Question about Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
No Digital Signal to TV
Hello! I bought a Sony Bravia 40 inch 1080i and originally installed it with the coaxial cable to the digital dvr cable box and it worked fine (horrible picture though). I then bought the HDMI cable, connected it to the back of the TV and to the cable box and I get a 'no digital channel found' meesage. Any ideas?
  • Anonymous Mar 29, 2014
    Tv says no signal after plugging coax from comcast box into tv. Tv is brand new tonight and plays the 23 digital channels fine when hooked directly to the wall, bypassing the cable box.
    Sergeant:
    Champion:
  • 231 Answers
Make sure you have Tv on that particular HDMI input .I believe video 6 or 7 .if you do check menu make sure that input is not blocked. or you might want to try the component outputs of cable box and connect that to a component input on tv to see if that is working,,i have seen these tv HDMI input board bad..lets hoe this is not the case..
Posted on Dec 16, 2007
Sony bravia no tv signal but video okay
Check and replace its tuner. Contact any service technician. This is not a user repairable work. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 16, 2014 | Televison & Video
Can the sony bravia home theater system be surround for both dvd and tv?
Strickly speaking about the audio:
The unit has digital audio in on 1 each coaxial and digital connectors.
Most DVD players have digital audio out in either a coaxial (RCA-looking) cable or optical cable.
Consider this: your TV is not a Source of audio (or even video, if you think about it). You probably get your programming from a cable or satellite box, Its audio should be available digitally.
If your DVD and cable use DIFFERENT types of digital audio sources, you're in luck. Attach each one to its compatible input on the Bravia. If you only have two optical outputs you can only attach one at a time.
If you have only two COAXIAL digital audio sources you CAN combine them into a single digital input on the Bravia by getting an RCA-splitter cable to connect them both to the one connector. It will only work if you leave one source dormant or off at any time you're monitoring the other source, otherwise you'll have two digital 'converstions' going on with the Bravia at the same time and it won't be pretty.
Dec 14, 2010 | Sony BRAVIA® DAV-HDX277WC Theater System...
Want to change my cable box from 1080i to 480i
U can't not change mode at will,the 480i or 1080i is determin by the show what mode is play on.1080i only in HD,more HD will need to order from ur cable,dish or telicom compannies.
Dec 17, 2009 | Sony Bravia KDL-40S4100 40 in. LCD TV
I have a sony 40 inches bravia flat screen hd and
Could be the decoder:
1. unplug the TV ans wait a few mins.
2. If you have digital cable box or dish tuner reboot those as well (likely your issue)
What you have is artifacting what that means is tiling garbiling and freezing this happends when the data in the digital stream just stopped hence Frozen.
Try those things rule out your cable tv box first or your sat box, if this is OTA over the air your antenna.
1. Try DVD's if it happends during a DVD you do have a decoder issue if it does not you need to talk to your cable tv or sat operator.
So you got 3 possiabilites here 1. the worse Decoder, 2 cable company or satalite provider, 3 your antenna is in the wroung position.
I sure this will help.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Nov 30, 2009 | Sony Bravia KDL-40S4100 40 in. LCD TV
Wiring problems
Not certain if HDMI can be used in a setup like this. I'd try it from the home theater (HT) to the TV, and other wiring for the other components.
For video:
All of these should have component connections (Y/Pr/Pb). You'll only need the video cables for each device:
  • Video out from cable, HT, and combo player.
  • Video in to TV. Your choice of inputs.
For audio:
Hopefully, the two output devices (the combo player and the cable box) have digital audio (fiber optic, or RCA coaxial). Otherwise, you'll only get stereo sound. VHS is stereo only anyway.
  • Audio out from cable box and combo player.
  • Audio in to HT.
The TV won't have anything to do with audio in this setup. Alternatively, you could try hooking up all inputs to the TV, and connecting audio out from the TV to the HT. Works best if this connection is digital, for surround.
Jan 01, 2009 | Sony BRAVIA DAVHDX275 Theater System
Which component cables to use
the cables are fine labeled as they are you notice cr =pr, cb=pb and y is still y
the cables are fine and will deliver up to 1080I capabilities
Dec 09, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony Bravia Dav-HDX279W and comcast HDTV Cable box connection.
Like above, use an optical connection (need fiber optic cable) or a coaxial connection (single RCA cable). HDMI might also work, but I personally haven't checked. Connect the audio outs from the cable box to the audio ins on the home theater. The TV will only need a video connection from the cable box, as well as one from the home theater (for DVDs, onscreen menus).
This discussion can help you set up the universal remote.
Nov 18, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Sony Bravia and Comcast MY DVR Not Working Now
Greetings...
Is the Comcast box digital? and is it a Scientific America 8000 series box?
If so, try unplugging the power to the cable box for a minute, replug and after the reboot see if that fixes the problem...
Ed
Dec 14, 2007 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Sony Bravia KDL-46S2010
Try plugging the coax directly into the T.V. or from you VCR or DVD player then to the TV. The bravia sets also have various picture mode settings as you will discover when you go through your manual. Cable boxes or splitters can cause problems also is they are not of good quality. I love my 40.
Jul 13, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
527 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
