Question about Honda Electrical Supplies
Generator starts but does not generate power
Honda em 6500 generator starts and runs but does not generate power at the plugins or any power at all for that matter.
  • petrvand May 11, 2010
    Does your generator have a reset button? It should have one or two located near the outlets. If that is not the problem, then you may have burned out a diode or other part of your circuit board. I had to have a board put in by a dealer.
    President:
  • 632 Answers
  1. Check for any blown fuse and replace. It can be traced directly from the output lines.
  2. Check field excitation. The field excitation is supplied by the battery to the excitation coil through a pair of carbon brushes. If the brushes are worn out, no excitation field is supplied and no output is generated. Replace carbon brush if found worn-out.
  3. Use an analog multitester to check the continuity of the carbon brush and the field coil.
Posted on Sep 25, 2009
Regulator voltage generator honda EM 1900x
Type honda em 1900x owners manual into your computer search engine, it will bring up sites to get manual.
Apr 25, 2016 | Honda Electrical Supplies
Honda eu 6500 Error e21. First time using it and the machine is new. How to fix it? Sorry there wasn't category for generator
check oil levels as generator will not start if oil level is low. this is a built in safety device on most generators and one of the leading causes of returns to stores />
Aug 03, 2013 | Garden
Powerboss 6500 won't run tools
powerboss generator wont start,,fresh fuel,fire to plug,clean float bowl,,,,,,honda gtx 390 motor,,,,13 hp,,,help
Oct 14, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
Onan Portable Generator - 5000 , Model# 6500: I have china generator capacity is 2700 watts but ...
Alternately,
• Turn-off all lights first.
Run your pump or water start motor.
• When the motor is running,
Turn on the lights , one at a time.
May 18, 2010 | Watts Onan Portable Generator - 5000 ,...
Honda ems 4000 generator starts and runs great, but no power
The plunger is stuck where the governor rod which is spring attached to the frame is. If you locate the governor metal rod on the lower level of the unit. zrock it to a higher rpm as you would a car carburator from under the hood.
This will free the plunger and the green light will go on and your current meter will register 120 volts.
When you lay up the generator for quite some time it often sticks closed. With monthly start up you will no have this problem reoccurr.
May 13, 2010 | Cars & Trucks
At the controller, you need to see if it is actually sending electricity out of the Generator/Alternator, have a look where the leads from the power making unit mates, (Think of it as a motor in reverse) onto the board. There should be an AC Voltage there, then, work back, or out from there, trace the Voltage until it stops, thats the problem... Check the Breaker isn't tripped or faulty too.
Mar 22, 2010 | Electrical Supplies
Converting the power to genertor
You should not have to switch between battery and generator, unless you are trying to use an inverter as well. Batteries are 12vdc, typically run lighting, water pump, furnace, fridge controls. Generator powers ac, microwave, television, and anything else that plugs into a 120vac wall outlet. Inverter may also run select loads, and possibly dedicated wall outlets, but not AC, fridge, or microwave (usually).
Most RVs / Motorhomes now have automatic transfer switches that will switch between the generator, shorepower, and possibly an inverter. Your coach is made during an era of transition from manual transfer switch (in form of heavy duty electrical outlet near shore power cord) and the automatic transfer switch.
There is no specific place where a transfer switch or generator receptacle are mounted on an RV. There are no rules or regulations tha cover this as far as I know. Your RV may also have an EMS (Energy Management System) that will control the transfer switch as well. EMS panels are typically located above the refrigerator or above driver / passenger seats in overhead compartment.
Apr 06, 2009 | Watts Onan Portable Generator - 5000 ,...
Honda EM 2500 Generator
Check out our testing video!
We hold parts too!
Oct 05, 2008 | Electrical Supplies
Electrical Supplies Logo
1,085 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
