Question about Lexmark X1270 All-In-One InkJet Printer
My lexmark x1270 printer has the correct drivers, and is equipped with full ink cartridges. I can request to print a document and the printer will run a page through and act as if it is printing (the ink cartridges even move as if they are printing) but the page comes out blank. can you help?
  • petrvand May 11, 2010
    I had the same problem with my Lexmark I moistend the print cartridges with my finger and this made them wirk. Have you tried running the cleaning program? sometimes different paper will help them start printing, like from glossy to regular paper. Most of the time if you don't use your Lexmark for thirty days or more you will have this problem. I got rid of mine because of this. H P makes better printers and all in one machines.
  • 10,421 Answers
X1270
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 1200 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
After printing the test page, try to print a document again to verify that the problem is fixed.
Jan 23, 2012 | Lexmark X1270 All-In-One InkJet Printer
Unable to print red.
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled (the absolute worst possible choice) or third party cartridges (2nd. Worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Mar 04, 2010 | Lexmark X1270 All-In-One InkJet Printer
My lexmark x1270 says that there is a print cartridge missing, they are both there but it still wont print! HELP!!
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Jan 22, 2010 | Lexmark X1270 All-In-One InkJet Printer
Lexmark x1270 printer will not print any colour 2 new ink cartridges fitted ,only black ink working
Don
Dec 03, 2009 | Lexmark X1270 All-In-One InkJet Printer
Lexmark x1270 poor printing
Try these steps after these if you face the same problem then you need to get the cart exchanged as it may be defective as Lexmark cart comes with 6 months warranty ...
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Jan 27, 2009 | Lexmark X1270 All-In-One InkJet Printer
I installed a new black ink cartridge and my printer will not print. It will scan and save documents and I can select printer from the print menu but it will not print. Print jobs just stay in the queue
Can you print out a test page? if not send the cartridge back to the supplier as it is the cartridge, I was told Lexmark cartridges are brittle and you have to be careful.
Tell me more about it? I have had a LOT of these problems.
Also try putting the cartridge onto a damp cloth and see if that can open it up and another way to open the ink in to pop it into a cup of boiling water, when that is done you should see the ink coming out.
Hope it works
(A fellow X1270 user)
Dec 22, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark x1270 not printing in color
Is the cartridge a Lexmark cartridge or a refilled cartridge?
Remove the cartridge from the printer, take a damp paper towell and wipe the cartridge in one direction on the bottom. Is Ink coming out? If yes then put the cartridge back in the printer and try to print again. If the answer is no and the cartridge is brand new you need to return it to you point of sale and get a new one as its a bad cartridge.
If the cartridge is a refilled cartridge that is probably the problem. Lexmark printers do not support refilled cartridges.
Thanks
Catherine
Sep 08, 2008 | Lexmark X1270 All-In-One InkJet Printer
X1270 will not print color even though it's saying it's full
I've had the lexmark too. the ink dries out in the cartridges.
Nov 19, 2007 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
200 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
