Question about Weber Baby Q Grill
My weber q200 grill won't stay light very low
My weber q200 grill won't stay lit very low flame that eventually dies out
5 Suggested Answers
  • 63 Answers
SOURCE: low/weak flame on Weber Genesis Silver B Grill.
hi my name is mark, could be one of two things the regulator on the propane tank try gently tapping on regulator it could be sticking, and make sure the vent on regulator does not have a spiders web . or the orifices to the burners are restricted. check regulator some are ajustable, some are not. hope that helps. thanks for your question.
Posted on Mar 14, 2009
Treefrog15
  • 127 Answers
SOURCE: low flame on burner...
Remove the burner and check the flexible tubes for kinks or blockages. The flexible tubes usually just slip over the backs of the valves. Spiders love to get in there and block them. Also check that the holes in the burners are not clogged. Be careful when reseating the flexible tubes to be sure that they are properly seated on the back of the valves. Failure to properly seat the flexible tubes can cause leakage there, and the gas can ignite at the back of the valves and not reach the burner. Be certain that the replacement burner is designed to use with your grill and the flexible tubes mate properly with the back of the valves.
Posted on Jul 07, 2009
SOURCE: just bough weber Q200 grill. Is it normal that the
I have used the Q-series for 2 years. The blue and low flame is absolutely normal. Weber's philiosophy is of avoiding flare ups when grilling for best taste. I love this grill - very easy to clean, uses less gas and makes great food.
Posted on Aug 23, 2009
  • 4736 Answers
SOURCE: Q200 weber grill getting gas flow but only at low
This sounds like a case of the OPD tank valve on the propane tank has locked up your regulator. In which case, turn the tank OFF and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose. Now, turn the tank valve ON VERY, VERY SLOWLY (slow motion, slow). Once the valve is completely open, light the burner farthest from the tank first and turn it to the highest setting. If the flame appears to now be normal, light the remaining burners following the same procedure. If all burners have returned to normal height, you solved the problem. Always remember to turn the tank valve ON VERY, VERY SLOWLY.
If the above doesn't solve the problem, you may need to replace the regulator/hose assembly, which you can purchase from any home center or hardware store that sell gas grills and accessories. Take your old one with your for comparison purposes.
Posted on Apr 03, 2011
Flame goes outweber troubleshooting
Try following these steps to reset your FLD (flow limiting device)http://www.edyoungs.com/edyoungs/troubleshoot_tank.htm and then carefully follow the lighting instructions sequence. I hope this works for you. In the future, be careful about the order of turning on your tank and grill AND the order turning off so as not to flood the FLD. Happy grilling and eating!
Sep 02, 2014 | Weber Q200
Model Q200, Propane model Get no flame on the burner. Apparently, getting no gas. Something seems to be stopped up. What to do?
Whether you're using a 20 Lb Propane Grill Tank or a screw in gas canister, the solution to the problem is the same .
1. Be sure you have enough gas in the tank or canister to maintain proper ignition.
2, If the above checks out OK. Turn the LP tank valve OFF or if you're using a screw-on canister
turn the gas valve OFF.
3. Disconnect the hose from the tank or unscrew and remove the gas canister.
4. Wait 5 minutes and reconnect the hose to the tank or reattach the canister to the gas valve.
5. Open the gas valve VERY, VERY SLOWLY (Slow Motion, slow). Once the valve is full open, light
the burner & turn it to HIGH. Did the burner light and does the flame height look correct?
If so, you solved the problem. Remember to always open the tank valve Very, Very Slowly.
if the above didn't solve the problem, you will either need to replace the Hose/Regulator Assembly or the Gas Valve/ Canister Holder. The Hose/Regulator Assembly you can pickup from any home center or hardware store that sell grills & accessories for about $30.00. If it's the Gas Valve/Canister Holder, you will have to purchase that from Weber or from Factory Appliance Parts http://www.appliancefactoryparts.com/gasgrillparts/brands/weber/q200.html Part # WEB4195 ($29.99) The adapter hose is also available there if you want to make it a one stop shop for $32.99
I hope ths helped you and thanks for choosing FixYa. Happy Grilling!!
Aug 26, 2011 | Weber Q Grill
Q200 weber grill getting gas flow but only at low and cannot regulate flame or raise temp for cooking
Apr 03, 2011 | Weber Q Grill
I was grilling peppers on med. heat and when I opened the top a huge ball of flame hit me. We took the grill apart and clean every nook and cranny but we are afraid to use it. What can we do?
That can happen with any grill under the right conditions....fireman know about it in houses....the gases build up and when air is given the flame shoots out....
It is best to always make sure you are clear of the front when opening the lid on ANY grill..
heatman101
Aug 29, 2010 | Weber Q200
CAN'T USE A 2O LB LP TANK ON THE q130 GRILL
hello. Actually I think you are probably dealing with a new issue related to the newer safety device on the 20 pound tanks. Turn off the tank and unscrew it from the grill hose. Then screw it back on and s-l-o-w-l-y open up the valve. Then light the grill.
You should notice a markedly bigger flame now. Enjoy! J.
Jun 23, 2010 | Weber Q Grill
Both burners are lit , tank is new but tepm wont
Your regulator could be bad or you propane tank is close to empty.
Apr 15, 2010 | Weber Q200
Weak flame on webber q200 grill
Remove connection to tank, reconnect, open valve slowly, when you open valve to fast the tank valve has a shutdown in it, it thinks something is wrong and shuts valve down. Always open tank valve slowly when using.
Also your tank valve could be sticking causing this problem, to fix replace tank.
Feb 25, 2010 | Weber Q200
MY PORTABLE GAS WEBERHAS A WEAK FLAME FROM THE
The regulator is probably bad and nees to be replaced.
Jan 01, 2010 | Weber Gas Go-Anywhere Grill
Just bough weber Q200 grill. Is it normal that the flame burns so low and blue?Used to large flames off conventional grills. Thanks.e.
Aug 23, 2009 | Weber Q Grill
Weber Baby Q Grill Logo
501 people viewed this question
Top Weber Grilling Experts
paulcarew
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Weber Grilling Expert? Answer questions, earn points and help others
