Question about Kitchen Ranges
In what order should the wires be installed: black red and white?
  • beachkid01 Sep 25, 2009
    Perfect! Thank You!
    Have a great evening!
  • 15,935 Answers
Thanks for using FixYa!!
Posted on Sep 25, 2009
Have a red,white, black, and green wire power cord...what order do the wires connect?
hello frenchbullsr. If you're looking straight at the terminal block;
the order will be black, white, red, green is connected to the cabinet.
The groundstrap in the middle is folded up and put back out of the way (just in case you need it later)
Red goes to L1
Black goes to L2
white goes to N
Green- to cabinet for ground
I hope this was helpful.
thanks,
Mike
Jul 21, 2011 | Dryers
We were given a HOT POINT Heavy Duty Dryer with Automatic Dry Control, Model DLB2650BRLWH, Serial No. DG241274H and had to buy the power cord to go with it. Ordered the cord from a local appliance company,...
Technical explanation: Older 240 Volt appliances use a three-wire power cord (Black, White, Red). The White wire is the "neutral" connection, which is tied to Ground at the service entrance panel. The Black and Red wires are opposite phases of the 240 VAC (when one goes positive, the other goes negative). The neutral wire is "in between", so measuring the voltage between the black or red wire and neutral would give you 120 VAC. The green wire is frame ground; the electrical code requires newer (since 2008) 240 VAC appliances to have a separate ground bonding connection to the frame; the neutral connection is not considered adequate protection for certain failure conditions.
Look for a screw head or terminal stud on the frame or sheet metal of the dryer labeled "Ground", "Earth", or one of the following ground symbols:
The green wire goes to this point. DO NOT connect the green wire to any of the wiring inside the dryer, unless it is a green wire attached to sheet metal or a bracket!
The black, white and red wires go to black, white and red terminals you already found.
Mar 17, 2011 | Hotpoint Dryers
What does the stereo colors stand for on an 1992 crown victoria Red, black, Grey/blue, yellow/black, white/purple, green/black ,blue/red, orange/green, white/green, blue/white, brown/yellow,...
Red = ground
black = ground
Grey/blue = Left rear (+)
yellow/black = ignition 12v
white/purple = right rear (-)
green/black = (could this be green / violet?) than it is 12v constant
blue/red = illumination
orange/green = left front (+)
white/green = right front (-)
blue/white = left front (-)
brown/yellow = left rear (tan / yellow) (-)
green/orange = right front (+)
orange/red = right rear (+)
blue = not used
Nov 10, 2010 | Ford Car Audio & Video
Just tried to install the fan and light, it doesn't work when power is connected. I have 2 white house wires, none black. I have rechecked the connections, no power to the fan
the white wires are returns they dont supply power .. you may have to take the fan back down in order to find the black or red wire that supplys AC power .. a red wire would come from a wall switch .. the black wire would usually be 120 VAC .. be careful .. you must first turn off power before working with that live wire .. the white wires are always paired with a black wire and a bare wire (safety ground) .. perhaps the black wire just got covered up when the fan was installed .. the black (or red) house wire should be connected to the black and blue wires of the fan .. the white wires should all be connected together .. the bare wire should be attached to the green wire or bolted to the fan housing ..
Jun 22, 2010 | Hunter (25417) Ceiling Fan
What is the order of the green,red,white and
Red goes with the red, usually right side. Black on left white in center and green attached to metal on frame.
Oct 23, 2009 | Dryers
I am installing a ceiling fan/light with a remote control and the wiring in the ceiling has a red wire and two white wires which are connected. I am used to seeing only a black and a white wire. in order...
the two white wires are the neutrals, just add the fan's white wire to the other whites. The red wire is the hot wire, same as a black, so connect it to the black.
Oct 11, 2009 | Home Decorators Collection Star-tech Fan...
I don't know how to re-install loose wires on my power cable
Goes in this order:
Red
White
Yellow
leave last 1 blank
Apr 25, 2009 | Computers & Internet
3 wire dryer 4 wire plug how do I make this work
Connect the two hot wires(black and red) to the two outside teminals(order does not matter here as long as you put one wire to each terminal). Remove wire or metal strap from center terminal to frame. Connect white wire to center terminal. Connect green wire to frame. (ground)
Nov 13, 2008 | Dryers
Wiring hook up in the back for whirpool dryer
assuming you are referring to the power hookup,there is no positive negative, (it's not D.C.) red and black are the hot lines(240 volt between them) white is neutral and green is equipment ground.voltage reading should be 120 volts from red or black to white as well as green, 240 volts from red to black, 0 volts from white to green
Sep 08, 2008 | Whirlpool GEW9250 Electric Dryer
Kitchen Ranges Logo
13 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
