV Driveshaft $65 at NAPA
Oct 03, 2010 | 1999 Plymouth Breeze
My volume menu from monitor pops up, volume auto-decreases
Was something spilled on the volume key? Sounds like it is stuck... you can use a fine toothpick and plain water to "scrub" around the key, there may be some buildup that inhitbits the key from "unpressing".
Hope this helps!
-- RT
Sep 02, 2009 | HP w2207 Monitor
Popping & hardly any volume
i had the first problem and you can probably fix it by turning the volume knob all the way up and down about 20 times. it worked for me. supposedly the potentiometers in the z-5300 get dirty or worn out, somehow this might fix it. for the second problem maybe try plugging it into the laptop and unplugging it again seeing if it goes back to normal?maybe its a problem with the amp?
May 07, 2008 | Logitech Z-5300 Computer Speakers
Loud popping and decrease in volume
I'm guessing power supply problems fluctuating, or main control board.
Apr 19, 2008 | Zenith E44W46LCD 44" Rear Projection...
Toshiba tz50v51 popping sound
Possible problems: * The TV set may be unplugged. * A fuse or circuit breaker may be blown or switched off. * The remote control unit (RCU) may be disabled. Solutions: * Make sure the TV/VCR are plugged in and the wall switch is on. * Check the fuse or circuit breaker. Test the outlet with a lamp. * Replace the RCU's batteries: if this fails exchange the unit.
Jan 18, 2006 | Toshiba TZ50V51 50" Rear Projection...
Samsung DLP HL-P5663W 56" TV Logo
141 people viewed this question
Jerry Greenberg
Jerry Greenberg
