Vertical line down the center, sound OK.
TV working great then got a vertical line down the center of the screen. The sound is OK.
  • 403 Answers
This is the deal. Your picture tube is going out. How thick is the line. As it gets wider that will tell you how much more time you have. Was the TV dropped? There is a way to adjust this but you have to get into the back of the TV and if the static discharge is not done properly it will kill you. Don't mess with it. It is now cheaper to buy another TV on craigslist or your local paper than trying to repair it. Hope this helps.
JimmyC
Posted on Sep 25, 2009
Panasonic TC-P50VT20 blank screen with vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 05, 2017 | Panasonic Televison & Video
Why come white vertical line on my t.v screen in center?
You said "I checked vertical output line from main ic pin 23 found correct"
But the problem is "Horizontal Output Line" Try that.
Jan 29, 2015 | LG Televison & Video
There is a line down the center of the screen
whether the line-shaped vertical or horizontal? if it appears a horizontal line on your side, it signifies the vertical rays do not exit the screen or your TV vertical part is not working. damage can be caused by IC Vertical, or in the vertical deflection coil yoke.dan if a line that appears is from top to bottom that indicates the horizontal section is not working, usually there is a problem of the deflection yoke is not connected or defective.
Jul 11, 2010 | Televison & Video
My 15 year old Toshiba Televisiononly shows a narrow horizontal band in the middle of the screen. Sound OK.
Hiii fairley,
You aren't specsificly dercribe yor tv set.
For common TV horizontal problem ;i.e : White line accross the horizontal screen, horizontal band,etc..it's can solved by replacing the IC Vertical/Transistor, and olso to replace the cap nearest the IC.
For common TV Vertical Problem :i.e : White line at the center of the screen (top to bottom),Vertical band,etc...It's can cure by Replacing the Horizontal IC/Transistor,and offcurse the cap's.
Tha's what all I know....
Hope can help you to solved the problem.
Thank's
h3liax
Jun 22, 2009 | Toshiba 32A33 32" TV
TV BLACK SCREEN WITH THE POWER ON.
It needs repair.
If the line is vertical, then something is damaged on its horizontal circuit section on the mainboard.
If the line is horizontal, the vertical circuit section is damaged.
have it repaired to a qualified service center or person!
avoid switching it to avoid further damage on other parts!
May 28, 2009 | Philips 32RF82S TV
Green horizontal line in center of screen.
Bad vertical output ic. Also, check resistors and diodes around vertical output ic.
Mar 23, 2009 | Sony KP-46V35 TV
Half screen showing
ok
keep tv off.
it will only get wors
if sumon dosent work on it soon
the problem you are having in the vertical section of the tv
hav a repairman resolider all conection on the vertical IC and check the serounding componets for falts.
regards daniel.
PS the repair takes me about 15 min.
Jan 13, 2009 | Samsung TXG2746 27" TV
Toshiba 46In HD Rear projection TV Vertical lines on screen
We also have vertical lines with our JVC 62"... turning it off and letting it cool down is the only solution. For us, we know it's a problem with heat. We simply are wits end on fixing it. added two additional fans, a exterior fan to blow heat away from the back of the tv, pulled everything else away, etc.... Anyway, goodluck.
Dec 24, 2007 | Toshiba 46H83 46" Rear Projection...
LG colour TV RI32CZ10RX problem with picture
My LG tv has suddenly got a problem with the picture. Whilst watching the tv with no problems at all, the picture was suddenly reduced to a thin vertical line down the centre of the screen and an awful smell seemed to come from the tv There is a short ckt in your tv in horl. section. 1 isolate power from horizontal section. 2 check for normal output from power supply. 3 check parts in horl output section a hor.output transistor b diode & cap in h/output trnsformerckt. c check for print. d if all are ok check for eht transformer. e if every thing becomes then reconnect hor output section supply. f put on the set.
Sep 23, 2007 | Televison & Video
Vertical fold over
if the set has a previous vertical line problem and a white horizental line only comes in the cross of the screen and you turned the tv on for a time while the problem is solved that mean you have make a burnt line to the screen , but if you are the tv owner and nothing of that happens so you have a problem in faulty dried capaciter in the vertical live part search for 33uf 160 v or 22u 160 v and alter regards please don't forget to rate thx
May 01, 2007 | Sony KV-32S45 32" TV
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
